Commit c645d6bd authored by Neil McGlohon's avatar Neil McGlohon
Browse files
DFP: Fix for QOS missing lines
Changes are as follows:
terminal plus init:
	missing inits
	corrected vc occupancy init
	corrected term msgs lists init
router credit send:
	add missing origin router ID info into buf msg
packet gen rc:
	add missing rc for monitoring bw
packet send:
	correct vc index for R_ARRIVE message
	removed deprecated RC bitfields
terminal buf update:
	add missing rng and cll counter inits
router packet receive rc:
	remove bad rng and cll counter inits
router packet send rc:
	add missing QOS rc lines - possibly very important
router packet send:
	correct rng coutner condition
router buf update:
	add missing asserts
parent 0ff25d9b
...@@ -777,7 +777,7 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -777,7 +777,7 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
rc = configuration_get_value_double(&config, "PARAMS", "max_qos_monitor", anno, &max_qos_monitor); rc = configuration_get_value_double(&config, "PARAMS", "max_qos_monitor", anno, &max_qos_monitor);
if(rc) { if(rc) {
printf("\n Setting adaptive threshold to %lf ", max_qos_monitor); printf("\n Setting max_qos_monitor to %lf ", max_qos_monitor);
rc = configuration_get_value_int(&config, "PARAMS", "cn_vc_size", anno, &p->cn_vc_size); rc = configuration_get_value_int(&config, "PARAMS", "cn_vc_size", anno, &p->cn_vc_size);
...@@ -1250,8 +1250,9 @@ void terminal_plus_init(terminal_state *s, tw_lp *lp) ...@@ -1250,8 +1250,9 @@ void terminal_plus_init(terminal_state *s, tw_lp *lp)
// printf("%d: Terminal Init()\n",lp->gid); // printf("%d: Terminal Init()\n",lp->gid);
s->packet_gen = 0; s->packet_gen = 0;
s->packet_fin = 0; s->packet_fin = 0;
s->is_monitoring_bw = 0;
s->num_term_rc_windows = 100; s->num_term_rc_windows = 100;
s->rc_index = 0;
int i; int i;
char anno[MAX_NAME_LENGTH]; char anno[MAX_NAME_LENGTH];
...@@ -1308,7 +1309,7 @@ void terminal_plus_init(terminal_state *s, tw_lp *lp) ...@@ -1308,7 +1309,7 @@ void terminal_plus_init(terminal_state *s, tw_lp *lp)
/* How much data has been transmitted on the virtual channel group within /* How much data has been transmitted on the virtual channel group within
* the window */ * the window */
s->qos_data = (int*)calloc(num_qos_levels, sizeof(int)); s->qos_data = (int*)calloc(num_qos_levels, sizeof(int));
s->vc_occupancy = (int*)calloc(s->num_vcs, sizeof(int)); s->vc_occupancy = (int*)calloc(num_qos_levels, sizeof(int));
/* for reverse handlers */ /* for reverse handlers */
s->last_qos_status = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int)); s->last_qos_status = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int));
...@@ -1318,20 +1319,24 @@ void terminal_plus_init(terminal_state *s, tw_lp *lp) ...@@ -1318,20 +1319,24 @@ void terminal_plus_init(terminal_state *s, tw_lp *lp)
s->qos_data[i] = 0; s->qos_data[i] = 0;
s->qos_status[i] = Q_ACTIVE; s->qos_status[i] = Q_ACTIVE;
s->vc_occupancy[i] = 0;
s->last_qos_lvl = 0; s->last_qos_lvl = 0;
s->last_buf_full = 0; s->last_buf_full = 0;
for (i = 0; i < s->num_vcs; i++) {
s->rank_tbl = NULL; s->rank_tbl = NULL;
s->terminal_msgs = s->terminal_msgs =
(terminal_plus_message_list **) calloc(s->num_vcs, sizeof(terminal_plus_message_list *)); (terminal_plus_message_list **) calloc(num_qos_levels, sizeof(terminal_plus_message_list *));
s->terminal_msgs_tail = s->terminal_msgs_tail =
for(int i = 0; i < num_qos_levels; i++)
s->terminal_msgs[i] = NULL;
s->terminal_msgs_tail[i] = NULL;
s->terminal_length = (int*)calloc(num_qos_levels, sizeof(int)); s->terminal_length = (int*)calloc(num_qos_levels, sizeof(int));
s->in_send_loop = 0; s->in_send_loop = 0;
s->issueIdle = 0; s->issueIdle = 0;
...@@ -1887,6 +1892,7 @@ static void router_credit_send(router_state *s, terminal_plus_message *msg, tw_l ...@@ -1887,6 +1892,7 @@ static void router_credit_send(router_state *s, terminal_plus_message *msg, tw_l
buf_msg->magic = router_magic_num; buf_msg->magic = router_magic_num;
buf_msg->origin_router_id = s->router_id;
if (sq == -1) { if (sq == -1) {
buf_msg->vc_index = msg->vc_index; buf_msg->vc_index = msg->vc_index;
