Commit c46acea7 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Rewrite dragonfly-plus routing to match intel rec
parent 92a2f13d
...@@ -43,6 +43,11 @@ struct Connection ...@@ -43,6 +43,11 @@ struct Connection
ConnectionType conn_type; //type of the connection: CONN_LOCAL, CONN_GLOBAL, or CONN_TERMINAL ConnectionType conn_type; //type of the connection: CONN_LOCAL, CONN_GLOBAL, or CONN_TERMINAL
inline bool operator<(const Connection& lhs, const Connection& rhs)
return lhs.port < rhs.port;
* @class ConnectionManager * @class ConnectionManager
...@@ -157,6 +157,21 @@ static void delete_terminal_plus_message_list(void *thisO) ...@@ -157,6 +157,21 @@ static void delete_terminal_plus_message_list(void *thisO)
free(toDel); free(toDel);
template <class T>
vector< T > set_difference_vectors(vector<T> vec1, vector<T> vec2)
int max_len = std::max(vec1.size(), vec2.size());
vector< T > retVec(max_len);
typename vector< T >::iterator retIt;
retIt = std::set_difference(vec1.begin(), vec1.end(), vec2.begin(), vec2.end(), retVec.begin());
retVec.resize(retIt - retVec.begin());
return retVec;
struct dragonfly_plus_param struct dragonfly_plus_param
// configuration parameters // configuration parameters
...@@ -608,7 +623,7 @@ void dragonfly_plus_print_params(const dragonfly_plus_param *p) ...@@ -608,7 +623,7 @@ void dragonfly_plus_print_params(const dragonfly_plus_param *p)
printf("\tnum_router_spine = %d\n",p->num_router_spine); printf("\tnum_router_spine = %d\n",p->num_router_spine);
printf("\tnum_router_leaf = %d\n",p->num_router_leaf); printf("\tnum_router_leaf = %d\n",p->num_router_leaf);
printf("\tadaptive_threshold = %d\n",p->adaptive_threshold); printf("\tadaptive_threshold = %d\n",p->adaptive_threshold);
printf("\tmax_port_score = %d\n",p->max_port_score); printf("\tmax_port_score = %ld\n",p->max_port_score);
printf("\tnum_groups = %d\n",p->num_groups); printf("\tnum_groups = %d\n",p->num_groups);
printf("\tradix = %d\n",p->radix); printf("\tradix = %d\n",p->radix);
printf("\ttotal_routers = %d\n",p->total_routers); printf("\ttotal_routers = %d\n",p->total_routers);
...@@ -2667,7 +2682,7 @@ static int dfp_pick_intermediate_router_with_conn(router_state *s, tw_bf *bf, te ...@@ -2667,7 +2682,7 @@ static int dfp_pick_intermediate_router_with_conn(router_state *s, tw_bf *bf, te
return intm_router_id; return intm_router_id;
static int dfp_reselect_intermediate_router(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, int origin_group_id, int fdest_group_id) static void dfp_reselect_intermediate_router(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, int origin_group_id, int fdest_group_id)
assert(s->params->source_group_rerouting == 0); //this method should only be called if rerouting isn't allowed assert(s->params->source_group_rerouting == 0); //this method should only be called if rerouting isn't allowed
if (s->params->intermediate_router_choice == INT_CHOICE_SPINE) { //then we care about having a connection to the actual spine router if (s->params->intermediate_router_choice == INT_CHOICE_SPINE) { //then we care about having a connection to the actual spine router
...@@ -2858,72 +2873,80 @@ static Connection get_best_connection_from_conns(router_state *s, tw_bf *bf, ter ...@@ -2858,72 +2873,80 @@ static Connection get_best_connection_from_conns(router_state *s, tw_bf *bf, ter
return selected_conns[best_score_index]; return selected_conns[best_score_index];
static vector< Connection > get_possible_stops_to_specific_router(router_state *s,
tw_bf *bf, //Returns a vector of connections that are legal dragonfly plus routes that specifically would not allow for a minimal connection to the specific router specified in get_possible_stops_to_specific_router()
terminal_plus_message *msg, //Be very wary of using this method, results may not make sense if possible_minimal_stops is not a vector of minimal next stops to fdest_rotuer_id
tw_lp *lp, //Nonminimal specifically refers to any move that does not move directly toward the destination router
int specific_router_id) static vector< Connection > get_legal_nonminimal_stops(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, vector< Connection > possible_minimal_stops, int fdest_router_id)
