Commit dfd41622 authored by Noah Wolfe's avatar Noah Wolfe
Browse files
Fat Tree Custom- configuration verified for k=4
 - Verified to construct 3-level fat trees correctly using custom-
approach.
 - Verified to work with 2, 3 and 4 pods.
parent 92409c58
...@@ -20,7 +20,7 @@ ...@@ -20,7 +20,7 @@
//#define TRACK_PKT -1 //#define TRACK_PKT -1
#define TRACK_PKT 2820 #define TRACK_PKT 2820
#define FATTREE_HELLO 0 #define FATTREE_HELLO 0
#define FATTREE_DEBUG 0 #define FATTREE_DEBUG 1
#define FATTREE_CONNECTIONS 1 #define FATTREE_CONNECTIONS 1
#define FATTREE_MSG 0 #define FATTREE_MSG 0
#define DEBUG_RC 0 #define DEBUG_RC 0
...@@ -104,7 +104,6 @@ struct fattree_param ...@@ -104,7 +104,6 @@ struct fattree_param
// configuration parameters // configuration parameters
int num_levels; int num_levels;
int link_repetitions; int link_repetitions;
int requested_terminals; //Number of terminals to shoot for if possible
int Ns; // number of switches per pod int Ns; // number of switches per pod
int Np; //Number of pods int Np; //Number of pods
int *num_switches; //switches at various levels int *num_switches; //switches at various levels
...@@ -407,9 +406,6 @@ static void fattree_read_config(const char * anno, fattree_param *p){ ...@@ -407,9 +406,6 @@ static void fattree_read_config(const char * anno, fattree_param *p){
tw_error(TW_LOC, "Too many num_levels, only upto 3 supported Aborting\n"); tw_error(TW_LOC, "Too many num_levels, only upto 3 supported Aborting\n");
configuration_get_value_int(&config, "PARAMS", "requested_terminals", anno,
&p->requested_terminals);
p->num_switches = (int *) malloc (p->num_levels * sizeof(int)); p->num_switches = (int *) malloc (p->num_levels * sizeof(int));
p->switch_radix = (int*) malloc (p->num_levels * sizeof(int)); p->switch_radix = (int*) malloc (p->num_levels * sizeof(int));
...@@ -455,18 +451,19 @@ static void fattree_read_config(const char * anno, fattree_param *p){ ...@@ -455,18 +451,19 @@ static void fattree_read_config(const char * anno, fattree_param *p){
p->Ns = p->switch_radix[0]/2; p->Ns = p->switch_radix[0]/2;
int num_terminals = p->num_switches[0]*p->switch_radix[0]/2;
if(p->num_levels == 2) { if(p->num_levels == 2) {
p->num_switches[1] = p->num_switches[0]/2; p->num_switches[1] = p->num_switches[0]/2;
p->switch_radix[1] = p->switch_radix[0]; p->switch_radix[1] = p->switch_radix[0];
} else { } else {
if(p->ft_type == 0){ if(p->ft_type == 0){
p->Np = ceil((double)p->requested_terminals/(double)(p->Ns*p->Ns)); p->Np = ceil((num_terminals)/(double)(p->Ns*p->Ns));
p->num_switches[1] = p->num_switches[0]; p->num_switches[1] = p->num_switches[0];
p->num_switches[2] = ceil((p->Ns*p->Ns) / floor(p->switch_radix[0]/p->Np)); p->num_switches[2] = ceil((p->Ns*p->Ns) / floor(p->switch_radix[0]/p->Np));
p->switch_radix[1] = p->switch_radix[2] = p->switch_radix[0]; p->switch_radix[1] = p->switch_radix[2] = p->switch_radix[0];
p->link_repetitions = floor(p->switch_radix[2] / p->Np); p->link_repetitions = floor(p->switch_radix[2] / p->Np);
printf("Np:%d Ns:%d requested_terminals:%d\n",p->Np,p->Ns,p->requested_terminals); printf("Np:%d Ns:%d\n",p->Np,p->Ns);
}else{ }else{
p->num_switches[2] = p->num_switches[0]/2; p->num_switches[2] = p->num_switches[0]/2;
...@@ -474,17 +471,7 @@ static void fattree_read_config(const char * anno, fattree_param *p){ ...@@ -474,17 +471,7 @@ static void fattree_read_config(const char * anno, fattree_param *p){