buf_msg->output_chan = msg->output_chan; buf_msg->output_chan = msg->output_chan;
...@@ -1916,6 +1922,9 @@ static void packet_generate_rc(terminal_state *s, tw_bf *bf, terminal_plus_messa ...@@ -1916,6 +1922,9 @@ static void packet_generate_rc(terminal_state *s, tw_bf *bf, terminal_plus_messa
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
int num_qos_levels = s->params->num_qos_levels; int num_qos_levels = s->params->num_qos_levels;
if(bf->c1)
int num_chunks = msg->packet_size / s->params->chunk_size; int num_chunks = msg->packet_size / s->params->chunk_size;
if (msg->packet_size < s->params->chunk_size) if (msg->packet_size < s->params->chunk_size)
num_chunks++; num_chunks++;
...@@ -2005,6 +2014,7 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message ...@@ -2005,6 +2014,7 @@ static void packet_generate(terminal_state *s, tw_bf *bf, terminal_plus_message
if(src_grp_id == dest_grp_id) if(src_grp_id == dest_grp_id)
if(dest_router_id == s->router_id) if(dest_router_id == s->router_id)
//TODO: add RC stuff like in dragonfly-custom.C
num_local_packets_sr++; num_local_packets_sr++;
else else
num_local_packets_sg++; num_local_packets_sg++;
...@@ -2230,7 +2240,7 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -2230,7 +2240,7 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
m->type = R_ARRIVE; m->type = R_ARRIVE;
m->src_terminal_id = lp->gid; m->src_terminal_id = lp->gid;
m->vc_index = 0; m->vc_index = vcg;
m->last_hop = TERMINAL; m->last_hop = TERMINAL;
m->magic = router_magic_num; m->magic = router_magic_num;
m->path_type = -1; m->path_type = -1;
...@@ -2242,7 +2252,6 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -2242,7 +2252,6 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
if (cur_entry->msg.chunk_id == num_chunks - 1 && (cur_entry->msg.local_event_size_bytes > 0)) { if (cur_entry->msg.chunk_id == num_chunks - 1 && (cur_entry->msg.local_event_size_bytes > 0)) {
bf->c2 = 1;
msg->num_cll++; msg->num_cll++;
tw_stime local_ts = codes_local_latency(lp); tw_stime local_ts = codes_local_latency(lp);
tw_event *e_new = tw_event_new(cur_entry->msg.sender_lp, local_ts, lp); tw_event *e_new = tw_event_new(cur_entry->msg.sender_lp, local_ts, lp);
...@@ -2270,7 +2279,6 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg ...@@ -2270,7 +2279,6 @@ static void packet_send(terminal_state *s, tw_bf *bf, terminal_plus_message *msg
/* if there is another packet inline then schedule another send event */ /* if there is another packet inline then schedule another send event */
if (cur_entry != NULL && s->vc_occupancy[next_vcg] + s->params->chunk_size <= s->params->cn_vc_size) { if (cur_entry != NULL && s->vc_occupancy[next_vcg] + s->params->chunk_size <= s->params->cn_vc_size) {
bf->c3 = 1;
terminal_plus_message *m_new; terminal_plus_message *m_new;
msg->num_rngs++; msg->num_rngs++;
ts += tw_rand_unif(lp->rng); ts += tw_rand_unif(lp->rng);
...@@ -2891,6 +2899,9 @@ static void terminal_buf_update_rc(terminal_state *s, tw_bf *bf, terminal_plus_m ...@@ -2891,6 +2899,9 @@ static void terminal_buf_update_rc(terminal_state *s, tw_bf *bf, terminal_plus_m
/* update the compute node-router channel buffer */ /* update the compute node-router channel buffer */
static void terminal_buf_update(terminal_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp) static void terminal_buf_update(terminal_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp)
msg->num_cll = 0;
msg->num_rngs = 0;
bf->c1 = 0; bf->c1 = 0;
bf->c2 = 0; bf->c2 = 0;
bf->c3 = 0; bf->c3 = 0;
...@@ -3845,9 +3856,6 @@ static void router_packet_receive_rc(router_state *s, tw_bf *bf, terminal_plus_m ...@@ -3845,9 +3856,6 @@ static void router_packet_receive_rc(router_state *s, tw_bf *bf, terminal_plus_m
router_rev_ecount++; router_rev_ecount++;
router_ecount--; router_ecount--;
msg->num_cll = 0;
msg->num_rngs = 0;
int output_port = msg->saved_vc; int output_port = msg->saved_vc;
int output_chan = msg->saved_channel; int output_chan = msg->saved_channel;
...@@ -3901,7 +3909,7 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -3901,7 +3909,7 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
