Commit e6a368c5 authored by Jonathan Jenkins's avatar Jonathan Jenkins
const-correctness
parent 18afbc3a
...@@ -112,12 +112,12 @@ int codes_mapping_get_lp_count( ...@@ -112,12 +112,12 @@ int codes_mapping_get_lp_count(
if (group_name == NULL) if (group_name == NULL)
ignore_repetitions = 0; ignore_repetitions = 0;
for (int g = 0; g < lpconf.lpgroups_count; g++){ for (int g = 0; g < lpconf.lpgroups_count; g++){
config_lpgroup_t *lpg = &lpconf.lpgroups[g]; const config_lpgroup_t *lpg = &lpconf.lpgroups[g];
// iterate over the lps if the group is null (count across all groups) // iterate over the lps if the group is null (count across all groups)
// or if the group names match // or if the group names match
if (group_name == NULL || strcmp(lpg->name, group_name) == 0){ if (group_name == NULL || strcmp(lpg->name, group_name) == 0){
for (int l = 0; l < lpg->lptypes_count; l++){ for (int l = 0; l < lpg->lptypes_count; l++){
config_lptype_t *lpt = &lpg->lptypes[l]; const config_lptype_t *lpt = &lpg->lptypes[l];
if (strcmp(lp_type_name, lpt->name) == 0){ if (strcmp(lp_type_name, lpt->name) == 0){
// increment the count if we are ignoring annotations, // increment the count if we are ignoring annotations,
// query and entry are both unannotated, or if the // query and entry are both unannotated, or if the
...@@ -151,7 +151,7 @@ void codes_mapping_get_lp_id( ...@@ -151,7 +151,7 @@ void codes_mapping_get_lp_id(
*gid = 0; *gid = 0;
// for each group // for each group
// in any case, count up the lps (need for repetition handling) // in any case, count up the lps (need for repetition handling)
tw_lpid rep_count = 0; tw_lpid rep_count = 0;
...@@ -162,7 +162,7 @@ void codes_mapping_get_lp_id( ...@@ -162,7 +162,7 @@ void codes_mapping_get_lp_id(
tw_lpid local_rep_count = 0; tw_lpid local_rep_count = 0;
// for each lp type // for each lp type
// does lp name match? // does lp name match?
if (strcmp(lpt->name, lp_type_name) == 0){ if (strcmp(lpt->name, lp_type_name) == 0){
// does annotation match (or are we ignoring annotations?) // does annotation match (or are we ignoring annotations?)
...@@ -210,16 +210,16 @@ int codes_mapping_get_lp_relative_id( ...@@ -210,16 +210,16 @@ int codes_mapping_get_lp_relative_id(
int group_index, lp_type_index, rep_id, offset; int group_index, lp_type_index, rep_id, offset;
codes_mapping_get_lp_info(gid, NULL, &group_index, codes_mapping_get_lp_info(gid, NULL, &group_index,
local_lp_name, &lp_type_index, local_annotation, &rep_id, &offset); local_lp_name, &lp_type_index, local_annotation, &rep_id, &offset);
char * anno = (local_annotation[0]=='\0') ? NULL : local_annotation; const char * anno = (local_annotation[0]=='\0') ? NULL : local_annotation;
uint64_t group_lp_count = 0; uint64_t group_lp_count = 0;
// if not group_specific, then count up LPs of all preceding groups // if not group_specific, then count up LPs of all preceding groups
if (!group_wise){ if (!group_wise){
for (int g = 0; g < group_index; g++){ for (int g = 0; g < group_index; g++){
uint64_t lp_count = 0; uint64_t lp_count = 0;
if (strcmp(local_lp_name, lpt->name) == 0){ if (strcmp(local_lp_name, lpt->name) == 0){
// both LPs are unannotated, or if the annotations match // both LPs are unannotated, or if the annotations match
