Commit cdfe3c19 authored by Shane Snyder's avatar Shane Snyder
Browse files
Minor enhancement to the darshan i/o workload API
Improve the performance of the darshan i/o workload by converting the
linked list of per-rank contexts to a hash table.
parent a1e0df0a
...@@ -12,19 +12,26 @@ ...@@ -12,19 +12,26 @@
#include <assert.h> #include <assert.h>
#include <sys/stat.h> #include <sys/stat.h>
#include "ross.h"
#include "codes/codes-workload.h" #include "codes/codes-workload.h"
#include "codes-workload-method.h" #include "codes-workload-method.h"
#include "darshan-io-events.h" #include "darshan-io-events.h"
#include "codes/quickhash.h"
#define DARSHAN_MAX_EVENT_READ_COUNT 100 #define DARSHAN_MAX_EVENT_READ_COUNT 100
#define DARSHAN_NEGLIGIBLE_DELAY .001 #define DARSHAN_NEGLIGIBLE_DELAY .001
#define RANK_HASH_TABLE_SIZE 397
/* structure for storing all context needed to retrieve events for this rank */ /* structure for storing all context needed to retrieve events for this rank */
/* TODO: if many ross LPs are mapped to this PE, then memory usage is going to increase
* linearly, obviously due to the static events arrays used here to store darshan events.
* This really needs to be fixed by coming up with a more intelligent way of representing
* this workload (i.e. no intermediary format). Until then, you can lower the
* DARSHAN_MAX_EVENT_READ_COUNT to as low as 1 to save memory but restrict performance.
struct rank_events_context struct rank_events_context
int rank; int rank;
struct rank_events_context *next;
int ind_file_fd; int ind_file_fd;
int64_t ind_event_cnt; int64_t ind_event_cnt;
int coll_file_fd; int coll_file_fd;
...@@ -36,6 +43,7 @@ struct rank_events_context ...@@ -36,6 +43,7 @@ struct rank_events_context
int coll_list_ndx; int coll_list_ndx;
int coll_list_max; int coll_list_max;
double last_event_time; double last_event_time;
struct qhash_head hash_link;
/* CODES workload API functions for workloads generated from darshan logs*/ /* CODES workload API functions for workloads generated from darshan logs*/
...@@ -46,6 +54,7 @@ static void *darshan_io_workload_get_info(int rank); ...@@ -46,6 +54,7 @@ static void *darshan_io_workload_get_info(int rank);
/* helper functions for darshan workload CODES API */ /* helper functions for darshan workload CODES API */
static void darshan_read_events(struct rank_events_context *rank_context, int ind_flag); static void darshan_read_events(struct rank_events_context *rank_context, int ind_flag);
static struct codes_workload_op darshan_event_to_codes_workload_op(struct darshan_event event); static struct codes_workload_op darshan_event_to_codes_workload_op(struct darshan_event event);
static int hash_rank_compare(void *key, struct qhash_head *link);
/* workload method name and function pointers for the CODES workload API */ /* workload method name and function pointers for the CODES workload API */
struct codes_workload_method darshan_io_workload_method = struct codes_workload_method darshan_io_workload_method =
...@@ -56,16 +65,18 @@ struct codes_workload_method darshan_io_workload_method = ...@@ -56,16 +65,18 @@ struct codes_workload_method darshan_io_workload_method =
.codes_workload_get_info= darshan_io_workload_get_info, .codes_workload_get_info= darshan_io_workload_get_info,
/* linked list of context structs for each rank participating in the workload */ static struct qhash_table *rank_tbl = NULL;
static struct rank_events_context *rank_events = NULL; static int rank_tbl_pop = 0;
/* info about this darshan workload group needed by bgp model */ /* info about this darshan workload group needed by bgp model */
/* TODO: is this needed for darshan workloads? */
/* TODO: does this need to be stored in the rank context to support multiple workloads? */
static struct codes_workload_info darshan_workload_info = {-1, -1, -1, -1, -1}; static struct codes_workload_info darshan_workload_info = {-1, -1, -1, -1, -1};
