Commit c3b8f7c8 authored by Neil McGlohon's avatar Neil McGlohon
Dragonfly Plus: use least congested route for all routing
parent 6ef443bf
...@@ -2763,8 +2763,8 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2763,8 +2763,8 @@ static Connection do_dfp_routing(router_state *s,
if (poss_next_stops.size() < 1) if (poss_next_stops.size() < 1)
tw_error(TW_LOC, "MINIMAL DEAD END\n"); tw_error(TW_LOC, "MINIMAL DEAD END\n");
int randsel = tw_rand_integer(lp->rng, 0, poss_next_stops.size() -1 ); Connection best_min_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops);
return poss_next_stops[randsel]; return best_min_conn;
else { //routing algorithm is specified in routing else { //routing algorithm is specified in routing
assert( (routing == NON_MINIMAL_LEAF) || (routing == NON_MINIMAL_SPINE) ); assert( (routing == NON_MINIMAL_LEAF) || (routing == NON_MINIMAL_SPINE) );
...@@ -2800,14 +2800,14 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2800,14 +2800,14 @@ static Connection do_dfp_routing(router_state *s,
if (route_to_fdest) { if (route_to_fdest) {
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, fdest_router_id);
else { //then we need to be going toward the intermediate router else { //then we need to be going toward the intermediate router
msg->path_type = NON_MINIMAL; msg->path_type = NON_MINIMAL;
vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id); vector< Connection > poss_next_stops = get_possible_stops_to_specific_router(s, bf, msg, lp, msg->intm_rtr_id);
int randsel = tw_rand_integer(lp->rng, 0, poss_next_stops.size() -1 ); Connection best_intm_conn = get_best_connection_from_conns(s, bf, msg, lp, poss_next_stops);
return poss_next_stops[randsel]; return best_intm_conn;
Markdown is supported
0%
or
Please register or to comment
