Commit dd17ce70 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
DFDally: Add Stalled packet per port counter
parent 67f976e6
...@@ -415,6 +415,8 @@ struct router_state ...@@ -415,6 +415,8 @@ struct router_state
tw_stime* busy_time; tw_stime* busy_time;
tw_stime* busy_time_sample; tw_stime* busy_time_sample;
unsigned long* stalled_chunks; //Counter for when a packet is put into queued messages instead of routing
terminal_dally_message_list ***pending_msgs; terminal_dally_message_list ***pending_msgs;
terminal_dally_message_list ***pending_msgs_tail; terminal_dally_message_list ***pending_msgs_tail;
terminal_dally_message_list ***queued_msgs; terminal_dally_message_list ***queued_msgs;
...@@ -1538,7 +1540,9 @@ void router_dally_setup(router_state * r, tw_lp * lp) ...@@ -1538,7 +1540,9 @@ void router_dally_setup(router_state * r, tw_lp * lp)
r->link_traffic_sample = (int64_t*)calloc(p->radix, sizeof(int64_t)); r->link_traffic_sample = (int64_t*)calloc(p->radix, sizeof(int64_t));
r->cur_hist_num = (int*)calloc(p->radix, sizeof(int)); r->cur_hist_num = (int*)calloc(p->radix, sizeof(int));
r->prev_hist_num = (int*)calloc(p->radix, sizeof(int)); r->prev_hist_num = (int*)calloc(p->radix, sizeof(int));
r->stalled_chunks = (unsigned long*)calloc(p->radix, sizeof(unsigned long));
r->last_sent_chan = (int*) calloc(p->num_router_rows, sizeof(int)); r->last_sent_chan = (int*) calloc(p->num_router_rows, sizeof(int));
r->vc_occupancy = (int**)calloc(p->radix , sizeof(int*)); r->vc_occupancy = (int**)calloc(p->radix , sizeof(int*));
r->in_send_loop = (int*)calloc(p->radix, sizeof(int)); r->in_send_loop = (int*)calloc(p->radix, sizeof(int));
...@@ -1781,13 +1785,14 @@ static void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_dally_me ...@@ -1781,13 +1785,14 @@ static void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_dally_me
if(bf->c5) { if(bf->c5) {
s->in_send_loop = 0; s->in_send_loop = 0;
if(bf->c11) {
if (bf->c11) {
s->issueIdle = 0; s->issueIdle = 0;
if(bf->c8)
{ if(bf->c8) {
s->last_buf_full = msg->saved_busy_time; s->last_buf_full = msg->saved_busy_time;
struct mn_stats* stat; struct mn_stats* stat;
stat = model_net_find_stats(msg->category, s->dragonfly_stats_array); stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
stat->send_count--; stat->send_count--;
...@@ -3149,11 +3154,11 @@ dragonfly_dally_terminal_final( terminal_state * s, ...@@ -3149,11 +3154,11 @@ dragonfly_dally_terminal_final( terminal_state * s,
if(s->terminal_id == 0) if(s->terminal_id == 0)
written += sprintf(s->output_buf + written, "# Format <source_id> <source_type> <dest_id> < dest_type> <link_type> <link_traffic> <link_saturation>"); written += sprintf(s->output_buf + written, "# Format <source_id> <source_type> <dest_id> < dest_type> <link_type> <link_traffic> <link_saturation> <stalled_chunks>");
// fprintf(fp, "# Format <LP id> <Terminal ID> <Total Data Size> <Avg packet latency> <# Flits/Packets finished> <Avg hops> <Busy Time> <Max packet Latency> <Min packet Latency >\n"); // fprintf(fp, "# Format <LP id> <Terminal ID> <Total Data Size> <Avg packet latency> <# Flits/Packets finished> <Avg hops> <Busy Time> <Max packet Latency> <Min packet Latency >\n");
written += sprintf(s->output_buf + written, "\n%u %s %llu %s %s %llu %lf", written += sprintf(s->output_buf + written, "\n%u %s %llu %s %s %llu %lf %d",
