Commit d8f31853 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
WIP: Adding functions for cortex custom-dragonfly topology
parent 03ebb0ff
...@@ -3225,10 +3225,56 @@ struct model_net_method dragonfly_custom_router_method = ...@@ -3225,10 +3225,56 @@ struct model_net_method dragonfly_custom_router_method =
#ifdef ENABLE_CORTEX #ifdef ENABLE_CORTEX
static double dragonfly_custom_get_router_link_bandwidth(void* topo, router_id_t r1, router_id_t r2) { static double dragonfly_custom_get_router_link_bandwidth(void* topo, router_id_t r1, router_id_t r2) {
// TODO // TODO: handle this function for multiple cables between the routers.
// Right now it returns the bandwidth of a single cable only.
// Given two router ids r1 and r2, this function should return the bandwidth (double) // Given two router ids r1 and r2, this function should return the bandwidth (double)
// of the link between the two routers, or 0 of such a link does not exist in the topology. // of the link between the two routers, or 0 of such a link does not exist in the topology.
// The function should return -1 if one of the router id is invalid. // The function should return -1 if one of the router id is invalid.
const dragonfly_param * params = &all_params[num_params-1];
if(!params)
return -1.0;
if(r1 > params->total_routers || r2 > params->total_routers)
return -1.0;
if(r1 < 0 || r2 < 0)
return -1.0;
int gid_r1 = r1 / params->num_routers;
int gid_r2 = r2 / params->num_routers;
if(gid_r1 == gid_r2)
int lid_r1 = r1 % params->num_routers;
int lid_r2 = r2 % params->num_routers;
/* The connection will be there if the router is in the same row or
* same column */
int src_row_r1 = lid_r1 / params->num_router_cols;
int src_row_r2 = lid_r2 / params->num_router_cols;
int src_col_r1 = lid_r1 % params->num_router_cols;
int src_col_r2 = lid_r2 % params->num_router_cols;
if(src_row_r1 == src_row_r2 || src_col_r1 == src_col_r2)
return params->local_bandwidth;
else
return 0.0;
else
vector<blink> &curVec = interGroupLinks[r1][gid_r2];
vector<blink>::iterator it = curVec.begin();
for(; it != curVec.end(); it++)
blink bl = *it;
if(bl.dest == r2)
return params->global_bandwidth;
return 0.0;
return -1.0; return -1.0;
...@@ -3237,7 +3283,14 @@ static double dragonfly_custom_get_compute_node_bandwidth(void* topo, cn_id_t no ...@@ -3237,7 +3283,14 @@ static double dragonfly_custom_get_compute_node_bandwidth(void* topo, cn_id_t no
// Given the id of a compute node, this function should return the bandwidth of the // Given the id of a compute node, this function should return the bandwidth of the
// link connecting this compute node to its router. // link connecting this compute node to its router.
// The function should return -1 if the compute node id is invalid. // The function should return -1 if the compute node id is invalid.
if(!params)
if(node < 0 || node >= params->total_terminals)
return -1.0;
return params->cn_bandwidth;
static int dragonfly_custom_get_router_neighbor_count(void* topo, router_id_t r) { static int dragonfly_custom_get_router_neighbor_count(void* topo, router_id_t r) {
...@@ -3245,14 +3298,62 @@ static int dragonfly_custom_get_router_neighbor_count(void* topo, router_id_t r) ...@@ -3245,14 +3298,62 @@ static int dragonfly_custom_get_router_neighbor_count(void* topo, router_id_t r)
// Given the id of a router, this function should return the number of routers // Given the id of a router, this function should return the number of routers
// (not compute nodes) connected to it. It should return -1 if the router id // (not compute nodes) connected to it. It should return -1 if the router id
// is not valid. // is not valid.
return -1; const dragonfly_param * params = &all_params[num_params-1];
if(!params)
return -1.0;
if(r < 0 || r >= params->total_routers)
return -1.0;
return (params->num_router_cols - 1) + (params->num_router_rows - 1) + params->num_global_channels;
static void dragonfly_custom_get_router_neighbor_list(void* topo, router_id_t r, router_id_t* neighbors) { static void dragonfly_custom_get_router_neighbor_list(void* topo, router_id_t r, router_id_t* neighbors) {
// TODO
// Given a router id r, this function fills the "neighbors" array with the ids of routers // Given a router id r, this function fills the "neighbors" array with the ids of routers
// directly connected to r. It is assumed that enough memory has been allocated to "neighbors" // directly connected to r. It is assumed that enough memory has been allocated to "neighbors"
// (using get_router_neighbor_count to know the required size). // (using get_router_neighbor_count to know the required size).
