Commit dd66ea45 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Merge branch 'dfp-big-to-release' into 'master'
Dragonfly Plus and Related Work
See merge request !53
parents 34cd5129 5b1538bd
...@@ -13,6 +13,8 @@ EXTRA_PROGRAMS = ...@@ -13,6 +13,8 @@ EXTRA_PROGRAMS =
CLEANFILES = $(bin_SCRIPTS) CLEANFILES = $(bin_SCRIPTS)
EXTRA_DIST = EXTRA_DIST =
BUILT_SOURCES = BUILT_SOURCES =
AM_LDFLAGS =
# pkgconfig files # pkgconfig files
pkgconfigdir = $(libdir)/pkgconfig pkgconfigdir = $(libdir)/pkgconfig
...@@ -57,6 +59,12 @@ AM_CPPFLAGS += ${RECORDER_CPPFLAGS} ...@@ -57,6 +59,12 @@ AM_CPPFLAGS += ${RECORDER_CPPFLAGS}
src_libcodes_la_SOURCES += src/workload/methods/codes-recorder-io-wrkld.c src_libcodes_la_SOURCES += src/workload/methods/codes-recorder-io-wrkld.c
endif endif
if USE_ONLINE
AM_CPPFLAGS += ${ARGOBOTS_CFLAGS} ${SWM_CFLAGS} -DUSE_ONLINE=1
LDADD += ${SWM_LIBS} ${ARGOBOTS_LIBS}
src_libcodes_la_SOURCES += src/workload/methods/codes-online-comm-wrkld.C
endif
if USE_DUMPI if USE_DUMPI
AM_CPPFLAGS += ${DUMPI_CFLAGS} -DUSE_DUMPI=1 AM_CPPFLAGS += ${DUMPI_CFLAGS} -DUSE_DUMPI=1
src_libcodes_la_SOURCES += src/workload/methods/codes-dumpi-trace-nw-wrkld.c src_libcodes_la_SOURCES += src/workload/methods/codes-dumpi-trace-nw-wrkld.c
...@@ -19,6 +19,9 @@ extern "C" { ...@@ -19,6 +19,9 @@ extern "C" {
#include <ross.h> #include <ross.h>
#include "configuration.h" #include "configuration.h"
#ifdef USE_ONLINE
#include <abt.h>
#endif
#define MAX_NAME_LENGTH_WKLD 512 #define MAX_NAME_LENGTH_WKLD 512
/* implementations included with codes */ /* implementations included with codes */
...@@ -30,6 +33,7 @@ typedef struct recorder_params recorder_params; ...@@ -30,6 +33,7 @@ typedef struct recorder_params recorder_params;
/* struct to hold the actual data from a single MPI event*/ /* struct to hold the actual data from a single MPI event*/
typedef struct dumpi_trace_params dumpi_trace_params; typedef struct dumpi_trace_params dumpi_trace_params;
typedef struct checkpoint_wrkld_params checkpoint_wrkld_params; typedef struct checkpoint_wrkld_params checkpoint_wrkld_params;
typedef struct online_comm_params online_comm_params;
struct iomock_params struct iomock_params
...@@ -77,6 +81,11 @@ struct dumpi_trace_params { ...@@ -77,6 +81,11 @@ struct dumpi_trace_params {
#endif #endif
struct online_comm_params {
char workload_name[MAX_NAME_LENGTH_WKLD];
char file_path[MAX_NAME_LENGTH_WKLD];
int nprocs;
struct checkpoint_wrkld_params struct checkpoint_wrkld_params
int nprocs; /* number of workload processes */ int nprocs; /* number of workload processes */
...@@ -235,14 +244,14 @@ struct codes_workload_op ...@@ -235,14 +244,14 @@ struct codes_workload_op
} collective; } collective;
struct { struct {
int count; int count;
unsigned int* req_ids; uint32_t* req_ids;
} waits; } waits;
struct { struct {
unsigned int req_id; uint32_t req_id;
} wait; } wait;
struct struct
free; free;
}u; }u;
...@@ -323,6 +332,13 @@ int codes_workload_get_rank_cnt( ...@@ -323,6 +332,13 @@ int codes_workload_get_rank_cnt(
const char* params, const char* params,
int app_id); int app_id);
/* Finalize the workload */
int codes_workload_finalize(
const char* type,
const char* params,
int app_id,
int rank);
/* for debugging/logging: print an individual operation to the specified file */ /* for debugging/logging: print an individual operation to the specified file */
void codes_workload_print_op( void codes_workload_print_op(
FILE *f, FILE *f,
...@@ -346,6 +362,7 @@ struct codes_workload_method ...@@ -346,6 +362,7 @@ struct codes_workload_method
void (*codes_workload_get_next)(int app_id, int rank, struct codes_workload_op *op); void (*codes_workload_get_next)(int app_id, int rank, struct codes_workload_op *op);
void (*codes_workload_get_next_rc2)(int app_id, int rank); void (*codes_workload_get_next_rc2)(int app_id, int rank);
int (*codes_workload_get_rank_cnt)(const char* params, int app_id); int (*codes_workload_get_rank_cnt)(const char* params, int app_id);
int (*codes_workload_finalize)(const char* params, int app_id, int rank);
/* added for get all read or write time */ /* added for get all read or write time */
int (*codes_workload_get_time)(const char * params, int app_id, int rank, double *read_time, double *write_time, int64_t *read_bytes, int64_t *written_bytes); int (*codes_workload_get_time)(const char * params, int app_id, int rank, double *read_time, double *write_time, int64_t *read_bytes, int64_t *written_bytes);
This diff is collapsed.