s->terminal_id, "T", s->router_id, "R", "CN", LLU(s->total_msg_size), s->busy_time); s->terminal_id, "T", s->router_id, "R", "CN", LLU(s->total_msg_size), s->busy_time, -1); //note that terminals don't have stalled chuncks because of model net scheduling only gives a terminal what it can handle (-1 to show N/A)
lp_io_write(lp->gid, (char*)"dragonfly-link-stats", written, s->output_buf); lp_io_write(lp->gid, (char*)"dragonfly-link-stats", written, s->output_buf);
...@@ -3224,36 +3229,40 @@ void dragonfly_dally_router_final(router_state * s, ...@@ -3224,36 +3229,40 @@ void dragonfly_dally_router_final(router_state * s,
if(d != src_rel_id) if(d != src_rel_id)
int dest_ab_id = local_grp_id * p->num_routers + d; int dest_ab_id = local_grp_id * p->num_routers + d;
written += sprintf(s->output_buf + written, "\n%d %s %d %s %s %llu %lf", written += sprintf(s->output_buf + written, "\n%d %s %d %s %s %llu %lf %lu",
s->router_id, s->router_id,
"R", "R",
dest_ab_id, dest_ab_id,
"R", "R",
"L", "L",
s->link_traffic[d], s->link_traffic[d],
s->busy_time[d]); s->busy_time[d],
s->stalled_chunks[d]);
map< int, vector<bLink> > &curMap = interGroupLinks[s->router_id];
map< int, vector<bLink> >::iterator it = curMap.begin(); map< int, vector<bLink> > &curMap = interGroupLinks[s->router_id];
for(; it != curMap.end(); it++) map< int, vector<bLink> >::iterator it = curMap.begin();
{ for(; it != curMap.end(); it++)
/* TODO: Works only for single global connections right now. Make it functional {
* for a 2-D dragonfly. */ /* TODO: Works only for single global connections right now. Make it functional
for(int l = 0; l < it->second.size(); l++) { * for a 2-D dragonfly. */
int dest_rtr_id = it->second[l].dest; for(int l = 0; l < it->second.size(); l++) {
int offset = it->second[l].offset; int dest_rtr_id = it->second[l].dest;
assert(offset >= 0 && offset < p->num_global_channels); int offset = it->second[l].offset;
written += sprintf(s->output_buf + written, "\n%d %s %d %s %s %llu %lf", assert(offset >= 0 && offset < p->num_global_channels);
s->router_id, written += sprintf(s->output_buf + written, "\n%d %s %d %s %s %llu %lf %lu",
"R", s->router_id,
dest_rtr_id, "R",
"R", dest_rtr_id,
"G", "R",
s->link_traffic[offset], "G",
s->busy_time[offset]); s->link_traffic[offset],
} s->busy_time[offset],
s->stalled_chunks[offset]);
sprintf(s->output_buf + written, "\n"); sprintf(s->output_buf + written, "\n");
...@@ -4025,6 +4034,7 @@ static void router_packet_receive_rc(router_state * s, ...@@ -4025,6 +4034,7 @@ static void router_packet_receive_rc(router_state * s,
if(bf->c4) { if(bf->c4) {
s->stalled_chunks[output_port]--;
if(bf->c22) if(bf->c22)
s->last_buf_full[output_port] = msg->saved_busy_time; s->last_buf_full[output_port] = msg->saved_busy_time;
...@@ -4299,6 +4309,7 @@ if(cur_chunk->msg.path_type == NON_MINIMAL) ...@@ -4299,6 +4309,7 @@ if(cur_chunk->msg.path_type == NON_MINIMAL)
} else { } else {
bf->c4 = 1; bf->c4 = 1;
s->stalled_chunks[output_port]++;
cur_chunk->msg.saved_vc = msg->vc_index; cur_chunk->msg.saved_vc = msg->vc_index;
cur_chunk->msg.saved_channel = msg->output_chan; cur_chunk->msg.saved_channel = msg->output_chan;
assert(output_chan < s->params->num_vcs && output_port < s->params->radix); assert(output_chan < s->params->num_vcs && output_port < s->params->radix);
Markdown is supported
0% or .
Please register or to comment