/* load the workload generator for this rank, given input params */ /* load the workload generator for this rank, given input params */
static int darshan_io_workload_load(const char *params, int rank) static int darshan_io_workload_load(const char *params, int rank)
const char *event_file = params; /* for now, params is just the input event file name */ const char *event_file = params; /* for now, params is just the input trace file name */
int event_file_fd; int event_file_fd;
int64_t nprocs; int64_t nprocs;
ssize_t bytes_read; ssize_t bytes_read;
...@@ -73,8 +84,8 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -73,8 +84,8 @@ static int darshan_io_workload_load(const char *params, int rank)
int64_t off_beg = 0; int64_t off_beg = 0;
int64_t off_end = 0; int64_t off_end = 0;
int64_t i; int64_t i;
struct stat stat_buf;
int ret; int ret;
struct rank_events_context *new = NULL; struct rank_events_context *new = NULL;
if (!event_file) if (!event_file)
...@@ -91,21 +102,37 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -91,21 +102,37 @@ static int darshan_io_workload_load(const char *params, int rank)
/* open the input events file */ /* open the input events file */
event_file_fd = open(event_file, O_RDONLY); event_file_fd = open(event_file, O_RDONLY);
if (event_file_fd < 0) if (event_file_fd < 0)
free(new);
return -1; return -1;
/* read the event file header to determine the number of original ranks */ /* read the event file header to determine the number of original ranks */
bytes_read = read(event_file_fd, &nprocs, sizeof(int64_t)); bytes_read = read(event_file_fd, &nprocs, sizeof(int64_t));
if (bytes_read != sizeof(int64_t)) if (bytes_read != sizeof(int64_t))
free(new);
close(event_file_fd);
rank_offsets = malloc((nprocs + 1) * sizeof(int64_t)); rank_offsets = malloc((nprocs + 1) * sizeof(int64_t));
if (!rank_offsets) if (!rank_offsets)
free(new);
/* read the event list offset for all ranks from the event file header */ /* read the event list offset for all ranks from the event file header */
bytes_read = read(event_file_fd, rank_offsets, (nprocs + 1) * sizeof(int64_t)); bytes_read = read(event_file_fd, rank_offsets, (nprocs + 1) * sizeof(int64_t));
if (bytes_read != ((nprocs + 1) * sizeof(int64_t))) if (bytes_read != ((nprocs + 1) * sizeof(int64_t)))
free(new);
free(rank_offsets);
/* determine the beginning and ending offsets for this rank's independent events */ /* determine the beginning and ending offsets for this rank's independent events */
off_beg = rank_offsets[rank]; off_beg = rank_offsets[rank];
...@@ -128,7 +155,12 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -128,7 +155,12 @@ static int darshan_io_workload_load(const char *params, int rank)
if (!ret) if (!ret)
off_end = stat_buf.st_size; off_end = stat_buf.st_size;
else else
free(new);
free(rank_offsets);
/* set the independent event count */ /* set the independent event count */
...@@ -139,7 +171,12 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -139,7 +171,12 @@ static int darshan_io_workload_load(const char *params, int rank)
new->ind_file_fd = event_file_fd; new->ind_file_fd = event_file_fd;
ret = lseek(new->ind_file_fd, (off_t)off_beg, SEEK_SET); ret = lseek(new->ind_file_fd, (off_t)off_beg, SEEK_SET);
if (ret < 0) if (ret < 0)
free(new);
free(rank_offsets);
else else
...@@ -154,7 +191,12 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -154,7 +191,12 @@ static int darshan_io_workload_load(const char *params, int rank)
/* use fstat to find the ending offset of the file */ /* use fstat to find the ending offset of the file */
ret = fstat(event_file_fd, &stat_buf); ret = fstat(event_file_fd, &stat_buf);
free(new);
free(rank_offsets);
else else
off_end = (int64_t)stat_buf.st_size; off_end = (int64_t)stat_buf.st_size;
...@@ -164,11 +206,14 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -164,11 +206,14 @@ static int darshan_io_workload_load(const char *params, int rank)