...@@ -23,6 +23,7 @@ extern "C" { ...@@ -23,6 +23,7 @@ extern "C" {
#include "model-net-sched.h" #include "model-net-sched.h"
#include "net/dragonfly.h" #include "net/dragonfly.h"
#include "net/dragonfly-custom.h" #include "net/dragonfly-custom.h"
#include "net/dragonfly-plus.h"
#include "net/slimfly.h" #include "net/slimfly.h"
#include "net/fattree.h" #include "net/fattree.h"
#include "net/loggp.h" #include "net/loggp.h"
...@@ -131,6 +132,7 @@ typedef struct model_net_wrap_msg { ...@@ -131,6 +132,7 @@ typedef struct model_net_wrap_msg {
model_net_base_msg m_base; // base lp model_net_base_msg m_base; // base lp
terminal_message m_dfly; // dragonfly terminal_message m_dfly; // dragonfly
terminal_custom_message m_custom_dfly; // dragonfly-custom terminal_custom_message m_custom_dfly; // dragonfly-custom
terminal_plus_message m_dfly_plus; // dragonfly plus
slim_terminal_message m_slim; // slimfly slim_terminal_message m_slim; // slimfly
fattree_message m_fat; // fattree fattree_message m_fat; // fattree
loggp_message m_loggp; // loggp loggp_message m_loggp; // loggp
...@@ -74,6 +74,8 @@ typedef struct mn_stats mn_stats; ...@@ -74,6 +74,8 @@ typedef struct mn_stats mn_stats;
X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\ X(LOGGP, "modelnet_loggp", "loggp", &loggp_method)\
X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\ X(EXPRESS_MESH, "modelnet_express_mesh", "express_mesh", &express_mesh_method)\
X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\ X(EXPRESS_MESH_ROUTER, "modelnet_express_mesh_router", "express_mesh_router", &express_mesh_router_method)\
X(DRAGONFLY_PLUS, "modelnet_dragonfly_plus", "dragonfly_plus", &dragonfly_plus_method)\
X(DRAGONFLY_PLUS_ROUTER, "modelnet_dragonfly_plus_router", "dragonfly_plus_router", &dragonfly_plus_router_method)\
X(MAX_NETS, NULL, NULL, NULL) X(MAX_NETS, NULL, NULL, NULL)
#define X(a,b,c,d) a, #define X(a,b,c,d) a,
* Copyright (C) 2014 University of Chicago.
* See COPYRIGHT notice in top-level directory.
