Commit c3f2c08e authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
uncrustify config and reformatting tool
parent a28856ca
#!/bin/bash
script_dir="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
function error () {
echo "ERROR: $@" >&2
exit 1
function usage() {
cat \
<<EOF
USAGE: reformat.sh [-x] [-i] [-c CFG] [-b FILE] {-a | FILE...}
-i: perform in-place (will ask to confirm if being done recursively)
-c CFG: use CFG as the uncrustify config (default: $script_dir/uc-codes.cfg)
-b FILE[,...]: add FILE to the blacklist of directories (in the form *FILE/*)
multiple files can be added by separating with commas
-a: perform recursively on all files ending in .c or .h
if -a not provided, then perform on all files passed in
-x: instead of formatting, check if output format is the same as input
EOF
function build_blacklist() {
for x in $@ ; do
echo -n "-and -not -path \*$x/\* "
done
function getfiles() {
find . \( -name \*.c -or -name \*.h \) $(build_blacklist $@)
cfg=$script_dir/uc-codes.cfg
which uncrustify > /dev/null 2>&1 || error "uncrustify not found"
do_inplace=no
do_recursive=no
do_check=no
blacklist=
while getopts ":ib:ax" opt; do
case $opt in
i)
do_inplace=yes
b)
blacklist=$(cat $OPTARG | sed s/,/ /g)
c)
cfg=$OPTARG
a)
do_recursive=yes
x)
do_check=yes
usage
error "invalid argument: -$OPTARG"
esac
done
shift $((OPTIND-1))
[[ -e $cfg ]] || ( usage && error "config file $cfg not found" )
[[ $# -gt 0 && $do_recursive == yes ]] && \
usage && error "no file args expected in recursive mode"
[[ $# -eq 0 && $do_recursive == no ]] && \
usage && error "expected file args in non-recursive mode"
if [[ $do_recursive == yes ]] ; then
file_list="$(getfiles $blacklist)"
else
file_list="$@"
fi
if [[ $do_recursive == yes && $do_inplace == yes ]] ; then
echo -n "Do recursive in-place reformat? (y/n) "
read answer
[[ $answer =~ "[^y].*" ]] && echo "...aborting reformat" && exit 1
fi
[[ $do_inplace == yes ]] \
&& output_arg="--replace" \
|| output_arg=
if [[ $do_check == yes ]] ; then
check_arg=--check
output_arg=
echo "checking format..."
