Commit ea77dc24 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
missing EXTRA_DIST entries
parent 218edc0c
...@@ -5,4 +5,4 @@ Nikhil Jain (UIUC) ...@@ -5,4 +5,4 @@ Nikhil Jain (UIUC)
Xu Yang (IIT) Xu Yang (IIT)
- Added support for running multiple application workloads with CODES MPI - Added support for running multiple application workloads with CODES MPI
Simulation layer. Simulation layer, along with supporting scripts and utilities.
...@@ -21,8 +21,7 @@ $(pkgconfig_DATA): config.status ...@@ -21,8 +21,7 @@ $(pkgconfig_DATA): config.status
EXTRA_DIST += \ EXTRA_DIST += \
prepare.sh COPYRIGHT TODO.txt configure.ac uc-codes.cfg reformat.sh \ prepare.sh COPYRIGHT TODO.txt configure.ac uc-codes.cfg reformat.sh \
misc/README misc/ptrn_loggp-2.4.6.patch \ misc/README misc/ptrn_loggp-2.4.6.patch CONTRIBUTORS.md
doc/BUILD_STEPS doc/GETTING_STARTED doc/RELEASE_NOTES
AM_CPPFLAGS = -I$(top_srcdir)/src ${ROSS_CFLAGS} AM_CPPFLAGS = -I$(top_srcdir)/src ${ROSS_CFLAGS}
...@@ -13,7 +13,7 @@ EXTRA_DIST += \ ...@@ -13,7 +13,7 @@ EXTRA_DIST += \
doc/algorithm.sty \ doc/algorithm.sty \
doc/algorithmic.sty \ doc/algorithmic.sty \
doc/codes-best-practices.tex \ doc/codes-best-practices.tex \
doc/Makefile.best-practice \ doc/Makefile \
doc/example/example.conf \ doc/example/example.conf \
doc/example_heterogeneous/example.conf \ doc/example_heterogeneous/example.conf \
doc/example_heterogeneous/example_torus.conf \ doc/example_heterogeneous/example_torus.conf \
...@@ -6,7 +6,13 @@ bin_SCRIPTS += $(my_bin_scripts) ...@@ -6,7 +6,13 @@ bin_SCRIPTS += $(my_bin_scripts)
EXTRA_DIST += scripts/codes_configurator.py.in \ EXTRA_DIST += scripts/codes_configurator.py.in \
scripts/codes_filter_configs.py.in \ scripts/codes_filter_configs.py.in \
scripts/codes_config_get_vals.py.in \ scripts/codes_config_get_vals.py.in \
scripts/configurator.py scripts/configurator.py \
scripts/example/example.template \
scripts/example/params.py \
scripts/allocation_gen/allocation.conf \
scripts/allocation_gen/config_alloc.conf \
scripts/allocation_gen/listgen.py \
scripts/allocation_gen/README
CLEANFILES += $(my_bin_scripts) CLEANFILES += $(my_bin_scripts)
# manual rules for now # manual rules for now
...@@ -15,16 +15,22 @@ EXTRA_DIST += src/iokernellang/codesparser.y.in \ ...@@ -15,16 +15,22 @@ EXTRA_DIST += src/iokernellang/codesparser.y.in \
src/workload/TODO.codes-workload \ src/workload/TODO.codes-workload \
src/network-workloads/README_synthetic.txt \ src/network-workloads/README_synthetic.txt \
src/network-workloads/README_traces.txt \ src/network-workloads/README_traces.txt \
src/network-workloads/workloads.conf \
src/network-workloads/conf/modelnet-mpi-test.conf \ src/network-workloads/conf/modelnet-mpi-test.conf \
src/network-workloads/conf/modelnet-mpi-test-cry-router.conf \ src/network-workloads/conf/modelnet-mpi-test-cry-router.conf \
src/network-workloads/conf/modelnet-mpi-test-dragonfly.conf \ src/network-workloads/conf/modelnet-mpi-test-dragonfly.conf \
src/network-workloads/conf/modelnet-mpi-test-mini-fe.conf \ src/network-workloads/conf/modelnet-mpi-test-mini-fe.conf \
src/network-workloads/conf/modelnet-mpi-test-torus.conf \ src/network-workloads/conf/modelnet-mpi-test-torus.conf \
src/network-workloads/conf/allocation-cont.conf \
src/network-workloads/conf/allocation-random.conf \
src/network-workloads/conf/modelnet-synthetic-dragonfly.conf \
src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf \
src/networks/model-net/doc/README \ src/networks/model-net/doc/README \
src/networks/model-net/doc/README.dragonfly.txt \ src/networks/model-net/doc/README.dragonfly.txt \
src/networks/model-net/doc/README.loggp.txt \ src/networks/model-net/doc/README.loggp.txt \
src/networks/model-net/doc/README.simplenet.txt \ src/networks/model-net/doc/README.simplenet.txt \
src/networks/model-net/doc/README.simplep2p.txt \ src/networks/model-net/doc/README.simplep2p.txt \
src/networks/model-net/doc/README.torus.txt \
src/networks/model-net/MN_TODO src/networks/model-net/MN_TODO
#src/network-workload/README #src/network-workload/README
...@@ -34,6 +34,8 @@ EXTRA_DIST += tests/lp-io-test.sh \ ...@@ -34,6 +34,8 @@ EXTRA_DIST += tests/lp-io-test.sh \
tests/workload/codes-workload-test.sh \ tests/workload/codes-workload-test.sh \
tests/workload/codes-workload-test.conf \ tests/workload/codes-workload-test.conf \
tests/workload/README.txt \ tests/workload/README.txt \
tests/workload/darshan-dump.sh \
tests/workload/example.darshan.gz \
tests/mapping_test.sh \ tests/mapping_test.sh \
tests/lsm-test.sh \ tests/lsm-test.sh \
tests/resource-test.sh \ tests/resource-test.sh \
Markdown is supported
0% or .
Please register or to comment