#ifndef DRAGONFLY_PLUS_H
#define DRAGONFLY_PLUS_H
#ifdef __cplusplus
extern "C" {
#endif
#include <ross.h>
typedef struct terminal_plus_message terminal_plus_message;
/* this message is used for both dragonfly compute nodes and routers */
/* magic number */
int magic;
/* flit travel start time*/
tw_stime travel_start_time;
/* packet ID of the flit */
unsigned long long packet_ID;
/* event type of the flit */
short type;
/* category: comes from codes */
char category[CATEGORY_NAME_MAX];
/* store category hash in the event */
uint32_t category_hash;
/* final destination LP ID, this comes from codes can be a server or any other LP type*/
tw_lpid final_dest_gid;
/*sending LP ID from CODES, can be a server or any other LP type */
tw_lpid sender_lp;
tw_lpid sender_mn_lp; // source modelnet id
/* destination terminal ID of the dragonfly */
tw_lpid dest_terminal_id;
/* source terminal ID of the dragonfly */
unsigned int src_terminal_id;
/* message originating router id. MM: Can we calculate it through
* sender_mn_lp??*/
unsigned int origin_router_id;
/* number of hops traversed by the packet */
short my_N_hop;
short my_l_hop, my_g_hop;
short saved_channel;
short saved_vc;
int next_stop;
short nonmin_done;
/* Intermediate LP ID from which this message is coming */
unsigned int intm_lp_id;
/* last hop of the message, can be a terminal, local router or global router */
short last_hop;
/* For routing */
int saved_src_dest;
int saved_src_chan;
//DFP Specific Routing
int intm_rtr_id; //Router ID of the intermediate router for nonminimal routes
int intm_group_id; //Group ID of the intermediate router for nonminimal routes
short dfp_upward_channel_flag;
int dfp_dest_terminal_id; //this is the terminal id in the dfp network in range [0-total_num_terminals)
uint32_t chunk_id;
uint32_t packet_size;
uint32_t message_id;
uint32_t total_size;
int remote_event_size_bytes;
int local_event_size_bytes;
// For buffer message
short vc_index;
int output_chan;
model_net_event_return event_rc;
int is_pull;
uint32_t pull_size;
/* for reverse computation */
int path_type;
tw_stime saved_available_time;
tw_stime saved_avg_time;
tw_stime saved_rcv_time;
tw_stime saved_busy_time;
tw_stime saved_total_time;
tw_stime saved_sample_time;
tw_stime msg_start_time;
#ifdef __cplusplus
#endif
#endif /* end of include guard: DRAGONFLY_H */
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
...@@ -5,6 +5,10 @@ AC_PREREQ([2.67]) ...@@ -5,6 +5,10 @@ AC_PREREQ([2.67])
AC_INIT([codes], [0.6.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/]) AC_INIT([codes], [0.6.0], [http://trac.mcs.anl.gov/projects/codes/newticket],[],[http://www.mcs.anl.gov/projects/codes/])
LT_INIT LT_INIT
#WRAP SOME OPTION AROUND THIS - IT'S NOT REQUIRED FOR 99% OF CODES
AX_BOOST_BASE([1.66])
AC_CANONICAL_TARGET AC_CANONICAL_TARGET
AC_CANONICAL_SYSTEM AC_CANONICAL_SYSTEM
AC_CANONICAL_HOST AC_CANONICAL_HOST
...@@ -26,6 +30,7 @@ AC_PROG_CC ...@@ -26,6 +30,7 @@ AC_PROG_CC
AM_PROG_CC_C_O AM_PROG_CC_C_O
AC_PROG_CXX AC_PROG_CXX
AC_PROG_CXXCPP AC_PROG_CXXCPP
AX_CXX_COMPILE_STDCXX(11, noext, mandatory)
AC_PROG_RANLIB AC_PROG_RANLIB
PKG_PROG_PKG_CONFIG PKG_PROG_PKG_CONFIG
...@@ -104,6 +109,24 @@ fi ...@@ -104,6 +109,24 @@ fi
AM_CONDITIONAL(USE_DARSHAN, [test "x${use_darshan}" = xyes]) AM_CONDITIONAL(USE_DARSHAN, [test "x${use_darshan}" = xyes])
# check for Argobots
AC_ARG_WITH([online],[AS_HELP_STRING([--with-online@<:@=DIR@:>@],
[Build with the online workloads and argobots support])],
[use_online=yes],[use_online=no])
if test "x${use_online}" != "xno" ; then
AM_CONDITIONAL(USE_ONLINE, true)
PKG_CHECK_MODULES_STATIC([ARGOBOTS], [argobots], [],
[AC_MSG_ERROR([Could not find working argobots installation via pkg-config])])
PKG_CHECK_MODULES_STATIC([SWM], [swm], [],
[AC_MSG_ERROR([Could not find working swm installation via pkg-config])])
PKG_CHECK_VAR([SWM_DATAROOTDIR], [swm], [datarootdir], [],
[AC_MSG_ERROR[Could not find shared directory in SWM]])
AC_DEFINE_UNQUOTED([SWM_DATAROOTDIR], ["$SWM_DATAROOTDIR"], [if using json
data files])
else
AM_CONDITIONAL(USE_ONLINE, false)
fi
# check for Recorder # check for Recorder
AM_CONDITIONAL(USE_RECORDER, true) AM_CONDITIONAL(USE_RECORDER, true)
RECORDER_CPPFLAGS="-DUSE_RECORDER=1" RECORDER_CPPFLAGS="-DUSE_RECORDER=1"