int my_router_id = s->router_id; int my_router_id = s->router_id;
int my_group_id = s->router_id / s->params->num_routers; int my_group_id = s->router_id / s->params->num_routers;
int specific_group_id = specific_router_id / s->params->num_routers; int origin_group_id = msg->origin_router_id / s->params->num_routers;
router_type specific_router_type = router_type_map[specific_router_id]; int fdest_group_id = fdest_router_id / s->params->num_routers;
bool in_intermediate_group = (my_group_id != origin_group_id) && (my_group_id != fdest_group_id);
// if (specific_router_type == SPINE)
// tw_error(TW_LOC, "ROUTING TO SPINE NOT SUPPORTED\n"); //TODO when picking intm_rtr_id at the origin leaf, we need to pick a spine router that has a direct connection to our group!
vector< Connection > possible_next_conns; vector< Connection > possible_nonminimal_stops;
if (my_router_id == specific_router_id) { if (my_group_id == origin_group_id) { //then we're just sending upward out of the group
return possible_next_conns; //we're there so theres no need to go further. return empty - routing should check if we've arrived before calling this method if (s->dfp_router_type == LEAF) { //then any connections to spines that are not in possible_minimal_stops should be included
vector< Connection > conns_to_spines = s->connMan->get_connections_by_type(CONN_LOCAL);
possible_nonminimal_stops = set_difference_vectors(conns_to_spines, possible_minimal_stops); //get the complement of possible_minimal_stops
else if (s->dfp_router_type == SPINE) { //then we have to send via global connections that aren't to the dest group
vector< Connection > conns_to_other_groups = s->connMan->get_connections_by_type(CONN_GLOBAL);
possible_nonminimal_stops = set_difference_vectors(conns_to_other_groups, possible_minimal_stops);
else if (my_group_id == specific_group_id) { else if (in_intermediate_group) {
if (msg->dfp_upward_channel_flag == 1) { //then we return an empty vector as the only legal moves are those that already exist in possible_minimal_stops
if (s->dfp_router_type == SPINE) { //we are spine and we are not the specific router assert(possible_nonminimal_stops.size() == 0);
if (specific_router_type == SPINE) { //the specific router is a spine and we're not it so then we need to send to one of our leafs first on local return possible_nonminimal_stops;
possible_next_conns = s->connMan->get_connections_by_type(CONN_LOCAL);
else { // Then the spec router's a leaf and we have a local connection to the specific router on local
assert(specific_router_type == LEAF);
possible_next_conns = s->connMan->get_connections_to_gid(specific_router_id, CONN_LOCAL);
else { //we're a leaf in the specific router group else if (s->dfp_router_type == LEAF) { //if we're a leaf in an intermediate group then the routing alg should have flipped the dfp_upward channel already but lets return empty just in case
assert(s->dfp_router_type == LEAF); assert(possible_nonminimal_stops.size() == 0);
if (specific_router_type == SPINE) { //Then we have a local connection to the specific router on local return possible_nonminimal_stops;
possible_next_conns = s->connMan->get_connections_to_gid(specific_router_id, CONN_LOCAL); }
} else if (s->dfp_router_type == SPINE) { //then possible_minimal_stops will be the list of connections
else { //then the specific router is a leaf within our group and we need to send to one of our spines first assert(msg->dfp_upward_channel_flag == 0);
assert(specific_router_type == LEAF); vector< Connection> conns_to_leaves = s->connMan->get_connections_by_type(CONN_LOCAL);
possible_next_conns = s->connMan->get_connections_by_type(CONN_LOCAL); possible_nonminimal_stops = set_difference_vectors(conns_to_leaves, possible_minimal_stops); //get the complement of possible_minimal_stops
else {
tw_error(TW_LOC, "Impossible Error - Something's majorly wrong if this is tripped");
else if (my_group_id == fdest_group_id) {
assert(possible_nonminimal_stops.size() == 0); //empty because all legal stops within the destination group are minimal
else {
tw_error(TW_LOC, "Invalid group classification\n");
else { //then we are not the specific router, nor are we in the specific router's group.
