Commit e58af845 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
bad list manip in lp-io
parent ccd9b778
...@@ -101,7 +101,7 @@ int lp_io_write(tw_lpid gid, char* identifier, int size, void* buffer) ...@@ -101,7 +101,7 @@ int lp_io_write(tw_lpid gid, char* identifier, int size, void* buffer)
int lp_io_write_rev(tw_lpid gid, char* identifier){ int lp_io_write_rev(tw_lpid gid, char* identifier){
struct identifier* id; struct identifier* id, *id_prev;
struct io_buffer *buf, *buf_prev; struct io_buffer *buf, *buf_prev;
/* find given identifier */ /* find given identifier */
...@@ -112,10 +112,12 @@ int lp_io_write_rev(tw_lpid gid, char* identifier){ ...@@ -112,10 +112,12 @@ int lp_io_write_rev(tw_lpid gid, char* identifier){
id = identifiers; id = identifiers;
while (id && (strcmp(identifier, id->identifier) != 0)){ while (id && (strcmp(identifier, id->identifier) != 0)){
id_prev = id;
id = id->next; id = id->next;
if (!id){ if (!id){
fprintf(stderr, "Error: identifier %s not found on reverse.\n", identifier); fprintf(stderr, "Error: identifier %s not found on reverse for LP %lu.",
identifier,gid);
return(-1); return(-1);
...@@ -138,7 +140,12 @@ int lp_io_write_rev(tw_lpid gid, char* identifier){ ...@@ -138,7 +140,12 @@ int lp_io_write_rev(tw_lpid gid, char* identifier){
if (id->buffers_count == 0){ if (id->buffers_count == 0){
/* seg faults caused with empty identifiers for some reason - remove /* seg faults caused with empty identifiers for some reason - remove
* this ID */ * this ID */
identifiers = id->next; if (id == identifiers){
else{
id_prev->next = id->next;
free(id); free(id);
identifiers_count--; identifiers_count--;
Markdown is supported
0% or .
Please register or to comment
