Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
codes
codes
Commits
bd8eca73
Commit
bd8eca73
authored
Nov 11, 2013
by
Philip Carns
Browse files
reorganize test conf files
parent
8123fb24
Changes
12
Hide whitespace changes
Inline
Side-by-side
configure.ac
View file @
bd8eca73
@@ -65,5 +65,8 @@ AC_SUBST(CODES_BASE_CFLAGS)
# put include files in a codes/ subdir
includedir="${includedir}/codes"
if test "x$srcdir" != "x."; then
AC_CONFIG_LINKS([tests/conf:$srcdir/tests/conf])
fi
AC_CONFIG_FILES([Makefile])
AC_OUTPUT(maint/codes-net.pc
tests/modelnet-p2p-bw-loggp.conf tests/modelnet-test-loggp.conf
AC_OUTPUT(maint/codes-net.pc)
.in
tests/
conf/
View file @
bd8eca73
@@ -12,5 +12,5 @@ PARAMS
packet_size
"2147483648"
message_size
"128"
modelnet
"loggp"
net_config_file="
@abs_srcdir@
/ng-mpi-tukey.dat";
net_config_file
tests/conf
/ng-mpi-tukey.dat"
tests/modelnet-test-dragonfly.conf
tests/
conf/
View file @
bd8eca73
File moved
.in
tests/
conf/
View file @
bd8eca73
packet_size
"512"
message_size
"256"
modelnet
"loggp"
net_config_file="
@abs_srcdir@
/ng-mpi-tukey.dat";
net_config_file
tests/conf
/ng-mpi-tukey.dat"
tests/modelnet-test-torus.conf
tests/
conf/
View file @
bd8eca73
File moved
tests/modelnet-test.conf
tests/
conf/
modelnet-test.conf
View file @
bd8eca73
File moved
tests/ng-mpi-tukey.dat
tests/
conf/
ng-mpi-tukey.dat
View file @
bd8eca73
File moved
tests/modelnet-p2p-bw-loggp.sh
View file @
bd8eca73
#!/bin/bash
--sync
1
--sync
1
tests/
conf/
tests/modelnet-test-dragonfly.sh
View file @
bd8eca73
#!/bin/bash
if
-z
$srcdir
then
echo
srcdir variable not set.
exit
1
fi
tests/modelnet-test
--sync
1
$srcdir
/tests/modelnet-test-dragonfly.conf
tests/modelnet-test
--sync
1
tests/conf/modelnet-test-dragonfly.conf
tests/modelnet-test-loggp.sh
View file @
bd8eca73
#!/bin/bash
tests/modelnet-test
--sync
1
tests/modelnet-test
--sync
1
tests/
conf/
tests/modelnet-test-torus.sh
View file @
bd8eca73
#!/bin/bash
if
-z
$srcdir
then
echo
exit
1
fi
tests/modelnet-test
--sync
1
$srcdir
/tests/modelnet-test-torus.conf
tests/modelnet-test
--sync
1
tests/conf/modelnet-test-torus.conf
tests/modelnet-test.sh
View file @
bd8eca73
#!/bin/bash
if
-z
$srcdir
then
echo
exit
1
fi
tests/modelnet-test
--sync
1
$srcdir
/tests/modelnet-test.conf
tests/modelnet-test
--sync
1
tests/conf/modelnet-test.conf
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
