Commit ec4c6370 authored by Jonathan Jenkins's avatar Jonathan Jenkins
floating point best practices
parent 2e7b25cc
...@@ -419,6 +419,14 @@ reverse handler only needs to reverse as single event, in order) ...@@ -419,6 +419,14 @@ reverse handler only needs to reverse as single event, in order)
\item how to handle queues \item how to handle queues
\end{itemize} \end{itemize}
\subsection{Working with floating-point data}
Floating point variables are particularly tricky to use in optimistic
simulations, as rounding errors prevent rolling back to a consistent state by
merely performing the inverse operations (e.g., $a+b-b \neq a$). Hence, it is
instead preferable to simply store the local floating-point state in the event
structure and perform assignment on rollback.
\subsection{How to complete a simulation} \subsection{How to complete a simulation}
TODO: fill this in. Most core ROSS examples are design to intentionally hit TODO: fill this in. Most core ROSS examples are design to intentionally hit
Markdown is supported
0%
or
Please register or to comment