else
check_arg=
fi
function echolines () {
for x in $@ ; do echo $x ; done
echolines $file_list | uncrustify $check_arg -c $cfg $output_arg -F -
# Uncrustify 0.61
# General options
# The type of line endings
newlines = auto # auto/lf/crlf/cr
# Allow interpreting '>=' and '>>=' as part of a template in 'void f(list<list<B>>=val);'.
# If true (default), 'assert(x<0 && y>=3)' will be broken.
# Improvements to template detection may make this option obsolete.
tok_split_gte = false # false/true
# Control what to do with the UTF-8 BOM (recommend 'remove')
utf8_bom = remove # ignore/add/remove/force
# If the file contains bytes with values between 128 and 255, but is not UTF-8, then output as UTF-8
utf8_byte = false # false/true
# Force the output encoding to UTF-8
utf8_force = false # false/true
# Indenting
# The number of columns to indent per level.
# Usually 2, 3, 4, or 8.
indent_columns = 4 # number
# The continuation indent. If non-zero, this overrides the indent of '(' and '=' continuation indents.
# For FreeBSD, this is set to 4. Negative value is absolute and not increased for each ( level
indent_continue = 8 # number
# How to use tabs when indenting code
# 0=spaces only
# 1=indent with tabs to brace level, align with spaces
# 2=indent and align with tabs, using spaces when not on a tabstop
indent_with_tabs = 0 # number
# Comments that are not a brace level are indented with tabs on a tabstop.
# Requires indent_with_tabs=2. If false, will use spaces.
indent_cmt_with_tabs = false # false/true
# Whether to indent strings broken by '\' so that they line up
indent_align_string = false # false/true
# Spaces to indent '{' from level
indent_brace = 0 # number
# Whether braces are indented to the body level
indent_braces = false # false/true
# Indent based on the paren open instead of the brace open in '({\n', default is to indent by brace.
indent_paren_open_brace = false # false/true
# Whether the 'namespace' body is indented
indent_namespace = false # false/true
# Only indent one namespace and no sub-namepaces.
# Requires indent_namespace=true.
indent_namespace_single_indent = false # false/true
# The number of spaces to indent a namespace block
indent_namespace_level = 0 # number
# If the body of the namespace is longer than this number, it won't be indented.
# Requires indent_namespace=true. Default=0 (no limit)
indent_namespace_limit = 0 # number
# Whether the 'extern "C"' body is indented
indent_extern = false # false/true
# Whether the 'class' body is indented
indent_class = false # false/true
# Whether to indent the stuff after a leading base class colon
indent_class_colon = false # false/true
# Whether to indent the stuff after a leading class initializer colon
indent_constr_colon = false # false/true
# Virtual indent from the ':' for member initializers. Default is 2
indent_ctor_init_leading = 2 # number
# Additional indenting for constructor initializer list
indent_ctor_init = 0 # number
# False=treat 'else\nif' as 'else if' for indenting purposes
# True=indent the 'if' one level
indent_else_if = false # false/true
# Amount to indent variable declarations after a open brace. neg=relative, pos=absolute
indent_var_def_blk = 0 # number
# Indent continued variable declarations instead of aligning.
indent_var_def_cont = false # false/true
# True: force indentation of function definition to start in column 1
# False: use the default behavior
indent_func_def_force_col1 = false # false/true
# True: indent continued function call parameters one indent level
# False: align parameters under the open paren
indent_func_call_param = true # false/true
# Same as indent_func_call_param, but for function defs
indent_func_def_param = true # false/true
# Same as indent_func_call_param, but for function protos
indent_func_proto_param = true # false/true
# Same as indent_func_call_param, but for class declarations
indent_func_class_param = false # false/true
# Same as indent_func_call_param, but for class variable constructors
indent_func_ctor_var_param = false # false/true
# Same as indent_func_call_param, but for templates
indent_template_param = false # false/true
# Double the indent for indent_func_xxx_param options
indent_func_param_double = true # false/true
# Indentation column for standalone 'const' function decl/proto qualifier
indent_func_const = 0 # number
# Indentation column for standalone 'throw' function decl/proto qualifier
indent_func_throw = 0 # number
# The number of spaces to indent a continued '->' or '.'
# Usually set to 0, 1, or indent_columns.
indent_member = 0 # number
# Spaces to indent single line ('//') comments on lines before code
indent_sing_line_comments = 0 # number
# If set, will indent trailing single line ('//') comments relative
# to the code instead of trying to keep the same absolute column
indent_relative_single_line_comments = true # false/true
# Spaces to indent 'case' from 'switch'
# Usually 0 or indent_columns.
indent_switch_case = indent_columns # number
# Spaces to shift the 'case' line, without affecting any other lines
# Usually 0.
indent_case_shift = 0 # number
# Spaces to indent '{' from 'case'.
# By default, the brace will appear under the 'c' in case.
# Usually set to 0 or indent_columns.
indent_case_brace = 0 # number
# Whether to indent comments found in first column
indent_col1_comment = true # false/true
# How to indent goto labels
# >0 : absolute column where 1 is the leftmost column
# <=0 : subtract from brace indent
indent_label = 1 # number
# Same as indent_label, but for access specifiers that are followed by a colon
indent_access_spec = 1 # number
# Indent the code after an access specifier by one level.
# If set, this option forces 'indent_access_spec=0'
indent_access_spec_body = false # false/true
# If an open paren is followed by a newline, indent the next line so that it lines up after the open paren (not recommended)