...@@ -237,7 +237,7 @@ int codes_mapping_get_lp_relative_id( ...@@ -237,7 +237,7 @@ int codes_mapping_get_lp_relative_id(
uint64_t lp_pre_count = 0; uint64_t lp_pre_count = 0;
for (int l = 0; l < lpconf.lpgroups[group_index].lptypes_count; l++){ for (int l = 0; l < lpconf.lpgroups[group_index].lptypes_count; l++){
config_lptype_t *lpt = &lpconf.lpgroups[group_index].lptypes[l]; const config_lptype_t *lpt = &lpconf.lpgroups[group_index].lptypes[l];
if (!annotation_wise || cmp_anno(anno, lpt->anno)){ if (!annotation_wise || cmp_anno(anno, lpt->anno)){
lp_count += lpt->count; lp_count += lpt->count;
...@@ -268,13 +268,13 @@ tw_lpid codes_mapping_get_lpid_from_relative( ...@@ -268,13 +268,13 @@ tw_lpid codes_mapping_get_lpid_from_relative(
int rel_id_count = 0; int rel_id_count = 0;
tw_lpid gid_count = 0; tw_lpid gid_count = 0;
if (group_name == NULL || strcmp(group_name, lpg->name) == 0){ if (group_name == NULL || strcmp(group_name, lpg->name) == 0){
// consider this group for counting // consider this group for counting
tw_lpid local_gid_count = 0; tw_lpid local_gid_count = 0;
int local_rel_id_count = 0; int local_rel_id_count = 0;
local_gid_count += lpt->count; local_gid_count += lpt->count;
if (strcmp(lp_type_name, lpt->name) == 0 && if (strcmp(lp_type_name, lpt->name) == 0 &&
(!annotation_wise || cmp_anno(annotation, lpt->anno))){ (!annotation_wise || cmp_anno(annotation, lpt->anno))){
...@@ -291,7 +291,7 @@ tw_lpid codes_mapping_get_lpid_from_relative( ...@@ -291,7 +291,7 @@ tw_lpid codes_mapping_get_lpid_from_relative(
gid += local_gid_count * rep; gid += local_gid_count * rep;
// count up lps listed prior to this entry // count up lps listed prior to this entry
if ( strcmp(lp_type_name, lpt->name) == 0 && if ( strcmp(lp_type_name, lpt->name) == 0 &&
(!annotation_wise || (!annotation_wise ||
cmp_anno(annotation, lpt->anno))){ cmp_anno(annotation, lpt->anno))){
...@@ -349,7 +349,7 @@ void codes_mapping_get_lp_info( ...@@ -349,7 +349,7 @@ void codes_mapping_get_lp_info(
tw_lpid id_total = 0; tw_lpid id_total = 0;
tw_lpid num_id_group, num_id_per_rep = 0; tw_lpid num_id_group, num_id_per_rep = 0;
// count up the number of ids in this group // count up the number of ids in this group
...@@ -367,7 +367,7 @@ void codes_mapping_get_lp_info( ...@@ -367,7 +367,7 @@ void codes_mapping_get_lp_info(
rem -= num_id_per_rep * (tw_lpid)*rep_id; rem -= num_id_per_rep * (tw_lpid)*rep_id;
num_id_per_rep = 0; num_id_per_rep = 0;
if (rem < num_id_per_rep + lpt->count){ if (rem < num_id_per_rep + lpt->count){
// found the specific LP // found the specific LP
if (lp_type_name != NULL) if (lp_type_name != NULL)
...@@ -473,11 +473,11 @@ const char* codes_mapping_get_annotation_by_name( ...@@ -473,11 +473,11 @@ const char* codes_mapping_get_annotation_by_name(
const char * group_name, const char * group_name,
const char * lp_type_name){ const char * lp_type_name){
if (strcmp(lpg->name, group_name) == 0){ if (strcmp(lpg->name, group_name) == 0){
// group found, iterate through types // group found, iterate through types
// type found, return the annotation // type found, return the annotation
if (lpt->anno[0] == '\0') if (lpt->anno[0] == '\0')
Markdown is supported
0%
or
Please register or to comment
