Commit de35ac6f authored by mubarak's avatar mubarak
Removing g_tw_lookahead additions from model-net
parent 70746264
...@@ -311,7 +311,7 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui ...@@ -311,7 +311,7 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui
terminal_message * msg; terminal_message * msg;
tw_lpid dest_nic_id; tw_lpid dest_nic_id;
char* tmp_ptr; char* tmp_ptr;
// printf("\n g_tw_lookahead default %f", g_tw_lookahead); // printf("\n g_tw_lookahead default %f src lp %d sender %d ", g_tw_lookahead, src_lp, sender->gid);
#if 0 #if 0
char lp_type_name[MAX_NAME_LENGTH], lp_group_name[MAX_NAME_LENGTH]; char lp_type_name[MAX_NAME_LENGTH], lp_group_name[MAX_NAME_LENGTH];
...@@ -323,7 +323,7 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui ...@@ -323,7 +323,7 @@ static tw_stime dragonfly_packet_event(char* category, tw_lpid final_dest_lp, ui
codes_mapping_get_lp_info(final_dest_lp, lp_group_name, &mapping_grp_id, &mapping_type_id, lp_type_name, &mapping_rep_id, &mapping_offset); codes_mapping_get_lp_info(final_dest_lp, lp_group_name, &mapping_grp_id, &mapping_type_id, lp_type_name, &mapping_rep_id, &mapping_offset);
codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM, mapping_rep_id, mapping_offset, &dest_nic_id); codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM, mapping_rep_id, mapping_offset, &dest_nic_id);
xfer_to_nic_time = g_tw_lookahead + codes_local_latency(sender); /* Throws an error of found last KP time > current event time otherwise when LPs of one type are placed together*/ xfer_to_nic_time = codes_local_latency(sender); /* Throws an error of found last KP time > current event time otherwise when LPs of one type are placed together*/
//printf("\n transfer in time %f %f ", xfer_to_nic_time+offset, tw_now(sender)); //printf("\n transfer in time %f %f ", xfer_to_nic_time+offset, tw_now(sender));
//e_new = tw_event_new(sender->gid, xfer_to_nic_time+offset, sender); //e_new = tw_event_new(sender->gid, xfer_to_nic_time+offset, sender);
//msg = tw_event_data(e_new); //msg = tw_event_data(e_new);
...@@ -718,7 +718,7 @@ void dragonfly_collective(char* category, int message_size, int remote_event_siz ...@@ -718,7 +718,7 @@ void dragonfly_collective(char* category, int message_size, int remote_event_siz
codes_mapping_get_lp_info(sender->gid, lp_group_name, &mapping_grp_id, &mapping_type_id, lp_type_name, &mapping_rep_id, &mapping_offset); codes_mapping_get_lp_info(sender->gid, lp_group_name, &mapping_grp_id, &mapping_type_id, lp_type_name, &mapping_rep_id, &mapping_offset);
codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM, mapping_rep_id, mapping_offset, &local_nic_id); codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM, mapping_rep_id, mapping_offset, &local_nic_id);
xfer_to_nic_time = g_tw_lookahead + codes_local_latency(sender); xfer_to_nic_time = codes_local_latency(sender);
e_new = model_net_method_event_new(local_nic_id, xfer_to_nic_time, e_new = model_net_method_event_new(local_nic_id, xfer_to_nic_time,
sender, DRAGONFLY, (void**)&msg, (void**)&tmp_ptr); sender, DRAGONFLY, (void**)&msg, (void**)&tmp_ptr);
...@@ -225,7 +225,7 @@ void handle_new_msg( ...@@ -225,7 +225,7 @@ void handle_new_msg(
if (ns->in_sched_loop == 0){ if (ns->in_sched_loop == 0){
b->c0 = 1; b->c0 = 1;
tw_event *e = codes_event_new(lp->gid, g_tw_lookahead + codes_local_latency(lp), lp); tw_event *e = codes_event_new(lp->gid, codes_local_latency(lp), lp);
model_net_wrap_msg *m = tw_event_data(e); model_net_wrap_msg *m = tw_event_data(e);
m->event_type = MN_BASE_SCHED_NEXT; m->event_type = MN_BASE_SCHED_NEXT;
m->magic = model_net_base_magic; m->magic = model_net_base_magic;
...@@ -265,7 +265,7 @@ void handle_sched_next( ...@@ -265,7 +265,7 @@ void handle_sched_next(
else { else {
tw_event *e = codes_event_new(lp->gid, tw_event *e = codes_event_new(lp->gid,
poffset+codes_local_latency(lp) + g_tw_lookahead, lp); poffset+codes_local_latency(lp), lp);
...@@ -178,7 +178,7 @@ static void model_net_event_impl_base( ...@@ -178,7 +178,7 @@ static void model_net_event_impl_base(
tw_lpid mn_lp = model_net_find_local_device(net_id, sender); tw_lpid mn_lp = model_net_find_local_device(net_id, sender);
tw_stime poffset = g_tw_lookahead + codes_local_latency(sender); tw_stime poffset = codes_local_latency(sender);
if (in_sequence){ if (in_sequence){
tw_stime tmp = mn_msg_offset; tw_stime tmp = mn_msg_offset;
mn_msg_offset += poffset; mn_msg_offset += poffset;
Markdown is supported
0%
or
Please register or to comment