indent_paren_nl = false # false/true
# Controls the indent of a close paren after a newline.
# 0: Indent to body level
# 1: Align under the open paren
# 2: Indent to the brace level
indent_paren_close = 0 # number
# Controls the indent of a comma when inside a paren.If TRUE, aligns under the open paren
indent_comma_paren = false # false/true
# Controls the indent of a BOOL operator when inside a paren.If TRUE, aligns under the open paren
indent_bool_paren = false # false/true
# If 'indent_bool_paren' is true, controls the indent of the first expression. If TRUE, aligns the first expression to the following ones
indent_first_bool_expr = false # false/true
# If an open square is followed by a newline, indent the next line so that it lines up after the open square (not recommended)
indent_square_nl = false # false/true
# Don't change the relative indent of ESQL/C 'EXEC SQL' bodies
indent_preserve_sql = false # false/true
# Align continued statements at the '='. Default=True
# If FALSE or the '=' is followed by a newline, the next line is indent one tab.
indent_align_assign = true # false/true
# Spacing options
# Add or remove space around arithmetic operator '+', '-', '/', '*', etc
sp_arith = ignore # ignore/add/remove/force
# Add or remove space around assignment operator '=', '+=', etc
sp_assign = ignore # ignore/add/remove/force
# Add or remove space around '=' in C++11 lambda capture specifications. Overrides sp_assign
sp_cpp_lambda_assign = ignore # ignore/add/remove/force
# Add or remove space after the capture specification in C++11 lambda.
sp_cpp_lambda_paren = ignore # ignore/add/remove/force
# Add or remove space around assignment operator '=' in a prototype
sp_assign_default = ignore # ignore/add/remove/force
# Add or remove space before assignment operator '=', '+=', etc. Overrides sp_assign.
sp_before_assign = ignore # ignore/add/remove/force
# Add or remove space after assignment operator '=', '+=', etc. Overrides sp_assign.
sp_after_assign = ignore # ignore/add/remove/force
# Add or remove space in 'NS_ENUM ('
sp_enum_paren = ignore # ignore/add/remove/force
# Add or remove space around assignment '=' in enum
sp_enum_assign = ignore # ignore/add/remove/force
# Add or remove space before assignment '=' in enum. Overrides sp_enum_assign.
sp_enum_before_assign = ignore # ignore/add/remove/force
# Add or remove space after assignment '=' in enum. Overrides sp_enum_assign.
sp_enum_after_assign = ignore # ignore/add/remove/force
# Add or remove space around preprocessor '##' concatenation operator. Default=Add
sp_pp_concat = add # ignore/add/remove/force
# Add or remove space after preprocessor '#' stringify operator. Also affects the '#@' charizing operator.
sp_pp_stringify = ignore # ignore/add/remove/force
# Add or remove space before preprocessor '#' stringify operator as in '#define x(y) L#y'.
sp_before_pp_stringify = ignore # ignore/add/remove/force
# Add or remove space around boolean operators '&&' and '||'
sp_bool = ignore # ignore/add/remove/force
# Add or remove space around compare operator '<', '>', '==', etc
sp_compare = ignore # ignore/add/remove/force
# Add or remove space inside '(' and ')'
sp_inside_paren = remove # ignore/add/remove/force
# Add or remove space between nested parens: '((' vs ') )'
sp_paren_paren = remove # ignore/add/remove/force
# Add or remove space between back-to-back parens: ')(' vs ') ('
sp_cparen_oparen = ignore # ignore/add/remove/force
# Whether to balance spaces inside nested parens
sp_balance_nested_parens = false # false/true
# Add or remove space between ')' and '{'
sp_paren_brace = add # ignore/add/remove/force
# Add or remove space before pointer star '*'
sp_before_ptr_star = add # ignore/add/remove/force
# Add or remove space before pointer star '*' that isn't followed by a variable name
# If set to 'ignore', sp_before_ptr_star is used instead.
sp_before_unnamed_ptr_star = ignore # ignore/add/remove/force