if (s->dfp_router_type == SPINE) { //then we need to send to the specific group if we have a connection, otherwise we send to a leaf in our group
// if (specific_router_type == SPINE) { //then it's not good enough to just send to the specific group, we have to send to the specific router
// vector< Connection > conns_to_spec_router = s->connMan->get_connections_to_gid(specific_router_id, CONN_GLOBAL);
// if (conns_to_spec_router.size() < 1)
// tw_error(TW_LOC, "Failed to find a connection to specific router\n");
// possible_next_conns = conns_to_spec_router;
vector< Connection > conns_to_spec_group = s->connMan->get_connections_to_group(specific_group_id);
if (conns_to_spec_group.size() < 1) { //then we have to send to a leaf on local
else { //then we can send to the specific group via global conn
possible_next_conns = conns_to_spec_group;
} // assert(possible_nonminimal_stops.size() > 0);
else { //then we are a leaf and need to send to a spine that has a connection to the spec router group return possible_nonminimal_stops;
assert(s->dfp_router_type == LEAF); }
//The term minimal in this case refers to "Moving toward destination router". If a packet is at an intermediate spine and that spine doesn't
//have a direct connection to the destinatino group, then there wouldn't be any "legal minimal stops". The packet would have to continue to
//some leaf in the group first. THIS DOES NOT INCLUDE REROUTING. The only time an intermediate leaf can send to an intermediate spine is if
//dfp_upward_channel_flag is 0.
static vector< Connection > get_legal_minimal_stops(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, int fdest_router_id)
if (my_group_id != fdest_group_id) { //then we're in the source or the intermediate group.
vector< Connection> possible_next_conns_to_group; vector< Connection> possible_next_conns_to_group;
set<int> poss_router_id_set_to_group; set<int> poss_router_id_set_to_group;
for(int i = 0; i < connectionList[my_group_id][specific_group_id].size(); i++) for(int i = 0; i < connectionList[my_group_id][fdest_group_id].size(); i++)
int poss_router_id = connectionList[my_group_id][specific_group_id][i]; int poss_router_id = connectionList[my_group_id][fdest_group_id][i];
// printf("%d\n",poss_router_id); // printf("%d\n",poss_router_id);
if (poss_router_id_set_to_group.count(poss_router_id) == 0) { //if we haven't added the connections from poss_router_id yet if (poss_router_id_set_to_group.count(poss_router_id) == 0) { //if we haven't added the connections from poss_router_id yet
vector< Connection > conns = s->connMan->get_connections_to_gid(poss_router_id, CONN_LOCAL); vector< Connection > conns = s->connMan->get_connections_to_gid(poss_router_id, CONN_LOCAL);
...@@ -2931,36 +2954,37 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state * ...@@ -2931,36 +2954,37 @@ static vector< Connection > get_possible_stops_to_specific_router(router_state *
possible_next_conns_to_group.insert(possible_next_conns_to_group.end(), conns.begin(), conns.end()); possible_next_conns_to_group.insert(possible_next_conns_to_group.end(), conns.begin(), conns.end());
if (possible_next_conns_to_group.size() < 1) return possible_next_conns_to_group;
tw_error(TW_LOC, "Something went wrong when trying to send to a spine with connection to spec group\n"); }
// if (specific_router_type == SPINE) { //then its not good enough to just send to a spine with a connection to the group, it has to go to a spine that has a direct conn to the spec router id return s->connMan->get_connections_to_group(fdest_group_id);
// for(int i = 0; i < possible_next_conns_to_group.size(); i++) }
// Connection poss_next_spine = possible_next_conns_to_group[i]; else {
// vector< Connection> connecting_conns_to_spec = connManagerList[poss_next_spine.dest_gid].get_connections_to_gid(specific_router_id, CONN_GLOBAL); assert(my_group_id == fdest_group_id);
// if (connecting_conns_to_spec.size() > 0) { //then poss_next_spine is a valid next stop, add my connections to it as possible next stops if (s->dfp_router_type == SPINE) {
// possible_next_conns.push_back(poss_next_spine); vector< Connection > possible_next_conns = s->connMan->get_connections_to_gid(fdest_router_id, CONN_LOCAL);