int vcs_per_qos = s->params->num_vcs / num_qos_levels; int vcs_per_qos = s->params->num_vcs / num_qos_levels;
if(num_qos_levels > 1 && !s->is_monitoring_bw) if(num_qos_levels > 1 && (s->is_monitoring_bw == 0))
bf->c1 = 1; bf->c1 = 1;
...@@ -4094,6 +4102,15 @@ static void router_packet_send_rc(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -4094,6 +4102,15 @@ static void router_packet_send_rc(router_state *s, tw_bf *bf, terminal_plus_mess
terminal_plus_message_list *cur_entry = (terminal_plus_message_list *) rc_stack_pop(s->st); terminal_plus_message_list *cur_entry = (terminal_plus_message_list *) rc_stack_pop(s->st);
assert(cur_entry); assert(cur_entry);
int vcg = get_vcg_from_category(&(cur_entry->msg));
int msg_size = s->params->chunk_size;
if(cur_entry->msg.packet_size < s->params->chunk_size)
msg_size = cur_entry->msg.packet_size;
s->qos_data[output_port][vcg] -= msg_size;
s->next_output_available_time[output_port] = msg->saved_available_time;
if (bf->c11) { if (bf->c11) {
s->link_traffic[output_port] -= cur_entry->msg.packet_size % s->params->chunk_size; s->link_traffic[output_port] -= cur_entry->msg.packet_size % s->params->chunk_size;
s->link_traffic_sample[output_port] -= cur_entry->msg.packet_size % s->params->chunk_size; s->link_traffic_sample[output_port] -= cur_entry->msg.packet_size % s->params->chunk_size;
...@@ -4102,7 +4119,6 @@ static void router_packet_send_rc(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -4102,7 +4119,6 @@ static void router_packet_send_rc(router_state *s, tw_bf *bf, terminal_plus_mess
s->link_traffic[output_port] -= s->params->chunk_size; s->link_traffic[output_port] -= s->params->chunk_size;
s->link_traffic_sample[output_port] -= s->params->chunk_size; s->link_traffic_sample[output_port] -= s->params->chunk_size;
prepend_to_terminal_plus_message_list(s->pending_msgs[output_port], s->pending_msgs_tail[output_port], prepend_to_terminal_plus_message_list(s->pending_msgs[output_port], s->pending_msgs_tail[output_port],
output_chan, cur_entry); output_chan, cur_entry);
...@@ -4184,7 +4200,7 @@ static void router_packet_send(router_state *s, tw_bf *bf, terminal_plus_message ...@@ -4184,7 +4200,7 @@ static void router_packet_send(router_state *s, tw_bf *bf, terminal_plus_message
uint64_t num_chunks = cur_entry->msg.packet_size / s->params->chunk_size; uint64_t num_chunks = cur_entry->msg.packet_size / s->params->chunk_size;
if (msg->packet_size < s->params->chunk_size) if (cur_entry->msg.packet_size < s->params->chunk_size)
double bytetime = delay; double bytetime = delay;
...@@ -4318,6 +4334,9 @@ static void router_buf_update_rc(router_state *s, tw_bf *bf, terminal_plus_messa ...@@ -4318,6 +4334,9 @@ static void router_buf_update_rc(router_state *s, tw_bf *bf, terminal_plus_messa
/* Update the buffer space associated with this router LP */ /* Update the buffer space associated with this router LP */
static void router_buf_update(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp) static void router_buf_update(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp)
msg->num_cll = 0;
msg->num_rngs = 0;
int indx = msg->vc_index; int indx = msg->vc_index;
int output_chan = msg->output_chan; int output_chan = msg->output_chan;
s->vc_occupancy[indx][output_chan] -= s->params->chunk_size; s->vc_occupancy[indx][output_chan] -= s->params->chunk_size;
...@@ -4333,6 +4352,8 @@ static void router_buf_update(router_state *s, tw_bf *bf, terminal_plus_message ...@@ -4333,6 +4352,8 @@ static void router_buf_update(router_state *s, tw_bf *bf, terminal_plus_message
if (s->queued_msgs[indx][output_chan] != NULL) { if (s->queued_msgs[indx][output_chan] != NULL) {
assert(indx < s->params->radix);
assert(output_chan < s->params->num_vcs);
terminal_plus_message_list *head = terminal_plus_message_list *head =
return_head(s->queued_msgs[indx], s->queued_msgs_tail[indx], output_chan); return_head(s->queued_msgs[indx], s->queued_msgs_tail[indx], output_chan);
router_credit_send(s, &head->msg, lp, 1, &(msg->num_rngs)); router_credit_send(s, &head->msg, lp, 1, &(msg->num_rngs));
Markdown is supported
0% or .
Please register or to comment