# Add or remove space between pointer stars '*'
sp_between_ptr_star = remove # ignore/add/remove/force
# Add or remove space after pointer star '*', if followed by a word.
sp_after_ptr_star = add # ignore/add/remove/force
# Add or remove space after pointer star '*', if followed by a qualifier.
sp_after_ptr_star_qualifier = add # ignore/add/remove/force
# Add or remove space after a pointer star '*', if followed by a func proto/def.
sp_after_ptr_star_func = add # ignore/add/remove/force
# Add or remove space after a pointer star '*', if followed by an open paren (function types).
sp_ptr_star_paren = ignore # ignore/add/remove/force
# Add or remove space before a pointer star '*', if followed by a func proto/def.
sp_before_ptr_star_func = ignore # ignore/add/remove/force
# Add or remove space before a reference sign '&'
sp_before_byref = ignore # ignore/add/remove/force
# Add or remove space before a reference sign '&' that isn't followed by a variable name
# If set to 'ignore', sp_before_byref is used instead.
sp_before_unnamed_byref = ignore # ignore/add/remove/force
# Add or remove space after reference sign '&', if followed by a word.
sp_after_byref = ignore # ignore/add/remove/force
# Add or remove space after a reference sign '&', if followed by a func proto/def.
sp_after_byref_func = ignore # ignore/add/remove/force
# Add or remove space before a reference sign '&', if followed by a func proto/def.
sp_before_byref_func = ignore # ignore/add/remove/force
# Add or remove space between type and word. Default=Force
sp_after_type = force # ignore/add/remove/force
# Add or remove space before the paren in the D constructs 'template Foo(' and 'class Foo('.
sp_before_template_paren = ignore # ignore/add/remove/force
# Add or remove space in 'template <' vs 'template<'.
# If set to ignore, sp_before_angle is used.
sp_template_angle = ignore # ignore/add/remove/force
# Add or remove space before '<>'
sp_before_angle = ignore # ignore/add/remove/force
# Add or remove space inside '<' and '>'
sp_inside_angle = ignore # ignore/add/remove/force
# Add or remove space after '<>'
sp_after_angle = ignore # ignore/add/remove/force
# Add or remove space between '<>' and '(' as found in 'new List<byte>();'
sp_angle_paren = ignore # ignore/add/remove/force
# Add or remove space between '<>' and a word as in 'List<byte> m;'
sp_angle_word = ignore # ignore/add/remove/force
# Add or remove space between '>' and '>' in '>>' (template stuff C++/C# only). Default=Add
sp_angle_shift = add # ignore/add/remove/force
# Permit removal of the space between '>>' in 'foo<bar<int> >' (C++11 only). Default=False
# sp_angle_shift cannot remove the space without this option.
sp_permit_cpp11_shift = false # false/true
# Add or remove space before '(' of 'if', 'for', 'switch', and 'while'
sp_before_sparen = ignore # ignore/add/remove/force
# Add or remove space inside if-condition '(' and ')'
sp_inside_sparen = remove # ignore/add/remove/force
# Add or remove space before if-condition ')'. Overrides sp_inside_sparen.
sp_inside_sparen_close = ignore # ignore/add/remove/force
# Add or remove space before if-condition '('. Overrides sp_inside_sparen.
sp_inside_sparen_open = ignore # ignore/add/remove/force
# Add or remove space after ')' of 'if', 'for', 'switch', and 'while'
sp_after_sparen = ignore # ignore/add/remove/force
# Add or remove space between ')' and '{' of 'if', 'for', 'switch', and 'while'
sp_sparen_brace = ignore # ignore/add/remove/force
# Add or remove space between 'invariant' and '(' in the D language.
sp_invariant_paren = ignore # ignore/add/remove/force
# Add or remove space after the ')' in 'invariant (C) c' in the D language.
sp_after_invariant_paren = ignore # ignore/add/remove/force
# Add or remove space before empty statement ';' on 'if', 'for' and 'while'
sp_special_semi = ignore # ignore/add/remove/force
