Commit c1935e46 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
having a consistent config argument name for both dfp and dfdally models
parent 66fd5c5c
...@@ -708,7 +708,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){ ...@@ -708,7 +708,7 @@ static void dragonfly_read_config(const char * anno, dragonfly_param *params){
fprintf(stderr, "Buffer size of local channels not specified, setting to %d\n", p->local_vc_size); fprintf(stderr, "Buffer size of local channels not specified, setting to %d\n", p->local_vc_size);
rc = configuration_get_value_int(&config, "PARAMS", "qos_levels", anno, &p->num_qos_levels); rc = configuration_get_value_int(&config, "PARAMS", "num_qos_levels", anno, &p->num_qos_levels);
if(rc) { if(rc) {
p->num_qos_levels = 1; p->num_qos_levels = 1;
fprintf(stderr, "Number of QOS levels not specified, setting to %d\n", p->num_qos_levels); fprintf(stderr, "Number of QOS levels not specified, setting to %d\n", p->num_qos_levels);
...@@ -1267,7 +1267,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me ...@@ -1267,7 +1267,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me
for(int k = 0; k < num_qos_levels; k++) for(int k = 0; k < num_qos_levels; k++)
int bw_consumed = get_rtr_bandwidth_consumption(s, k, j); int bw_consumed = get_rtr_bandwidth_consumption(s, k, j);
if(s->router_id == 0) if(s->qos_data[j][k] > 0)
fprintf(dragonfly_rtr_bw_log, "\n %d %f %d %d %d %d %d %f", s->router_id, tw_now(lp), j, k, bw_consumed, s->qos_status[j][k], s->qos_data[j][k], s->busy_time_sample[j]); fprintf(dragonfly_rtr_bw_log, "\n %d %f %d %d %d %d %d %f", s->router_id, tw_now(lp), j, k, bw_consumed, s->qos_status[j][k], s->qos_data[j][k], s->busy_time_sample[j]);
...@@ -1470,16 +1470,14 @@ void router_custom_setup(router_state * r, tw_lp * lp) ...@@ -1470,16 +1470,14 @@ void router_custom_setup(router_state * r, tw_lp * lp)
r->router_id = codes_mapping_get_lp_relative_id(lp->gid, 0, 0); r->router_id = codes_mapping_get_lp_relative_id(lp->gid, 0, 0);
r->group_id=r->router_id/p->num_routers; r->group_id=r->router_id/p->num_routers;
if(r->router_id == 0)
char rtr_bw_log[128]; char rtr_bw_log[128];
sprintf(rtr_bw_log, "router-bw-tracker"); sprintf(rtr_bw_log, "router-bw-tracker-%d", g_tw_mynode);
dragonfly_rtr_bw_log = fopen(rtr_bw_log, "w"); dragonfly_rtr_bw_log = fopen(rtr_bw_log, "w");
//if(dragonfly_rtr_bw_log != NULL) if(dragonfly_rtr_bw_log != NULL)
// fprintf(dragonfly_rtr_bw_log, "\n router-id time-stamp port-id qos-level bw-consumed qos-status qos-data busy-time"); fprintf(dragonfly_rtr_bw_log, "\n router-id time-stamp port-id qos-level bw-consumed qos-status qos-data busy-time");
//printf("\n Local router id %d global id %d ", r->router_id, lp->gid); //printf("\n Local router id %d global id %d ", r->router_id, lp->gid);
r->num_rtr_rc_windows = 100; r->num_rtr_rc_windows = 100;
Markdown is supported
0% or .
Please register or to comment
