Commit cafa11b9 authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
update to ross interface change
parent adcef650
...@@ -540,7 +540,7 @@ void codes_mapping_setup_with_seed_offset(int offset) ...@@ -540,7 +540,7 @@ void codes_mapping_setup_with_seed_offset(int offset)
// last one // last one
g_tw_nRNG_per_lp++; g_tw_nRNG_per_lp++;
tw_define_lps(codes_mapping_get_lps_for_pe(), message_size, 0); tw_define_lps(codes_mapping_get_lps_for_pe(), message_size);
// use a similar computation to codes_mapping_init to compute the lpids and // use a similar computation to codes_mapping_init to compute the lpids and
// offsets to use in tw_rand_initial_seed // offsets to use in tw_rand_initial_seed
...@@ -110,7 +110,7 @@ int main( ...@@ -110,7 +110,7 @@ int main(
lps_per_proc = (NUM_SERVERS) / nprocs; lps_per_proc = (NUM_SERVERS) / nprocs;
tw_define_lps(lps_per_proc, sizeof(struct svr_msg), 0); tw_define_lps(lps_per_proc, sizeof(struct svr_msg));
for(i=0; i<lps_per_proc; i++) for(i=0; i<lps_per_proc; i++)
...@@ -86,7 +86,7 @@ int main( ...@@ -86,7 +86,7 @@ int main(
configuration_load(argv[2], MPI_COMM_WORLD, &config); configuration_load(argv[2], MPI_COMM_WORLD, &config);
tw_define_lps(lps_per_proc, 512, 0); tw_define_lps(lps_per_proc, 512);
Markdown is supported
0% or .
Please register or to comment