# Add or remove space before ';'. Default=Remove
sp_before_semi = remove # ignore/add/remove/force
# Add or remove space before ';' in non-empty 'for' statements
sp_before_semi_for = ignore # ignore/add/remove/force
# Add or remove space before a semicolon of an empty part of a for statement.
sp_before_semi_for_empty = ignore # ignore/add/remove/force
# Add or remove space after ';', except when followed by a comment. Default=Add
sp_after_semi = add # ignore/add/remove/force
# Add or remove space after ';' in non-empty 'for' statements. Default=Force
sp_after_semi_for = force # ignore/add/remove/force
# Add or remove space after the final semicolon of an empty part of a for statement: for ( ; ; <here> ).
sp_after_semi_for_empty = ignore # ignore/add/remove/force
# Add or remove space before '[' (except '[]')
sp_before_square = ignore # ignore/add/remove/force
# Add or remove space before '[]'
sp_before_squares = ignore # ignore/add/remove/force
# Add or remove space inside a non-empty '[' and ']'
sp_inside_square = remove # ignore/add/remove/force
# Add or remove space after ','
sp_after_comma = ignore # ignore/add/remove/force
# Add or remove space before ','
sp_before_comma = remove # ignore/add/remove/force
# Add or remove space between an open paren and comma: '(,' vs '( ,'
sp_paren_comma = force # ignore/add/remove/force
# Add or remove space before the variadic '...' when preceded by a non-punctuator
sp_before_ellipsis = ignore # ignore/add/remove/force
# Add or remove space after class ':'
sp_after_class_colon = ignore # ignore/add/remove/force
# Add or remove space before class ':'
sp_before_class_colon = ignore # ignore/add/remove/force
# Add or remove space after class constructor ':'
sp_after_constr_colon = ignore # ignore/add/remove/force
# Add or remove space before class constructor ':'
sp_before_constr_colon = ignore # ignore/add/remove/force
# Add or remove space before case ':'. Default=Remove
sp_before_case_colon = remove # ignore/add/remove/force
# Add or remove space between 'operator' and operator sign
sp_after_operator = ignore # ignore/add/remove/force
# Add or remove space between the operator symbol and the open paren, as in 'operator ++('
sp_after_operator_sym = ignore # ignore/add/remove/force
# Add or remove space after C/D cast, i.e. 'cast(int)a' vs 'cast(int) a' or '(int)a' vs '(int) a'
sp_after_cast = ignore # ignore/add/remove/force
# Add or remove spaces inside cast parens
sp_inside_paren_cast = ignore # ignore/add/remove/force
# Add or remove space between the type and open paren in a C++ cast, i.e. 'int(exp)' vs 'int (exp)'
sp_cpp_cast_paren = ignore # ignore/add/remove/force
# Add or remove space between 'sizeof' and '('
sp_sizeof_paren = ignore # ignore/add/remove/force
# Add or remove space after the tag keyword (Pawn)
sp_after_tag = ignore # ignore/add/remove/force
# Add or remove space inside enum '{' and '}'
sp_inside_braces_enum = ignore # ignore/add/remove/force
# Add or remove space inside struct/union '{' and '}'
sp_inside_braces_struct = ignore # ignore/add/remove/force
# Add or remove space inside '{' and '}'
sp_inside_braces = ignore # ignore/add/remove/force
# Add or remove space inside '{}'
sp_inside_braces_empty = ignore # ignore/add/remove/force
# Add or remove space between return type and function name
# A minimum of 1 is forced except for pointer return types.
sp_type_func = ignore # ignore/add/remove/force
# Add or remove space between function name and '(' on function declaration
sp_func_proto_paren = ignore # ignore/add/remove/force
# Add or remove space between function name and '(' on function definition
sp_func_def_paren = ignore # ignore/add/remove/force
# Add or remove space inside empty function '()'
sp_inside_fparens = ignore # ignore/add/remove/force
# Add or remove space inside function '(' and ')'
sp_inside_fparen = ignore # ignore/add/remove/force