# https://www.gnu.org/software/autoconf-archive/ax_boost_base.html
# SYNOPSIS
# AX_BOOST_BASE([MINIMUM-VERSION], [ACTION-IF-FOUND], [ACTION-IF-NOT-FOUND])
# DESCRIPTION
# Test for the Boost C++ libraries of a particular version (or newer)
# If no path to the installed boost library is given the macro searchs
# under /usr, /usr/local, /opt and /opt/local and evaluates the
# $BOOST_ROOT environment variable. Further documentation is available at
# <http://randspringer.de/boost/index.html>.
# This macro calls:
# AC_SUBST(BOOST_CPPFLAGS) / AC_SUBST(BOOST_LDFLAGS)
# And sets:
# HAVE_BOOST
# LICENSE
# Copyright (c) 2008 Thomas Porschberg <thomas@randspringer.de>
# Copyright (c) 2009 Peter Adolphs
# Copying and distribution of this file, with or without modification, are
# permitted in any medium without royalty provided the copyright notice
# and this notice are preserved. This file is offered as-is, without any
# warranty.
#serial 44
# example boost program (need to pass version)
m4_define([_AX_BOOST_BASE_PROGRAM],
[AC_LANG_PROGRAM([[
#include <boost/version.hpp>
(void) ((void)sizeof(char[1 - 2*!!((BOOST_VERSION) < ($1))]));
AC_DEFUN([AX_BOOST_BASE],
AC_ARG_WITH([boost],
[AS_HELP_STRING([--with-boost@<:@=ARG@:>@],
[use Boost library from a standard location (ARG=yes),
from the specified location (ARG=<path>),
or disable it (ARG=no)
@<:@ARG=yes@:>@ ])],
AS_CASE([$withval],
[no],[want_boost="no";_AX_BOOST_BASE_boost_path=""],
[yes],[want_boost="yes";_AX_BOOST_BASE_boost_path=""],
[want_boost="yes";_AX_BOOST_BASE_boost_path="$withval"])
[want_boost="yes"])
AC_ARG_WITH([boost-libdir],
[AS_HELP_STRING([--with-boost-libdir=LIB_DIR],
[Force given directory for boost libraries.
Note that this will override library path detection,
so use this parameter only if default library detection fails
and you know exactly where your boost libraries are located.])],
AS_IF([test -d "$withval"],
[_AX_BOOST_BASE_boost_lib_path="$withval"],
[AC_MSG_ERROR([--with-boost-libdir expected directory name])])
[_AX_BOOST_BASE_boost_lib_path=""])
BOOST_LDFLAGS=""
BOOST_CPPFLAGS=""
AS_IF([test "x$want_boost" = "xyes"],
[_AX_BOOST_BASE_RUNDETECT([$1],[$2],[$3])])
# convert a version string in $2 to numeric and affect to polymorphic var $1
AC_DEFUN([_AX_BOOST_BASE_TONUMERICVERSION],[
AS_IF([test "x$2" = "x"],[_AX_BOOST_BASE_TONUMERICVERSION_req="1.20.0"],[_AX_BOOST_BASE_TONUMERICVERSION_req="$2"])
_AX_BOOST_BASE_TONUMERICVERSION_req_shorten=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '\([[0-9]]*\.[[0-9]]*\)'`
_AX_BOOST_BASE_TONUMERICVERSION_req_major=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '\([[0-9]]*\)'`
AS_IF([test "x$_AX_BOOST_BASE_TONUMERICVERSION_req_major" = "x"],
[AC_MSG_ERROR([You should at least specify libboost major version])])
_AX_BOOST_BASE_TONUMERICVERSION_req_minor=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '[[0-9]]*\.\([[0-9]]*\)'`
AS_IF([test "x$_AX_BOOST_BASE_TONUMERICVERSION_req_minor" = "x"],
[_AX_BOOST_BASE_TONUMERICVERSION_req_minor="0"])
_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'`
AS_IF([test "X$_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor" = "X"],
[_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor="0"])
_AX_BOOST_BASE_TONUMERICVERSION_RET=`expr $_AX_BOOST_BASE_TONUMERICVERSION_req_major \* 100000 \+ $_AX_BOOST_BASE_TONUMERICVERSION_req_minor \* 100 \+ $_AX_BOOST_BASE_TONUMERICVERSION_req_sub_minor`
AS_VAR_SET($1,$_AX_BOOST_BASE_TONUMERICVERSION_RET)
dnl Run the detection of boost should be run only if $want_boost
AC_DEFUN([_AX_BOOST_BASE_RUNDETECT],[
_AX_BOOST_BASE_TONUMERICVERSION(WANT_BOOST_VERSION,[$1])
succeeded=no
AC_REQUIRE([AC_CANONICAL_HOST])
dnl On 64-bit systems check for system libraries in both lib64 and lib.
