Commit d9e32252 authored by Philip Carns's avatar Philip Carns
Browse files
updates for better model agreement
parent df83061f
...@@ -329,7 +329,7 @@ static void handle_msg_ready_event( ...@@ -329,7 +329,7 @@ static void handle_msg_ready_event(
param = find_params(m->net_msg_size_bytes); param = find_params(m->net_msg_size_bytes);
if(m->net_msg_size_bytes <= SMALL_MSG_LIMIT) if(m->net_msg_size_bytes < SMALL_MSG_LIMIT)
max = param->g; max = param->g;
if(max < param->o_r) if(max < param->o_r)
...@@ -431,7 +431,7 @@ static void handle_msg_start_event( ...@@ -431,7 +431,7 @@ static void handle_msg_start_event(
total_event_size = loggp_get_msg_sz() + m->event_size_bytes + m->local_event_size_bytes; total_event_size = loggp_get_msg_sz() + m->event_size_bytes + m->local_event_size_bytes;
if(max < param->o_s) if(max < param->o_s)
...@@ -640,14 +640,18 @@ static struct param_table_entry* find_params(int msg_size) ...@@ -640,14 +640,18 @@ static struct param_table_entry* find_params(int msg_size)
for(i=0; i<param_table_size; i++) for(i=0; i<param_table_size; i++)
if(param_table[i].size > msg_size) if(param_table[i].size >= msg_size)
if(i > 0)
i--;
break; break;
/* TODO: THIS IS A HACK */
/* need to understand why the o_s and o_r values don't work as
* expected...
param_table[i].o_s = 0;
param_table[i].o_r = 0;
return(&param_table[i]); return(&param_table[i]);
Markdown is supported
0% or .
Please register or to comment
