Commit c1491729 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
adding a rotating random permutation pattern
parent b43f2130
......@@ -32,6 +32,8 @@
static int msg_size_hash_compare(
void *key, struct qhash_head *link);
static unsigned long perm_switch_thresh = 20971520;
/* NOTE: Message tracking works in sequential mode only! */
static int debug_cols = 0;
/* Turning on this option slows down optimistic mode substantially. Only turn
......@@ -150,7 +152,8 @@ enum TRAFFIC
UNIFORM = 1, /* sends message to a randomly selected node */
NEAREST_NEIGHBOR = 2, /* sends message to the next node (potentially connected to the same router) */
ALLTOALL = 3, /* sends message to all other nodes */
STENCIL = 4 /* sends message to 4 nearby neighbors */
STENCIL = 4, /* sends message to 4 nearby neighbors */
PERMUTATION = 5
struct mpi_workload_sample
......@@ -279,7 +282,11 @@ struct nw_state
unsigned long syn_data;
unsigned long gen_data;
unsigned long prev_switch;
unsigned long saved_perm_dest;
unsigned long rc_perm;
/* For sampling data */
int sampling_indx;
int max_arr_size;
......@@ -609,6 +616,16 @@ static void gen_synthetic_tr_rc(nw_state * s, tw_bf * bf, nw_message * m, tw_lp
if(bf->c0)
return;
if(bf->c1)
tw_rand_reverse_unif(lp->rng);
if(bf->c2)
s->prev_switch -= perm_switch_thresh;
s->saved_perm_dest = s->rc_perm;
int i;
for (i=0; i < m->rc.saved_syn_length; i++){
model_net_event_rc2(lp, &m->event_rc);
......@@ -645,6 +662,7 @@ static void gen_synthetic_tr(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * l
case UNIFORM:
bf->c1 = 1;
length = 1;
dest_svr = (int*) calloc(1, sizeof(int));
dest_svr[0] = tw_rand_integer(lp->rng, 0, num_clients - 1);
......@@ -652,6 +670,26 @@ static void gen_synthetic_tr(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * l
dest_svr[0] = (s->local_rank + 1) % num_clients;
break;
case PERMUTATION:
length = 1;
if(s->syn_data - s->prev_switch > perm_switch_thresh)
bf->c2 = 1;
s->prev_switch += perm_switch_thresh;
if(dest_svr[0] == s->local_rank)
dest_svr[0] = (s->local_rank + num_clients/2) % num_clients;
s->rc_perm = s->saved_perm_dest;
s->saved_perm_dest = dest_svr[0];
else
dest_svr[0] = s->saved_perm_dest;
break;
case NEAREST_NEIGHBOR:
length = 1;
......@@ -1867,6 +1905,8 @@ void nw_test_init(nw_state* s, tw_lp* lp)
s->num_reduce = 0;
s->reduce_time = 0;
s->all_reduce_time = 0;
s->prev_switch = 0;
char type_name[512];
if(!num_net_traces)
Markdown is supported
0% or .
Please register or to comment