// } return possible_next_conns;
// } else {
if (specific_router_type == SPINE) { //for now let's allow our spine routers to just send to the group, let them route it to the spec router assert(s->dfp_router_type == LEAF);
possible_next_conns = possible_next_conns_to_group;
if (my_router_id != fdest_router_id) { //then we're also the source group and we need to send to any spine in our group
assert(my_group_id == origin_group_id);
return s->connMan->get_connections_by_type(CONN_LOCAL);
else { //then just sending to the group is good enough else { //then we're the dest router
possible_next_conns = possible_next_conns_to_group; assert(my_router_id == fdest_router_id);
vector< Connection > empty;
return empty;
if (possible_next_conns.size() < 1) return empty;
tw_error(TW_LOC,"didn't pick any possible next stops!\n");
//always uses 4 rngs
static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, int fdest_router_id) static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, int fdest_router_id)
...@@ -2972,14 +2996,14 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -2972,14 +2996,14 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
int adaptive_threshold = s->params->adaptive_threshold; int adaptive_threshold = s->params->adaptive_threshold;
bool next_hop_is_global = false; bool next_hop_is_global = false;
if (msg->intm_rtr_id == my_router_id) //then we are the intermediate router and need to forward to fdest on the upward channel (VL 1)
msg->dfp_upward_channel_flag = 1;
//The check for dest group local routing has already been completed at this point //The check for dest group local routing has already been completed at this point
Connection nextStopConn; Connection nextStopConn;
vector< Connection > poss_min_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); vector< Connection > poss_min_next_stops = get_legal_minimal_stops(s, bf, msg, lp, fdest_router_id);
vector< Connection > poss_intm_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id); vector< Connection > poss_intm_next_stops = get_legal_nonminimal_stops(s, bf, msg, lp, poss_min_next_stops, fdest_router_id);
if ( (poss_min_next_stops.size() == 0) && (poss_intm_next_stops.size() == 0))
tw_error(TW_LOC, "No possible next stops!!!");
Connection best_min_conn, best_intm_conn; Connection best_min_conn, best_intm_conn;
ConnectionType conn_type_of_mins, conn_type_of_intms; ConnectionType conn_type_of_mins, conn_type_of_intms;
...@@ -3000,7 +3024,6 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -3000,7 +3024,6 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
else else
best_intm_conn = get_absolute_best_connection_from_conns(s, bf, msg, lp, poss_intm_next_stops); best_intm_conn = get_absolute_best_connection_from_conns(s, bf, msg, lp, poss_intm_next_stops);
//if the best is intermediate, encode the intermediate router id in the message, set path type to non minimal //if the best is intermediate, encode the intermediate router id in the message, set path type to non minimal
int min_score = dfp_score_connection(s, bf, msg, lp, best_min_conn, C_MIN); int min_score = dfp_score_connection(s, bf, msg, lp, best_min_conn, C_MIN);
int intm_score = dfp_score_connection(s, bf, msg, lp, best_intm_conn, C_NONMIN); int intm_score = dfp_score_connection(s, bf, msg, lp, best_intm_conn, C_NONMIN);
...@@ -3010,37 +3033,39 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi ...@@ -3010,37 +3033,39 @@ static Connection do_dfp_prog_adaptive_routing(router_state *s, tw_bf *bf, termi
route_to_fdest = true; route_to_fdest = true;
else { else {
if (msg->path_type == MINIMAL) { //we need to evaluate whether to stay on the minimal path or deviate if (scoring_preference == LOWER) {
if (scoring_preference == LOWER) { if (min_score <= adaptive_threshold) {
if (min_score <= adaptive_threshold) { route_to_fdest = true;
// printf("CHOOSE MIN: Min Score=%d\tNonmin Score=%d (Adaptive Threshold =%d)\n",min_score, intm_score,adaptive_threshold);
else if (min_score <= intm_score) {
// printf("CHOOSE MIN: Min Score=%d\tNonmin Score=%d\n",min_score, intm_score);
else { //Changing to a nonminimal path!
