Commit caac4e98 authored by Philip Carns's avatar Philip Carns
Browse files
minor tweak
parent 7a53c394
...@@ -385,7 +385,7 @@ static void handle_msg_start_rev_event( ...@@ -385,7 +385,7 @@ static void handle_msg_start_rev_event(
stat = model_net_find_stats(m->category, ns->sn_stats_array); stat = model_net_find_stats(m->category, ns->sn_stats_array);
stat->send_count--; stat->send_count--;
stat->send_bytes -= m->net_msg_size_bytes; stat->send_bytes -= m->net_msg_size_bytes;
stat->send_time -= global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs); stat->send_time -= (global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs));
return; return;
...@@ -415,7 +415,7 @@ static void handle_msg_start_event( ...@@ -415,7 +415,7 @@ static void handle_msg_start_event(
stat->send_count++; stat->send_count++;
stat->send_bytes += m->net_msg_size_bytes; stat->send_bytes += m->net_msg_size_bytes;
stat->send_time += global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs); stat->send_time += (global_net_startup_ns + rate_to_ns(m->net_msg_size_bytes, global_net_bw_mbs));
if(stat->max_event_size < total_event_size) if(stat->max_event_size < total_event_size)
stat->max_event_size = total_event_size; stat->max_event_size = total_event_size;
Markdown is supported
0% or .
Please register or to comment