/* open a new file descriptor for collective events, and seek to the beginning offset */ /* open a new file descriptor for collective events, and seek to the beginning offset */
new->coll_file_fd = open(event_file, O_RDONLY); new->coll_file_fd = open(event_file, O_RDONLY);
if (new->coll_file_fd < 0)
return -1;
ret = lseek(new->coll_file_fd, (off_t)off_beg, SEEK_SET); ret = lseek(new->coll_file_fd, (off_t)off_beg, SEEK_SET);
free(new);
free(rank_offsets);
else else
...@@ -182,9 +227,23 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -182,9 +227,23 @@ static int darshan_io_workload_load(const char *params, int rank)
new->coll_list_ndx = 0; new->coll_list_ndx = 0;
new->coll_list_max = 0; new->coll_list_max = 0;
/* add this stream of events to the head of our list of streams per rank */ /* initialize the hash table of rank contexts, if it has not been initialized */
new->next = rank_events; if (!rank_tbl)
rank_events = new; {
rank_tbl = qhash_init(hash_rank_compare, quickhash_32bit_hash, RANK_HASH_TABLE_SIZE);
if (!rank_tbl)
free(new);
free(rank_offsets);
close(new->coll_file_fd);
return -1;
/* add this rank context to the hash table */
qhash_add(rank_tbl, &(new->rank), &(new->hash_link));
rank_tbl_pop++;
/* fill out the info required for this workload group */ /* fill out the info required for this workload group */
if (darshan_workload_info.group_id == -1) if (darshan_workload_info.group_id == -1)
...@@ -196,7 +255,6 @@ static int darshan_io_workload_load(const char *params, int rank) ...@@ -196,7 +255,6 @@ static int darshan_io_workload_load(const char *params, int rank)
free(rank_offsets); free(rank_offsets);
return 0; return 0;
...@@ -205,23 +263,20 @@ static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op) ...@@ -205,23 +263,20 @@ static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op)
struct darshan_event next_event; struct darshan_event next_event;
int ind_event_flag; int ind_event_flag;
struct rank_events_context *tmp = rank_events; struct qhash_head *hash_link = NULL;
struct rank_events_context *tmp = NULL;
/* find event context for this rank */ /* find event context for this rank in the rank hash table */
while (tmp) hash_link = qhash_search(rank_tbl, &rank);
if (tmp->rank == rank)
break;
tmp = tmp->next;
/* terminate the workload if there are no events for this rank */ /* terminate the workload if there is no valid rank context */
if (!tmp) if (!hash_link)
op->op_type = CODES_WK_END; op->op_type = CODES_WK_END;
return; return;
tmp = qhash_entry(hash_link, struct rank_events_context, hash_link);
assert(tmp->rank == rank); assert(tmp->rank == rank);
/* read in more independent events if necessary */ /* read in more independent events if necessary */
...@@ -261,6 +316,11 @@ static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op) ...@@ -261,6 +316,11 @@ static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op)
/* no more events -- just end the workload */ /* no more events -- just end the workload */
qhash_del(hash_link);
free(tmp);
rank_tbl_pop--;
if (!rank_tbl_pop)
qhash_finalize(rank_tbl);
else else
...@@ -313,7 +373,8 @@ static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op) ...@@ -313,7 +373,8 @@ static void darshan_io_workload_get_next(int rank, struct codes_workload_op *op)
return; return;
/* for now, no info needed by the simulator regarding darshan workloads */ /* return the workload info needed by the bgp model */
/* TODO: do we really need this? */
static void *darshan_io_workload_get_info(int rank) static void *darshan_io_workload_get_info(int rank)
return &(darshan_workload_info); return &(darshan_workload_info);
...@@ -414,6 +475,18 @@ static struct codes_workload_op darshan_event_to_codes_workload_op(struct darsha ...@@ -414,6 +475,18 @@ static struct codes_workload_op darshan_event_to_codes_workload_op(struct darsha
return codes_op; return codes_op;
int *in_rank = (int *)key;