dnl The former is specified by FHS, but e.g. Debian does not adhere to
dnl this (as it rises problems for generic multi-arch support).
dnl The last entry in the list is chosen by default when no libraries
dnl are found, e.g. when only header-only libraries are installed!
AS_CASE([${host_cpu}],
[x86_64],[libsubdirs="lib64 libx32 lib lib64"],
[ppc64|s390x|sparc64|aarch64|ppc64le|riscv64],[libsubdirs="lib64 lib lib64"],
[libsubdirs="lib"]
dnl allow for real multi-arch paths e.g. /usr/lib/x86_64-linux-gnu. Give
dnl them priority over the other paths since, if libs are found there, they
dnl are almost assuredly the ones desired.
[i?86],[multiarch_libsubdir="lib/i386-${host_os}"],
[multiarch_libsubdir="lib/${host_cpu}-${host_os}"]
dnl first we check the system location for boost libraries
dnl this location ist chosen if boost libraries are installed with the --layout=system option
dnl or if you install boost with RPM
AS_IF([test "x$_AX_BOOST_BASE_boost_path" != "x"],[
AC_MSG_CHECKING([for boostlib >= $1 ($WANT_BOOST_VERSION) includes in "$_AX_BOOST_BASE_boost_path/include"])
AS_IF([test -d "$_AX_BOOST_BASE_boost_path/include" && test -r "$_AX_BOOST_BASE_boost_path/include"],[
AC_MSG_RESULT([yes])
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path/include"
for _AX_BOOST_BASE_boost_path_tmp in $multiarch_libsubdir $libsubdirs; do
AC_MSG_CHECKING([for boostlib >= $1 ($WANT_BOOST_VERSION) lib path in "$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp"])
AS_IF([test -d "$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp" && test -r "$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp" ],[
BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_path/$_AX_BOOST_BASE_boost_path_tmp";
break;
[AC_MSG_RESULT([no])])
done],[
if test X"$cross_compiling" = Xyes; then
search_libsubdirs=$multiarch_libsubdir
else
search_libsubdirs="$multiarch_libsubdir $libsubdirs"
fi
for _AX_BOOST_BASE_boost_path_tmp in /usr /usr/local /opt /opt/local ; do
if test -d "$_AX_BOOST_BASE_boost_path_tmp/include/boost" && test -r "$_AX_BOOST_BASE_boost_path_tmp/include/boost" ; then
for libsubdir in $search_libsubdirs ; do
if ls "$_AX_BOOST_BASE_boost_path_tmp/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_path_tmp/$libsubdir"
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path_tmp/include"
break;
fi
done
dnl overwrite ld flags if we have required special directory with
dnl --with-boost-libdir parameter
AS_IF([test "x$_AX_BOOST_BASE_boost_lib_path" != "x"],
[BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_lib_path"])
AC_MSG_CHECKING([for boostlib >= $1 ($WANT_BOOST_VERSION)])
CPPFLAGS_SAVED="$CPPFLAGS"
CPPFLAGS="$CPPFLAGS $BOOST_CPPFLAGS"
export CPPFLAGS
LDFLAGS_SAVED="$LDFLAGS"
LDFLAGS="$LDFLAGS $BOOST_LDFLAGS"
export LDFLAGS
AC_REQUIRE([AC_PROG_CXX])
AC_LANG_PUSH(C++)
AC_COMPILE_IFELSE([_AX_BOOST_BASE_PROGRAM($WANT_BOOST_VERSION)],[
AC_MSG_RESULT(yes)
succeeded=yes
found_system=yes
AC_LANG_POP([C++])
dnl if we found no boost with system layout we search for boost libraries
dnl built and installed without the --layout=system option or for a staged(not installed) version
if test "x$succeeded" != "xyes" ; then
CPPFLAGS="$CPPFLAGS_SAVED"
LDFLAGS="$LDFLAGS_SAVED"