// printf("CHOOSE NONMIN: Min Score=%d\tNonmin Score=%d\n",min_score, intm_score);
msg->path_type = NON_MINIMAL;
else { //HIGHER is better else if (min_score <= intm_score) {
if (adaptive_threshold > 0) route_to_fdest = true;
tw_error(TW_LOC, "Adaptive threshold not compatible with HIGHER score preference yet\n"); //TODO fix this }
if (min_score >= intm_score) { else { //Changing to a nonminimal path!
route_to_fdest = true; msg->path_type = NON_MINIMAL;
else { //changing to a nonminimal path! }
msg->path_type = NON_MINIMAL; else { //HIGHER is better
} if (adaptive_threshold > 0)
//we don't need to do anything if the path type is already non-minimal. "Don't revisit decision to route non-minimally after it's been made to be non-minimal"
if (route_to_fdest && (poss_min_next_stops.size() == 0))
route_to_fdest = false;
if (route_to_fdest && (poss_intm_next_stops.size() == 0))
if (route_to_fdest){ if (route_to_fdest){
if (in_intermediate_group == true)
msg->dfp_upward_channel_flag = 1; //if we're in an intermediate group and take a turn toward the dest group, we flip the flag!
nextStopConn = best_min_conn; nextStopConn = best_min_conn;
else { else {
...@@ -3063,15 +3088,15 @@ static Connection do_dfp_routing(router_state *s, ...@@ -3063,15 +3088,15 @@ static Connection do_dfp_routing(router_state *s,
int origin_group_id = msg->origin_router_id / s->params->num_routers; int origin_group_id = msg->origin_router_id / s->params->num_routers;
bool in_intermediate_group = (my_group_id != origin_group_id) && (my_group_id != fdest_group_id); bool in_intermediate_group = (my_group_id != origin_group_id) && (my_group_id != fdest_group_id);
if (s->router_id == msg->origin_router_id) { //then we havent picked an intermediate router yet // if (s->router_id == msg->origin_router_id) { //then we havent picked an intermediate router yet
msg->intm_rtr_id = dfp_pick_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id); // msg->intm_rtr_id = dfp_pick_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id);
if ( (my_group_id == origin_group_id) && (s->dfp_router_type == SPINE) ) { // if ( (my_group_id == origin_group_id) && (s->dfp_router_type == SPINE) ) {
if (s->params->source_group_rerouting == 0 && isRoutingAdaptive(routing)) { //if we cannot reroute within our source group, we have to pick a new intermediate router // if (s->params->source_group_rerouting == 0 && isRoutingAdaptive(routing)) { //if we cannot reroute within our source group, we have to pick a new intermediate router
dfp_reselect_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id); //alters msg->intm_rtr_id to be more appropriate // dfp_reselect_intermediate_router(s, bf, msg, lp, origin_group_id, fdest_group_id); //alters msg->intm_rtr_id to be more appropriate
Connection nextStopConn; //the connection that we will forward the packet to Connection nextStopConn; //the connection that we will forward the packet to
...@@ -3084,7 +3109,7 @@ static Connection do_dfp_routing(router_state *s, ...@@ -3084,7 +3109,7 @@ static Connection do_dfp_routing(router_state *s,
return best_min_conn; return best_min_conn;
else if (my_group_id == fdest_group_id) { //then we just route minimally else if (my_group_id == fdest_group_id) { //then we just route minimally
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); vector< Connection > poss_next_stops = get_legal_minimal_stops(s, bf, msg, lp, fdest_router_id);
