Commit e9c89f8d authored by Jonathan Jenkins's avatar Jonathan Jenkins
move workload implementations into their own dir
parent 740719a0
...@@ -38,14 +38,14 @@ include $(top_srcdir)/tests/Makefile.subdir ...@@ -38,14 +38,14 @@ include $(top_srcdir)/tests/Makefile.subdir
if USE_DARSHAN if USE_DARSHAN
AM_CPPFLAGS += ${DARSHAN_CFLAGS} -DUSE_DARSHAN=1 AM_CPPFLAGS += ${DARSHAN_CFLAGS} -DUSE_DARSHAN=1
src_libcodes_base_a_SOURCES += src/workload/codes-darshan-io-wrkld.c src_libcodes_base_a_SOURCES += src/workload/methods/codes-darshan-io-wrkld.c
tests_workload_codes_workload_test_LDADD += ${DARSHAN_LIBS} tests_workload_codes_workload_test_LDADD += ${DARSHAN_LIBS}
tests_workload_codes_workload_mpi_replay_LDADD += ${DARSHAN_LIBS} tests_workload_codes_workload_mpi_replay_LDADD += ${DARSHAN_LIBS}
endif endif
if USE_RECORDER if USE_RECORDER
AM_CPPFLAGS += ${RECORDER_CPPFLAGS} AM_CPPFLAGS += ${RECORDER_CPPFLAGS}
src_libcodes_base_a_SOURCES += src/workload/codes-recorder-io-wrkld.c src_libcodes_base_a_SOURCES += src/workload/methods/codes-recorder-io-wrkld.c
endif endif
if USE_DUMPI if USE_DUMPI
...@@ -116,8 +116,8 @@ src_libcodes_base_a_SOURCES = \ ...@@ -116,8 +116,8 @@ src_libcodes_base_a_SOURCES = \
src/logging/timeline.c \ src/logging/timeline.c \
src/workload/codes-workload.c \ src/workload/codes-workload.c \
src/workload/codes-workload-method.h \ src/workload/codes-workload-method.h \
src/workload/codes-bgp-io-wrkld.c \ src/workload/methods/codes-bgp-io-wrkld.c \
src/workload/test-workload-method.c \ src/workload/methods/test-workload-method.c \
codes/rc-stack.h \ codes/rc-stack.h \
src/util/rc-stack.c src/util/rc-stack.c
...@@ -12,7 +12,7 @@ ...@@ -12,7 +12,7 @@
#include <codes/codeslexer.h> #include <codes/codeslexer.h>
#include "codes/codes-workload.h" #include "codes/codes-workload.h"
#include "codes-workload-method.h" #include "src/workload/codes-workload-method.h"
#include "codes/quickhash.h" #include "codes/quickhash.h"
#define RANK_HASH_TABLE_SIZE 400 #define RANK_HASH_TABLE_SIZE 400
...@@ -8,7 +8,7 @@ ...@@ -8,7 +8,7 @@
#include "darshan-logutils.h" #include "darshan-logutils.h"
...@@ -17,7 +17,7 @@ ...@@ -17,7 +17,7 @@
#include "ross.h" #include "ross.h"
#include "codes/jenkins-hash.h" #include "codes/jenkins-hash.h"
...@@ -13,7 +13,7 @@ ...@@ -13,7 +13,7 @@
static int test_workload_load(const char* params, int rank); static int test_workload_load(const char* params, int rank);
static void test_workload_get_next(int rank, struct codes_workload_op *op); static void test_workload_get_next(int rank, struct codes_workload_op *op);
Markdown is supported
0%
or
Please register or to comment
