Commit ccb2567a authored by yangxuserene's avatar yangxuserene
clean up for jobmap interface based on John's suggestions
parent 3a2e6194
...@@ -99,7 +99,7 @@ src_libcodes_base_a_SOURCES = \ ...@@ -99,7 +99,7 @@ src_libcodes_base_a_SOURCES = \
src/util/codes-jobmap-method-impl.h \ src/util/codes-jobmap-method-impl.h \
src/util/codes-jobmap.c \ src/util/codes-jobmap.c \
src/util/jobmap-impl/jobmap-dummy.c \ src/util/jobmap-impl/jobmap-dummy.c \
src/util/jobmap-impl/jobmap-local-global-mapping.c\ src/util/jobmap-impl/jobmap-list.c\
src/workload/codes-workload.c \ src/workload/codes-workload.c \
src/workload/codes-workload-method.h \ src/workload/codes-workload-method.h \
src/workload/methods/codes-iolang-wrkld.c \ src/workload/methods/codes-iolang-wrkld.c \
...@@ -11,7 +11,7 @@ ...@@ -11,7 +11,7 @@
#include "codes/codes-jobmap.h" #include "codes/codes-jobmap.h"
extern struct codes_jobmap_impl jobmap_dummy_impl; extern struct codes_jobmap_impl jobmap_dummy_impl;
extern struct codes_jobmap_impl jobmap_dumpi_impl; extern struct codes_jobmap_impl jobmap_list_impl;
struct codes_jobmap_ctx * struct codes_jobmap_ctx *
codes_jobmap_configure(enum codes_jobmap_type t, void const * params) codes_jobmap_configure(enum codes_jobmap_type t, void const * params)
...@@ -26,7 +26,7 @@ codes_jobmap_configure(enum codes_jobmap_type t, void const * params) ...@@ -26,7 +26,7 @@ codes_jobmap_configure(enum codes_jobmap_type t, void const * params)
c->impl = &jobmap_dummy_impl; c->impl = &jobmap_dummy_impl;
break; break;
case CODES_JOBMAP_DUMPI: case CODES_JOBMAP_DUMPI:
c->impl = &jobmap_dumpi_impl; c->impl = &jobmap_list_impl;
break; break;
default: default:
free(c); free(c);
...@@ -9,6 +9,11 @@ ...@@ -9,6 +9,11 @@
#include <assert.h> #include <assert.h>
#include "src/util/codes-jobmap-method-impl.h" #include "src/util/codes-jobmap-method-impl.h"
#define ERR(str, ...)\
do{\
fprintf(stderr, "ERROR at %s:%d: " str "\n", __FILE__, __LINE__, ##__VA_ARGS__);\
return -1; \
}while(0)
struct workload_params { struct workload_params {
int num_jobs; int num_jobs;
...@@ -16,18 +21,16 @@ struct workload_params { ...@@ -16,18 +21,16 @@ struct workload_params {
int **lp_arrays; int **lp_arrays;
static int jobmap_dumpi_configure(void const * params, void ** ctx) static int jobmap_list_configure(void const * params, void ** ctx)
struct codes_jobmap_params_dumpi const * p = params; struct codes_jobmap_params_dumpi const * p = params;
struct workload_params *wp = malloc(sizeof(*wp)); struct workload_params *wp = malloc(sizeof(*wp));
assert(wp); assert(wp);
/*open first time, count No. lines, each line is the LP list for a job*/
FILE *alloc_file_name = fopen(p->alloc_file, "r"); FILE *alloc_file_name = fopen(p->alloc_file, "r");
if(!alloc_file_name) if(!alloc_file_name)
printf("Coudld not open file %s ======\n ", p->alloc_file); ERR( "Coudld not open file %s\n ", p->alloc_file);
exit(1);
else{ else{
wp->num_jobs = 0; wp->num_jobs = 0;
...@@ -37,38 +40,37 @@ static int jobmap_dumpi_configure(void const * params, void ** ctx) ...@@ -37,38 +40,37 @@ static int jobmap_dumpi_configure(void const * params, void ** ctx)
if(ch == '\n') if(ch == '\n')
wp->num_jobs++;//how many jobs wp->num_jobs++;//how many jobs
fclose(alloc_file_name);
wp->num_rank_job = malloc(sizeof(wp->num_rank_job)*wp->num_jobs); wp->num_rank_job = malloc(sizeof(wp->num_rank_job)*wp->num_jobs);
assert(wp->num_rank_job); assert(wp->num_rank_job);
for(int i=0; i<wp->num_jobs; i++) for(int i=0; i<wp->num_jobs; i++)
wp->num_rank_job[i]=0; wp->num_rank_job[i]=0;
