Commit bbae9bca authored by Lee Savoie's avatar Lee Savoie
Browse files
Fix error that caused default to fcfs scheduler
parent 64789c54
...@@ -238,6 +238,24 @@ static void base_read_config(const char * anno, model_net_base_params *p){ ...@@ -238,6 +238,24 @@ static void base_read_config(const char * anno, model_net_base_params *p){
&packet_size_l); &packet_size_l);
packet_size = packet_size_l; packet_size = packet_size_l;
if (ret > 0){
int i;
for (i = 0; i < MAX_SCHEDS; i++){
if (strcmp(sched_names[i], sched) == 0){
p->sched_params.type = i;
break;
if (i == MAX_SCHEDS){
tw_error(TW_LOC,"Unknown value for PARAMS:modelnet-scheduler : "
"%s", sched);
else{
// default: FCFS
p->sched_params.type = MN_SCHED_FCFS;
p->num_queues = 1; p->num_queues = 1;
ret = configuration_get_value_int(&config, "PARAMS", "num_injection_queues", anno, ret = configuration_get_value_int(&config, "PARAMS", "num_injection_queues", anno,
&p->num_queues); &p->num_queues);
...@@ -262,24 +280,6 @@ static void base_read_config(const char * anno, model_net_base_params *p){ ...@@ -262,24 +280,6 @@ static void base_read_config(const char * anno, model_net_base_params *p){
"setting to %d\n", p->node_copy_queues); "setting to %d\n", p->node_copy_queues);
if (ret > 0){
int i;
break;
"%s", sched);
else{
// default: FCFS
// get scheduler-specific parameters // get scheduler-specific parameters
if (p->sched_params.type == MN_SCHED_PRIO){ if (p->sched_params.type == MN_SCHED_PRIO){
// prio scheduler uses default parameters // prio scheduler uses default parameters
Markdown is supported
0% or .
Please register or to comment
