Commit e6f95a18 authored by Misbah Mubarak's avatar Misbah Mubarak
adding hop count for local nodes in df-dally
parent e7c55e0c
...@@ -46,8 +46,9 @@ static int BIAS_MIN = 1; ...@@ -46,8 +46,9 @@ static int BIAS_MIN = 1;
static int DF_DALLY = 0; static int DF_DALLY = 0;
static int adaptive_threshold = 1024; static int adaptive_threshold = 1024;
unsigned long num_local_packets = 0; static long num_local_packets_sr = 0;
unsigned long num_remote_packets = 0; static long num_local_packets_sg = 0;
static long num_remote_packets = 0;
using namespace std; using namespace std;
struct Link { struct Link {
int offset, type; int offset, type;
...@@ -841,7 +842,7 @@ void dragonfly_custom_report_stats() ...@@ -841,7 +842,7 @@ void dragonfly_custom_report_stats()
tw_stime avg_time, max_time; tw_stime avg_time, max_time;
int total_minimal_packets, total_nonmin_packets; int total_minimal_packets, total_nonmin_packets;
long total_gen, total_fin; long total_gen, total_fin;
long total_local_packets, total_remote_packets; long total_local_packets_sr, total_local_packets_sg, total_remote_packets;
MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &total_hops, &avg_hops, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &N_finished_packets, &total_finished_packets, 1, MPI_LONG_LONG, MPI_SUM, 0, MPI_COMM_CODES);
...@@ -853,7 +854,8 @@ void dragonfly_custom_report_stats() ...@@ -853,7 +854,8 @@ void dragonfly_custom_report_stats()
MPI_Reduce( &packet_gen, &total_gen, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &packet_gen, &total_gen, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce(&packet_fin, &total_fin, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce(&packet_fin, &total_fin, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce( &num_local_packets, &total_local_packets, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &num_local_packets_sr, &total_local_packets_sr, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce( &num_local_packets_sg, &total_local_packets_sg, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
MPI_Reduce( &num_remote_packets, &total_remote_packets, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES); MPI_Reduce( &num_remote_packets, &total_remote_packets, 1, MPI_LONG, MPI_SUM, 0, MPI_COMM_CODES);
if(routing == ADAPTIVE || routing == PROG_ADAPTIVE) if(routing == ADAPTIVE || routing == PROG_ADAPTIVE)
...@@ -870,7 +872,7 @@ void dragonfly_custom_report_stats() ...@@ -870,7 +872,7 @@ void dragonfly_custom_report_stats()
printf("\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally completed packets %lld \n", printf("\n ADAPTIVE ROUTING STATS: %d chunks routed minimally %d chunks routed non-minimally completed packets %lld \n",
total_minimal_packets, total_nonmin_packets, total_finished_chunks); total_minimal_packets, total_nonmin_packets, total_finished_chunks);
printf("\n Total packets generated %ld finished %ld Locally routed %ld Remote (inter-group) %ld \n", total_gen, total_fin, total_local_packets, total_remote_packets); printf("\n Total packets generated %ld finished %ld Locally routed- same router %ld different-router %ld Remote (inter-group) %ld \n", total_gen, total_fin, total_local_packets_sr, total_local_packets_sg, total_remote_packets);
return; return;
...@@ -1232,7 +1234,12 @@ static void packet_generate(terminal_state * s, tw_bf * bf, terminal_custom_mess ...@@ -1232,7 +1234,12 @@ static void packet_generate(terminal_state * s, tw_bf * bf, terminal_custom_mess
int src_grp_id = s->router_id / s->params->num_routers; int src_grp_id = s->router_id / s->params->num_routers;
if(src_grp_id == dest_grp_id) if(src_grp_id == dest_grp_id)
num_local_packets++; {
if(dest_router_id == s->router_id)
num_local_packets_sr++;
else
num_local_packets_sg++;
else else
num_remote_packets++; num_remote_packets++;
Markdown is supported
0%
or
Please register or to comment