# Add or remove space inside the first parens in the function type: 'void (*x)(...)'
sp_inside_tparen = ignore # ignore/add/remove/force
# Add or remove between the parens in the function type: 'void (*x)(...)'
sp_after_tparen_close = ignore # ignore/add/remove/force
# Add or remove space between ']' and '(' when part of a function call.
sp_square_fparen = ignore # ignore/add/remove/force
# Add or remove space between ')' and '{' of function
sp_fparen_brace = ignore # ignore/add/remove/force
# Java: Add or remove space between ')' and '{{' of double brace initializer.
sp_fparen_dbrace = ignore # ignore/add/remove/force
# Add or remove space between function name and '(' on function calls
sp_func_call_paren = ignore # ignore/add/remove/force
# Add or remove space between function name and '()' on function calls without parameters.
# If set to 'ignore' (the default), sp_func_call_paren is used.
sp_func_call_paren_empty = ignore # ignore/add/remove/force
# Add or remove space between the user function name and '(' on function calls
# You need to set a keyword to be a user function, like this: 'set func_call_user _' in the config file.
sp_func_call_user_paren = ignore # ignore/add/remove/force
# Add or remove space between a constructor/destructor and the open paren
sp_func_class_paren = ignore # ignore/add/remove/force
# Add or remove space between 'return' and '('
sp_return_paren = ignore # ignore/add/remove/force
# Add or remove space between '__attribute__' and '('
sp_attribute_paren = ignore # ignore/add/remove/force
# Add or remove space between 'defined' and '(' in '#if defined (FOO)'
sp_defined_paren = ignore # ignore/add/remove/force
# Add or remove space between 'throw' and '(' in 'throw (something)'
sp_throw_paren = ignore # ignore/add/remove/force
# Add or remove space between 'throw' and anything other than '(' as in '@throw [...];'
sp_after_throw = ignore # ignore/add/remove/force
# Add or remove space between 'catch' and '(' in 'catch (something) { }'
# If set to ignore, sp_before_sparen is used.
sp_catch_paren = ignore # ignore/add/remove/force
# Add or remove space between 'version' and '(' in 'version (something) { }' (D language)
sp_version_paren = ignore # ignore/add/remove/force
# Add or remove space between 'scope' and '(' in 'scope (something) { }' (D language)
sp_scope_paren = ignore # ignore/add/remove/force
# Add or remove space between macro and value
sp_macro = ignore # ignore/add/remove/force
# Add or remove space between macro function ')' and value
sp_macro_func = ignore # ignore/add/remove/force
# Add or remove space between 'else' and '{' if on the same line
sp_else_brace = add # ignore/add/remove/force
# Add or remove space between '}' and 'else' if on the same line
sp_brace_else = add # ignore/add/remove/force
# Add or remove space between '}' and the name of a typedef on the same line
sp_brace_typedef = ignore # ignore/add/remove/force
# Add or remove space between 'catch' and '{' if on the same line
sp_catch_brace = ignore # ignore/add/remove/force
# Add or remove space between '}' and 'catch' if on the same line
sp_brace_catch = ignore # ignore/add/remove/force
# Add or remove space between 'finally' and '{' if on the same line
sp_finally_brace = ignore # ignore/add/remove/force
# Add or remove space between '}' and 'finally' if on the same line
sp_brace_finally = ignore # ignore/add/remove/force
# Add or remove space between 'try' and '{' if on the same line
sp_try_brace = ignore # ignore/add/remove/force
# Add or remove space between get/set and '{' if on the same line
sp_getset_brace = ignore # ignore/add/remove/force
# Add or remove space between a variable and '{' for C++ uniform initialization
sp_word_brace = add # ignore/add/remove/force
# Add or remove space between a variable and '{' for a namespace
sp_word_brace_ns = add # ignore/add/remove/force
# Add or remove space before the '::' operator
sp_before_dc = ignore # ignore/add/remove/force
