Commit d5fe2b8f authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Adding tests for DUMPI traces with dragonfly, slim fly and torus models
parent 8a7bb711
LPGROUPS
MODELNET_GRP
repetitions="32"; # repetitions = Ne = total # of edge switches. For type0 Ne = Np*Ns = ceil(N/Ns*(k/2))*(k/2) = ceil(N/(k/2)^2)*(k/2)
nw-lp="4";
modelnet_fattree="4";
fattree_switch="3";
PARAMS
ft_type="0";
packet_size="512";
message_size="592";
chunk_size="512";
modelnet_scheduler="fcfs";
#modelnet_scheduler="round-robin";
modelnet_order=( "fattree" );
num_levels="3";
switch_count="32"; # = repititions
switch_radix="8";
router_delay="90";
terminal_radix="1";
soft_delay="1000";
vc_size="65536";
cn_vc_size="65536";
link_bandwidth="12.5";
cn_bandwidth="12.5";
routing="adaptive";
rail_routing="adaptive";
LPGROUPS
MODELNET_GRP
repetitions="50";
nw-lp="3";
modelnet_slimfly="3";
slimfly_router="1";
PARAMS
packet_size="256";
modelnet_order=( "slimfly" );
# scheduler options
chunk_size="256";
# modelnet_scheduler="round-robin";
num_vcs="4";
num_routers="5";
num_terminals="3";
global_channels="5";
local_channels="2";
generator_set_X=("1","4"); # : Subgraph 0 generator set
generator_set_X_prime=("2","3"); # : Subgraph 1 generator set
local_vc_size="25600";
global_vc_size="25600";
cn_vc_size="25600";
local_bandwidth="9.0";
global_bandwidth="9.0";
cn_bandwidth="9.0";
router_delay="0";
link_delay="0";
message_size="592";
routing="minimal";
...@@ -10,7 +10,7 @@ LPGROUPS ...@@ -10,7 +10,7 @@ LPGROUPS
PARAMS PARAMS
packet_size="512"; packet_size="512";
message_size="560"; message_size="592";
modelnet_order=( "torus" ); modelnet_order=( "torus" );
# scheduler options # scheduler options
modelnet_scheduler="fcfs"; modelnet_scheduler="fcfs";
...@@ -1441,9 +1441,11 @@ void nw_test_finalize(nw_state* s, tw_lp* lp) ...@@ -1441,9 +1441,11 @@ void nw_test_finalize(nw_state* s, tw_lp* lp)
int count_irecv = qlist_count(&s->pending_recvs_queue); int count_irecv = qlist_count(&s->pending_recvs_queue);
int count_isend = qlist_count(&s->arrival_queue); int count_isend = qlist_count(&s->arrival_queue);
if(count_irecv || count_isend) if(count_irecv || count_isend)
printf("\n LP %llu unmatched irecvs %d unmatched sends %d Total sends %ld receives %ld collectives %ld delays %ld wait alls %ld waits %ld send time %lf wait %lf", {
lp->gid, count_irecv, count_isend, s->num_sends, s->num_recvs, s->num_cols, s->num_delays, s->num_waitall, s->num_wait, s->send_time, s->wait_time); printf("\n LP %llu unmatched irecvs %d unmatched sends %d Total sends %ld receives %ld collectives %ld delays %ld wait alls %ld waits %ld send time %lf wait %lf",
tw_error(TW_LOC, "\n Unmatched send and receive, terminating simulation");
written += sprintf(s->output_buf + written, "\n %llu %llu %ld %ld %ld %ld %lf %lf %lf", lp->gid, s->nw_id, s->num_sends, s->num_recvs, s->num_bytes_sent, written += sprintf(s->output_buf + written, "\n %llu %llu %ld %ld %ld %ld %lf %lf %lf", lp->gid, s->nw_id, s->num_sends, s->num_recvs, s->num_bytes_sent,
s->num_bytes_recvd, s->send_time, s->elapsed_time - s->compute_time, s->compute_time); s->num_bytes_recvd, s->send_time, s->elapsed_time - s->compute_time, s->compute_time);
lp_io_write(lp->gid, "mpi-replay-stats", written, s->output_buf); lp_io_write(lp->gid, "mpi-replay-stats", written, s->output_buf);
#!/bin/bash
FILE=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00-0000.bin
if [ ! -f $FILE ]; then
wget https://portal.nersc.gov/project/CAL/doe-miniapps-mpi-traces/AMG/df_AMG_n27_dumpi.tar.gz
tar -xvf df_AMG_n27_dumpi.tar.gz -C /tmp
fi
...@@ -9,3 +9,5 @@ src/network-workloads/model-net-synthetic-custom-dfly --sync=1 --num_messages=1 ...@@ -9,3 +9,5 @@ src/network-workloads/model-net-synthetic-custom-dfly --sync=1 --num_messages=1
...@@ -5,7 +5,10 @@ if [ -z $srcdir ]; then ...@@ -5,7 +5,10 @@ if [ -z $srcdir ]; then
exit 1 exit 1
fi fi
source $srcdir/tests/download-traces.sh
src/network-workloads/model-net-synthetic --sync=1 --num_messages=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-dragonfly.conf src/network-workloads/model-net-synthetic --sync=1 --num_messages=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-dragonfly.conf
src/network-workloads/model-net-mpi-replay --sync=1 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-dfly-amg-216.conf
exit 1 exit 1
fi fi
src/network-workloads/model-net-synthetic-fattree --sync=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-fattree.conf src/network-workloads/model-net-synthetic-fattree --sync=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-fattree.conf
#src/network-workloads/model-net-mpi-replay --sync=1 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-fattree.conf
...@@ -5,7 +5,9 @@ if [ -z $srcdir ]; then ...@@ -5,7 +5,9 @@ if [ -z $srcdir ]; then
exit 1 exit 1
fi fi
src/network-workloads/model-net-synthetic-slimfly --sync=1 -- $srcdir/src/network-workloads/conf/modelnet-synthetic-slimfly-min.conf source $srcdir/tests/download-traces.sh
src/network-workloads/model-net-mpi-replay --sync=1 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-slimfly-min.conf
#!/bin/bash #!/bin/bash
echo srcdir variable not set.
exit 1
fi
tests/modelnet-test --sync=1 -- tests/conf/modelnet-test-torus.conf tests/modelnet-test --sync=1 -- tests/conf/modelnet-test-torus.conf
src/network-workloads/model-net-mpi-replay --sync=1 --num_net_traces=27 --workload_file=/tmp/df_AMG_n27_dumpi/dumpi-2014.03.03.14.55.00- --workload_type="dumpi" -- $srcdir/src/network-workloads/conf/modelnet-mpi-test-torus.conf
Markdown is supported
0% or .
Please register or to comment
