Commit d31683a3 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
dfp: fix terminal length conditional and remove deprecated rc value
parent 4c1947e6
...@@ -2071,7 +2071,7 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message ...@@ -2071,7 +2071,7 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message
s->terminal_length[vcg] += s->params->chunk_size; s->terminal_length[vcg] += s->params->chunk_size;
if (s->terminal_length[vcg] < 2 * s->params->cn_vc_size) { if (s->terminal_length[vcg] < s->params->cn_vc_size) {
model_net_method_idle_event(nic_ts, 0, lp); model_net_method_idle_event(nic_ts, 0, lp);
else { else {
...@@ -3883,9 +3883,6 @@ static void router_packet_receive_rc(router_state *s, tw_bf *bf, terminal_plus_m ...@@ -3883,9 +3883,6 @@ static void router_packet_receive_rc(router_state *s, tw_bf *bf, terminal_plus_m
if (bf->c4) { if (bf->c4) {
if (bf->c22) {
s->last_buf_full[output_port] = msg->saved_busy_time;
delete_terminal_plus_message_list( delete_terminal_plus_message_list(
return_tail(s->queued_msgs[output_port], s->queued_msgs_tail[output_port], output_chan)); return_tail(s->queued_msgs[output_port], s->queued_msgs_tail[output_port], output_chan));
s->queued_count[output_port] -= s->params->chunk_size; s->queued_count[output_port] -= s->params->chunk_size;
Markdown is supported
0% or .
Please register or to comment