struct rank_events_context *tmp;
tmp = qhash_entry(link, struct rank_events_context, hash_link);
if (tmp->rank == *in_rank)
return 1;
return 0;
* Local variables: * Local variables:
* c-indent-level: 4 * c-indent-level: 4
...@@ -22,7 +22,7 @@ ...@@ -22,7 +22,7 @@
#include "codes/quickhash.h" #include "codes/quickhash.h"
struct file_info_list struct file_info
struct qlist_head hash_link; struct qlist_head hash_link;
uint64_t file_hash; uint64_t file_hash;
...@@ -177,7 +177,7 @@ int main(int argc, char *argv[]) ...@@ -177,7 +177,7 @@ int main(int argc, char *argv[])
/* destroy and finalize the file descriptor hash table */ /* destroy and finalize the file descriptor hash table */
qhash_destroy_and_finalize(fd_table, struct file_info_list, hash_link, free); qhash_destroy_and_finalize(fd_table, struct file_info, hash_link, free);
error_exit: error_exit:
...@@ -192,7 +192,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -192,7 +192,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
int open_flags = O_RDWR; int open_flags = O_RDWR;
char file_name[50]; char file_name[50];
int fildes; int fildes;
struct file_info_list *tmp_list = NULL; struct file_info *tmp_list = NULL;
struct qlist_head *hash_link = NULL; struct qlist_head *hash_link = NULL;
char *buf = NULL; char *buf = NULL;
int ret; int ret;
...@@ -270,7 +270,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -270,7 +270,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
/* save the file descriptor for this file in a hash table to be retrieved later */ /* save the file descriptor for this file in a hash table to be retrieved later */
tmp_list = malloc(sizeof(struct file_info_list)); tmp_list = malloc(sizeof(struct file_info));
if (!tmp_list) if (!tmp_list)
fprintf(stderr, "No memory available for file hash entry\n"); fprintf(stderr, "No memory available for file hash entry\n");
...@@ -292,7 +292,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -292,7 +292,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
/* search for the corresponding file descriptor in the hash table */ /* search for the corresponding file descriptor in the hash table */
hash_link = qhash_search_and_remove(fd_table, &(replay_op.u.close.file_id)); hash_link = qhash_search_and_remove(fd_table, &(replay_op.u.close.file_id));
assert(hash_link); assert(hash_link);
tmp_list = qhash_entry(hash_link, struct file_info_list, hash_link); tmp_list = qhash_entry(hash_link, struct file_info, hash_link);
fildes = tmp_list->file_descriptor; fildes = tmp_list->file_descriptor;
free(tmp_list); free(tmp_list);
...@@ -318,7 +318,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -318,7 +318,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
hash_link = qhash_search(fd_table, &(replay_op.u.write.file_id)); hash_link = qhash_search(fd_table, &(replay_op.u.write.file_id));
/* perform the write operation */ /* perform the write operation */
...@@ -349,7 +349,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -349,7 +349,7 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
hash_link = qhash_search(fd_table, &(replay_op.u.read.file_id)); hash_link = qhash_search(fd_table, &(replay_op.u.read.file_id));
...@@ -379,9 +379,9 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i ...@@ -379,9 +379,9 @@ int replay_workload_op(struct codes_workload_op replay_op, int rank, long long i
int hash_file_compare(void *key, struct qlist_head *link) int hash_file_compare(void *key, struct qlist_head *link)
uint64_t *in_file_hash = (uint64_t *)key; uint64_t *in_file_hash = (uint64_t *)key;
struct file_info_list *tmp_file; struct file_info *tmp_file;
tmp_file = qlist_entry(link, struct file_info_list, hash_link); tmp_file = qlist_entry(link, struct file_info, hash_link);
if (tmp_file->file_hash == *in_file_hash) if (tmp_file->file_hash == *in_file_hash)
return 1; return 1;
Markdown is supported
0% or .
Please register or to comment
