Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
cacd55b9
Commit
cacd55b9
authored
Mar 29, 2018
by
Neil McGlohon
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'workloads' of xgitlab.cels.anl.gov:codes/codes into dfp-online-workloads
parents
a0f83d31
af00f056
Changes
7
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
7 changed files
with
89 additions
and
143 deletions
+89
-143
scripts/allocation_gen/config_alloc-upd.conf
+3
-3
scripts/allocation_gen/config_alloc.conf
+3
-4
scripts/allocation_gen/listgen.py
+8
-11
src/network-workloads/conf/modelnet-mpi-test.conf
+1
-1
src/network-workloads/model-net-mpi-replay.c
+72
-121
src/workload/codes-workload.c
+1
-2
src/workload/methods/codes-online-comm-wrkld.C
+1
-1
No files found.
View file @
cacd55b9
rand
CONT
8832
3456
2
2
1
1
1024
7500
1024
128
View file @
cacd55b9
rand
CONT
8316
3456
2048
2048
1024
128
View file @
cacd55b9
@@ -33,7 +33,6 @@ def cube_alloc(job_ranks, total_nodes):
row
append
i
offset
row
append
i
offset
layer
row
layer
row
cube
layer
cube
layer
print
"list length is"
len
cube
cube
f
open
'cube_allc_linear.conf'
'w'
f
open
'w'
for
rankid
in
range
len
cube
for
rankid
in
range
len
cube
@@ -60,7 +59,6 @@ def permeate_alloc(job_ranks, total_nodes):
permeate_list
node_list
num_rank
permeate_area
num_rank
1
permeate_area
permeate_list
node_list
num_rank
permeate_area
num_rank
1
permeate_area
alloc_list
random
sample
permeate_list
job_ranks
num_rank
alloc_list
random
sample
permeate_list
job_ranks
num_rank
alloc_list
sort
alloc_list
sort
print
"length of alloc list"
len
alloc_list
n
alloc_list
n
for
idx
in
range
len
alloc_list
for
idx
in
range
len
alloc_list
f
write
"%s "
alloc_list
idx
f
write
"%s "
alloc_list
idx
f
write
n
f
write
n
@@ -73,7 +71,6 @@ def random_alloc(job_rank, total_nodes):
for
rankid
in
range
len
job_rank
for
rankid
in
range
len
job_rank
alloc_list
random
sample
node_list
job_rank
rankid
alloc_list
random
sample
node_list
job_rank
rankid
node_list
i
for
i
in
node_list
if
i
not
in
alloc_list
node_list
i
for
i
in
node_list
if
i
not
in
alloc_list
print
len
alloc_list
n
alloc_list
n
for
idx
in
range
len
alloc_list
for
idx
in
range
len
alloc_list
f
write
"%s "
alloc_list
idx
f
write
"%s "
alloc_list
idx
f
write
n
f
write
n
@@ -113,22 +110,22 @@ def stripe_alloc(job_ranks, total_nodes):
def
policy_select
plcy
job_ranks
total_nodes
def
policy_select
plcy
job_ranks
total_nodes
if
plcy
"CONT"
if
plcy
"CONT"
print
"contiguous alloction!"
print
contiguous_alloc
job_ranks
total_nodes
contiguous_alloc
job_ranks
total_nodes
elif
plcy
"rand"
elif
plcy
"rand"
print
"random allocation!"
print
random_alloc
job_ranks
total_nodes
random_alloc
job_ranks
total_nodes
elif
plcy
"STRIPE"
elif
plcy
"STRIPE"
print
"stripe allcation!"
print
"stripe allcation!"
stripe_alloc
job_ranks
total_nodes
stripe_alloc
job_ranks
total_nodes
elif
plcy
"PERMEATE"
elif
plcy
"PERMEATE"
print
"permeate allocation!"
print
permeate_alloc
job_ranks
total_nodes
permeate_alloc
job_ranks
total_nodes
elif
plcy
"CUBE"
elif
plcy
"CUBE"
print
"cube allocation!"
print
"cube allocation!"
cube_alloc
job_ranks
total_nodes
cube_alloc
job_ranks
total_nodes
else
else
print
"NOT Supported yet!"
print
if
__name__
"__main__"
if
__name__
"__main__"
@@ -142,8 +139,8 @@ if __name__ == "__main__":
f
close
f
close
alloc_plcy
array
pop
0
alloc_plcy
array
pop
0
total_nodes
array
pop
0
total_nodes
array
pop
0
print
alloc_plcy
print
alloc_plcy
array
map
int
array
array
map
int
array
print
array
print
array
policy_select
alloc_plcy
array
total_nodes
policy_select
alloc_plcy
array
total_nodes
View file @
cacd55b9
@@ -2,7 +2,7 @@ LPGROUPS
MODELNET_GRP
MODELNET_GRP
repetitions
"2
7
repetitions
"2
56
modelnet_simplenet
"1"
modelnet_simplenet
"1"
nw
lp
"1"
nw
lp
"1"
View file @
cacd55b9
This diff is collapsed.
View file @
cacd55b9
@@ -227,7 +227,6 @@ void codes_workload_get_next(
return
return
/* ask generator for the next operation */
method_array
wkld_id
app_id
rank
op
method_array
wkld_id
app_id
rank
op
assert
op
op_type
assert
op
op_type
@@ -253,7 +252,7 @@ void codes_workload_get_next_rc(
assert
tmp
assert
tmp
tmp_op
struct
rc_op
calloc
1
sizeof
tmp
_op
tmp_op
struct
rc_op
malloc
sizeof
struct
rc
_op
assert
tmp_op
assert
tmp_op
tmp_op
op
op
tmp_op
op
op
tmp_op
next
tmp
lifo
tmp_op
next
tmp
lifo
View file @
cacd55b9
@@ -25,7 +25,7 @@
@@ -25,7 +25,7 @@
#define ALLREDUCE_SHORT_MSG_SIZE 2048
#define DBG_COMM 0
#define DBG_COMM 0
using
namespace
std
using
namespace
std
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