if(p->num_levels == 2){ #if FATTREE_CONNECTIONS
if(p->requested_terminals > 2*(p->switch_radix[0]/2)*(p->switch_radix[0]/2)){
tw_error(TW_LOC, "too many terminals requested. Can't maintain full bisection bandwidth for given radix.");
}else{
if(p->requested_terminals > 2*(p->switch_radix[0]/2)*(p->switch_radix[0]/2)*(p->switch_radix[0]/2)){
#if FATTREE_DEBUG
for(int jj=0;jj<3;jj++) for(int jj=0;jj<3;jj++)
printf("num_switches[%d]=%d\n",jj,p->num_switches[jj]); printf("num_switches[%d]=%d\n",jj,p->num_switches[jj]);
...@@ -891,33 +878,6 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -891,33 +878,6 @@ void switch_init(switch_state * r, tw_lp * lp)
// int l2_base = 0;
/* not true anymore */
/* r->start_uneigh = p->num_switches[0] + l2_base;
r->con_per_uneigh = 1;
if(((int)r->switch_id - p->num_switches[0]) % p->l1_set_size >=
p->l1_set_size/2) {
l2_base += (p->num_switches[2]/2);
for(int l2 = 0; l2 < p->num_switches[2]/2; l2++) {
tw_lpid nextTerm;
codes_mapping_get_lp_id(lp_group_name, "fattree_switch", NULL, 1,
l2_base, 2, &nextTerm);
for(int con = 0; con < r->con_per_uneigh; con++) {
r->port_connections[r->num_cons++] = nextTerm;
codes_mapping_get_lp_info(nextTerm, lp_group_name, &mapping_grp_id, NULL,
&mapping_type_id, anno, &mapping_rep_id, &mapping_offset);
next_switch_lid = mapping_rep_id + mapping_offset * p->num_switches[0];
written += sprintf(r->output_buf + written, "%u, %llu, ", r->switch_id+p->num_terminals,LLU(next_switch_lid)+p->num_terminals);
#endif
#if FATTREE_DEBUG
printf("I am switch %d, connect to upper switch %d L2 (%llu) at port %d yes collecting\n",
r->switch_id, l2_base, LLU(nextTerm), r->num_cons - 1);
#endif
l2_base++;
} else { } else {
int l2 = ((r->switch_id - p->num_switches[0]) % p->l1_set_size); int l2 = ((r->switch_id - p->num_switches[0]) % p->l1_set_size);
/* not true anymore */ /* not true anymore */
...@@ -950,17 +910,12 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -950,17 +910,12 @@ void switch_init(switch_state * r, tw_lp * lp)
} else { } else {
if(p->ft_type == 0) { if(p->ft_type == 0) {
r->con_per_lneigh = 1; r->con_per_lneigh = p->link_repetitions;
r->start_lneigh = p->num_switches[0]; r->start_lneigh = p->num_switches[0];
r->end_lneigh = r->start_lneigh + p->num_switches[1]; r->end_lneigh = r->start_lneigh + p->num_switches[1];
int l1 = 0; int l1 = (r->switch_id - p->num_switches[0] - p->num_switches[1]) % p->l1_set_size;
if((int)r->switch_id - p->num_switches[0] - p->num_switches[1] >= for(; l1 < p->num_switches[1]; l1 += p->l1_set_size) {
(p->num_switches[2]/2)) {
l1 += (p->l1_set_size/2);
int count = 0;
for(; l1 < p->num_switches[1]; l1++) {
tw_lpid nextTerm; tw_lpid nextTerm;
codes_mapping_get_lp_id(lp_group_name, "fattree_switch", NULL, 1, codes_mapping_get_lp_id(lp_group_name, "fattree_switch", NULL, 1,
l1, 1, &nextTerm); l1, 1, &nextTerm);
...@@ -978,11 +933,6 @@ void switch_init(switch_state * r, tw_lp * lp) ...@@ -978,11 +933,6 @@ void switch_init(switch_state * r, tw_lp * lp)
r->switch_id, l1, LLU(nextTerm), r->num_cons - 1); r->switch_id, l1, LLU(nextTerm), r->num_cons - 1);
#endif #endif
count++;
if(count == (p->l1_set_size/2)) {
count = 0;
} else { } else {
r->con_per_lneigh = 2; r->con_per_lneigh = 2;
Markdown is supported
0% or .
Please register or to comment