if(!params)
return -1.0;
return -1.0;
int gid = r / params->num_routers;
int src_row = r / params->num_router_cols;
int src_col = r % params->num_router_cols;
/* First the routers in the same row */
for(int i = 0; i < params->num_router_cols; i++)
int neighbor = gid * p->num_routers + (src_row * params->num_router_cols) + i;
if(neighbor != r)
neighbors[i] = neighbor;
/* Now the routers in the same column. */
for(int i = 0; i < params->num_router_rows; i++)
int neighbor = gid * p->num_routers + src_col + (i * params->num_router_cols);
int offset = i + num_router_cols - 1;
if(neighbor != r)
neighbors[offset] = neighbor;
int g_offset = params->num_router_cols + params->num_router_cols - 2;
/* Now fill up global channels */
set<router_id_t> g_neighbors;
map< int, vector<bLink> > &curMap = interGroupLinks[a];
map< int, vector<bLink> >::iterator it = curMap.begin();
for(; it != curMap.end(); it++) {
for(int l = 0; l < it->second.size(); l++) {
g_neighbors.insert(it->second[l].dest);
copy(g_neighbors.begin, g_neighbors.end, neighbors[g_offset]);
static int dragonfly_custom_get_router_location(void* topo, router_id_t r, int32_t* location, int size) { static int dragonfly_custom_get_router_location(void* topo, router_id_t r, int32_t* location, int size) {
...@@ -3265,7 +3366,21 @@ static int dragonfly_custom_get_router_location(void* topo, router_id_t r, int32 ...@@ -3265,7 +3366,21 @@ static int dragonfly_custom_get_router_location(void* topo, router_id_t r, int32
// If the "size" is sufficient to hold the information, the function should return the size // If the "size" is sufficient to hold the information, the function should return the size
// effectively used (e.g. 2 in the above example). If however the function did not manage to use // effectively used (e.g. 2 in the above example). If however the function did not manage to use
// the provided buffer, it should return -1. // the provided buffer, it should return -1.
if(!params)
return -1; return -1;
if(r < 0 || r >= params->total_terminals)
return -1;
if(size < 2)
return -1;
int rid = r % params->num_routers;
location[0] = gid;
location[1] = rid;
return 2;
static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node, int32_t* location, int size) { static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node, int32_t* location, int size) {
...@@ -3273,28 +3388,64 @@ static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node, ...@@ -3273,28 +3388,64 @@ static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node,
// This function does the same as dragonfly_custom_get_router_location but for a compute node instead // This function does the same as dragonfly_custom_get_router_location but for a compute node instead
// of a router. E.g., for a dragonfly network, the location could be expressed as the array // of a router. E.g., for a dragonfly network, the location could be expressed as the array
// [ group_id, router_id, terminal_id ] // [ group_id, router_id, terminal_id ]
if(!params)
return -1;
if(size < 3)
return -1;
int rid = node / params->num_cn;
int gid = rid / params->num_routers;
int lid = node % params->num_cn;
location[0] = gid;
location[1] = rid;
location[2] = lid;
return 3;
static router_id_t dragonfly_custom_get_router_from_compute_node(void* topo, cn_id_t node) { static router_id_t dragonfly_custom_get_router_from_compute_node(void* topo, cn_id_t node) {
// TODO // TODO
// Given a node id, this function returns the id of the router connected to the node, // Given a node id, this function returns the id of the router connected to the node,
// or -1 if the node id is not valid. // or -1 if the node id is not valid.
if(!params)
return -1;
router_id_t rid = node / params->num_cn;
return rid;
static int dragonfly_custom_get_router_compute_node_count(void* topo, router_id_t r) { static int dragonfly_custom_get_router_compute_node_count(void* topo, router_id_t r) {
// TODO
// Given the id of a router, returns the number of compute nodes connected to this // Given the id of a router, returns the number of compute nodes connected to this
// router, or -1 if the router id is not valid. // router, or -1 if the router id is not valid.
return 0; const dragonfly_param * params = &all_params[num_params-1];
if(!params)
return -1;
return -1;
return params->num_cn;
static void dragonfly_custom_get_router_compute_node_list(void* topo, router_id_t r, cn_id_t* nodes) { static void dragonfly_custom_get_router_compute_node_list(void* topo, router_id_t r, cn_id_t* nodes) {
// TODO // TODO: What if there is an invalid router ID?
// Given the id of a router, fills the "nodes" array with the list of ids of compute nodes // Given the id of a router, fills the "nodes" array with the list of ids of compute nodes
// connected to this router. It is assumed that enough memory has been allocated for the // connected to this router. It is assumed that enough memory has been allocated for the
// "nodes" variable to hold all the ids. // "nodes" variable to hold all the ids.
for(int i = 0; i < params->num_cn; i++)
nodes[i] = r * params->num_cn + i;
cortex_topology dragonfly_custom_cortex_topology = { cortex_topology dragonfly_custom_cortex_topology = {
Markdown is supported
0% or .
Please register or to comment