/*open second time, read No. of LP id in each line, No. of LP id equals to No. of rank in each job*/
alloc_file_name = fopen(p->alloc_file, "r"); rewind(alloc_file_name);
int job_id = 0;
while(!feof(alloc_file_name))
char ch = (char)fgetc(alloc_file_name); int job_id = 0;
if(ch == '\n'){ while(!feof(alloc_file_name))
job_id++;//how many jobs {
continue; char ch = (char)fgetc(alloc_file_name);
} if(ch == '\n'){
if(ch == ' '){ job_id++;//how many jobs
wp->num_rank_job[job_id]++;//how many ranks in each job continue;
if(ch == ' '){
/*open third time, read in each LP id for each rank in every job*/
wp->lp_arrays = (int **)malloc(sizeof(int *)*wp->num_jobs); wp->lp_arrays = (int **)malloc(sizeof(int *)*wp->num_jobs);
for(int i=0; i<wp->num_jobs; i++){ for(int i=0; i<wp->num_jobs; i++){
wp->lp_arrays[i] = (int *)malloc(sizeof(int)*wp->num_rank_job[i]); wp->lp_arrays[i] = (int *)malloc(sizeof(int)*wp->num_rank_job[i]);
for(int i=0; i < wp->num_jobs; i++) for(int i=0; i < wp->num_jobs; i++)
for(int j=0; j < wp->num_rank_job[i]; j++) for(int j=0; j < wp->num_rank_job[i]; j++)
...@@ -86,7 +88,7 @@ static int jobmap_dumpi_configure(void const * params, void ** ctx) ...@@ -86,7 +88,7 @@ static int jobmap_dumpi_configure(void const * params, void ** ctx)
printf("\nIn Job %d, there are %d ranks, LP list is:\n", i, wp->num_rank_job[i]); printf("\nIn Job %d, there are %d ranks, LP list is:\n", i, wp->num_rank_job[i]);
printf(",%d,", wp->lp_arrays[i][j]); printf("%d,", wp->lp_arrays[i][j]);
printf("\n==========\n"); printf("\n==========\n");
...@@ -94,7 +96,7 @@ static int jobmap_dumpi_configure(void const * params, void ** ctx) ...@@ -94,7 +96,7 @@ static int jobmap_dumpi_configure(void const * params, void ** ctx)
return 0; return 0;
static struct codes_jobmap_id jobmap_dumpi_to_local(int id, void const * ctx) static struct codes_jobmap_id jobmap_list_to_local(int id, void const * ctx)
struct codes_jobmap_id rtn; struct codes_jobmap_id rtn;
struct workload_params *wp = (struct workload_params*)ctx; struct workload_params *wp = (struct workload_params*)ctx;
...@@ -119,7 +121,7 @@ static struct codes_jobmap_id jobmap_dumpi_to_local(int id, void const * ctx) ...@@ -119,7 +121,7 @@ static struct codes_jobmap_id jobmap_dumpi_to_local(int id, void const * ctx)
return rtn; return rtn;
static int jobmap_dumpi_to_global(struct codes_jobmap_id id, void const * ctx) static int jobmap_list_to_global(struct codes_jobmap_id id, void const * ctx)
...@@ -130,7 +132,7 @@ static int jobmap_dumpi_to_global(struct codes_jobmap_id id, void const * ctx) ...@@ -130,7 +132,7 @@ static int jobmap_dumpi_to_global(struct codes_jobmap_id id, void const * ctx)
return -1; return -1;
int jobmap_dumpi_get_num_jobs(void const * ctx) int jobmap_list_get_num_jobs(void const * ctx)
return wp->num_jobs; return wp->num_jobs;
...@@ -138,18 +140,27 @@ int jobmap_dumpi_get_num_jobs(void const * ctx) ...@@ -138,18 +140,27 @@ int jobmap_dumpi_get_num_jobs(void const * ctx)
static void jobmap_dumpi_destroy(void * ctx) static void jobmap_list_destroy(void * ctx)
free(wp->lp_arrays[i]);
free(wp->lp_arrays);
free(wp->num_rank_job);
free(ctx); free(ctx);
struct codes_jobmap_impl jobmap_dumpi_impl = { struct codes_jobmap_impl jobmap_list_impl = {
jobmap_dumpi_configure, jobmap_list_configure,
jobmap_dumpi_destroy, jobmap_list_destroy,
jobmap_dumpi_to_local, jobmap_list_to_local,
jobmap_dumpi_to_global, jobmap_list_to_global,
jobmap_dumpi_get_num_jobs jobmap_list_get_num_jobs
Markdown is supported
0%
or
Please register or to comment