if (poss_next_stops.size() < 1) if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "DEAD END WHEN ROUTING LOCALLY\n"); tw_error(TW_LOC, "DEAD END WHEN ROUTING LOCALLY\n");
...@@ -3102,7 +3127,7 @@ static Connection do_dfp_routing(router_state *s, ...@@ -3102,7 +3127,7 @@ static Connection do_dfp_routing(router_state *s,
else if (isRoutingMinimal(routing)) { else if (isRoutingMinimal(routing)) {
tw_error(TW_LOC, "MINIMAL DEAD END\n"); tw_error(TW_LOC, "MINIMAL DEAD END\n");
...@@ -3116,47 +3141,35 @@ static Connection do_dfp_routing(router_state *s, ...@@ -3116,47 +3141,35 @@ static Connection do_dfp_routing(router_state *s,
else { //routing algorithm is specified in routing else { //routing algorithm is specified in routing
assert( (routing == NON_MINIMAL_LEAF) || (routing == NON_MINIMAL_SPINE) );
bool route_to_fdest = false; bool route_to_fdest = false;
if (routing == NON_MINIMAL_LEAF) {
if(s->dfp_router_type == LEAF) { if (msg->dfp_upward_channel_flag == 1) //we only route to minimal if this flag is true, otherwise we keep routing nonminimally
if (s->router_id == msg->intm_rtr_id) { //then we are the intermediate router
msg->dfp_upward_channel_flag = 1; //from here on the packet should be routed to fdest_router_id
else if (msg->dfp_upward_channel_flag == 1) { //then we have already visited the intermediate router else if (s->dfp_router_type == LEAF) {
route_to_fdest = true; if (in_intermediate_group) { //then we are the intermediate router
} msg->dfp_upward_channel_flag = 1;
else { //then we still need to go to the intermediate router route_to_fdest = true;
//do nothing for now }
if (msg->intm_rtr_id == -1)
tw_error(TW_LOC, "intm router id not set!");
else { else if (routing == NON_MINIMAL_SPINE) {
assert(s->dfp_router_type == SPINE); tw_error(TW_LOC, "nonminimal spine routing not yet supported");
vector< Connection > poss_next_stops; vector< Connection > poss_next_stops;
if (route_to_fdest) { if (route_to_fdest) {
poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); poss_next_stops = poss_min_next_stops;
tw_error(TW_LOC, "Dead end when finding stops to fdest router"); tw_error(TW_LOC, "Dead end when finding stops to fdest router");
else { //then we need to be going toward the intermediate router else { //then we need to be going toward the intermediate router
msg->path_type = NON_MINIMAL; msg->path_type = NON_MINIMAL;
poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id); poss_next_stops = poss_intm_next_stops;
tw_error(TW_LOC, "Dead end when finding stops to intermediate router"); tw_error(TW_LOC, "Dead end when finding stops to intermediate router");
...@@ -3329,7 +3342,7 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -3329,7 +3342,7 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
Connection next_stop_conn = do_dfp_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id); Connection next_stop_conn = do_dfp_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id);
if (s->connMan->is_any_connection_to(next_stop_conn.dest_gid) == false) if (s->connMan->is_any_connection_to(next_stop_conn.dest_gid) == false)
tw_error(TW_LOC, "Router does not have a connection to chosen destination\n"); tw_error(TW_LOC, "Router %d does not have a connection to chosen destination %d\n", s->router_id, next_stop_conn.dest_gid);
output_port = next_stop_conn.port; output_port = next_stop_conn.port;
Markdown is supported
0% or .
Please register or to comment