BOOST_CPPFLAGS=
if test -z "$_AX_BOOST_BASE_boost_lib_path" ; then
BOOST_LDFLAGS=
fi
_version=0
if test -n "$_AX_BOOST_BASE_boost_path" ; then
if test -d "$_AX_BOOST_BASE_boost_path" && test -r "$_AX_BOOST_BASE_boost_path"; then
for i in `ls -d $_AX_BOOST_BASE_boost_path/include/boost-* 2>/dev/null`; do
_version_tmp=`echo $i | sed "s#$_AX_BOOST_BASE_boost_path##" | sed 's/\/include\/boost-//' | sed 's/_/./'`
V_CHECK=`expr $_version_tmp \> $_version`
if test "x$V_CHECK" = "x1" ; then
_version=$_version_tmp
fi
VERSION_UNDERSCORE=`echo $_version | sed 's/\./_/'`
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path/include/boost-$VERSION_UNDERSCORE"
done
dnl if nothing found search for layout used in Windows distributions
if test -z "$BOOST_CPPFLAGS"; then
if test -d "$_AX_BOOST_BASE_boost_path/boost" && test -r "$_AX_BOOST_BASE_boost_path/boost"; then
BOOST_CPPFLAGS="-I$_AX_BOOST_BASE_boost_path"
fi
fi
dnl if we found something and BOOST_LDFLAGS was unset before
dnl (because "$_AX_BOOST_BASE_boost_lib_path" = ""), set it here.
if test -n "$BOOST_CPPFLAGS" && test -z "$BOOST_LDFLAGS"; then
for libsubdir in $libsubdirs ; do
if ls "$_AX_BOOST_BASE_boost_path/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
BOOST_LDFLAGS="-L$_AX_BOOST_BASE_boost_path/$libsubdir"
fi
fi
else
if test "x$cross_compiling" != "xyes" ; then
for _AX_BOOST_BASE_boost_path in /usr /usr/local /opt /opt/local ; do
if test -d "$_AX_BOOST_BASE_boost_path" && test -r "$_AX_BOOST_BASE_boost_path" ; then
best_path=$_AX_BOOST_BASE_boost_path
fi
done
fi
done
BOOST_CPPFLAGS="-I$best_path/include/boost-$VERSION_UNDERSCORE"
if ls "$best_path/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
BOOST_LDFLAGS="-L$best_path/$libsubdir"
fi
fi
if test -n "$BOOST_ROOT" ; then
if ls "$BOOST_ROOT/stage/$libsubdir/libboost_"* >/dev/null 2>&1 ; then break; fi
done
if test -d "$BOOST_ROOT" && test -r "$BOOST_ROOT" && test -d "$BOOST_ROOT/stage/$libsubdir" && test -r "$BOOST_ROOT/stage/$libsubdir"; then
version_dir=`expr //$BOOST_ROOT : '.*/\(.*\)'`
stage_version=`echo $version_dir | sed 's/boost_//' | sed 's/_/./g'`
stage_version_shorten=`expr $stage_version : '\([[0-9]]*\.[[0-9]]*\)'`
V_CHECK=`expr $stage_version_shorten \>\= $_version`
if test "x$V_CHECK" = "x1" && test -z "$_AX_BOOST_BASE_boost_lib_path" ; then
AC_MSG_NOTICE(We will use a staged boost library from $BOOST_ROOT)
BOOST_CPPFLAGS="-I$BOOST_ROOT"
BOOST_LDFLAGS="-L$BOOST_ROOT/stage/$libsubdir"
fi
fi
fi
fi
export CPPFLAGS
export LDFLAGS
AC_LANG_PUSH(C++)
AC_MSG_RESULT(yes)
succeeded=yes
found_system=yes
AC_LANG_POP([C++])
fi
if test "x$_version" = "x0" ; then
AC_MSG_NOTICE([[We could not detect the boost libraries (version $1 or higher). If you have a staged boost library (still not installed) please specify \$BOOST_ROOT in your environment and do not give a PATH to --with-boost option. If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.]])
else
AC_MSG_NOTICE([Your boost libraries seems to old (version $_version).])
fi
# execute ACTION-IF-NOT-FOUND (if present):
ifelse([$3], , :, [$3])
else
AC_DEFINE(HAVE_BOOST,,[define if the Boost library is available])
# execute ACTION-IF-FOUND (if present):
ifelse([$2], , :, [$2])
fi
