Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
b734e145
Commit
b734e145
authored
Oct 02, 2018
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'codes-ml-master' into 'master'
Dragonfly Plus: Bugfix and safety check See merge request
!61
parents
c2ba8ef7
55a9cbf2
Changes
2
Show whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
33 additions
and
23 deletions
+33
-23
codes/connection-manager.h
+30
-17
src/networks/model-net/dragonfly-plus.C
+3
-6
No files found.
View file @
b734e145
@@ -255,22 +255,34 @@ void ConnectionManager::add_connection(int dest_gid, ConnectionType type)
switch
type
case
CONN_LOCAL
if
intraGroupConnections
size
_max_intra_ports
conn
port
this
get_used_ports_for
CONN_LOCAL
conn
dest_lid
push_back
conn
_used_intra_ports
else
tw_error
TW_LOC
"Attempting to add too many local connections per router - exceeding configuration value: %d"
_max_intra_ports
break
case
CONN_GLOBAL
if
globalConnections
size
_max_inter_ports
conn
port
_max_intra_ports
this
get_used_ports_for
CONN_GLOBAL
globalConnections
conn
dest_gid
push_back
conn
_used_inter_ports
else
tw_error
TW_LOC
"Attempting to add too many global connections per router - exceeding configuration value: %d"
_max_inter_ports
break
case
CONN_TERMINAL
if
terminalConnections
size
_max_terminal_ports
conn
port
_max_intra_ports
_max_inter_ports
this
get_used_ports_for
CONN_TERMINAL
conn
dest_group_id
_source_group
terminalConnections
conn
dest_gid
push_back
conn
_used_terminal_ports
else
tw_error
TW_LOC
"Attempting to add too many terminal connections per router - exceeding configuration value: %d"
_max_terminal_ports
break
default:
@@ -534,18 +546,19 @@ void ConnectionManager::print_connections()
int
group_id
it
second
dest_group_id
int
id
gid
if
get_port_type
port_num
CONN_LOCAL
if
get_port_type
port_num
CONN_LOCAL
id
it
second
dest_lid
gid
it
second
dest_gid
printf
" %d -> (%d,%d) : %d
\n
port_num
id
gid
group_id
printf
- LOCAL
\n
port_num
id
gid
group_id
else
else
if
get_port_type
port_num
CONN_GLOBAL
id
it
second
dest_gid
printf
" %d -> %d : %d
\n
port_num
id
group_id
printf
" %d -> %d : %d - GLOBAL
\n
port_num
id
group_id
else
if
get_port_type
port_num
CONN_TERMINAL
id
it
second
dest_gid
printf
" %d -> %d : %d - TERMINAL
\n
port_num
id
group_id
ports_printed
View file @
b734e145
@@ -1134,18 +1134,15 @@ int dragonfly_plus_get_assigned_router_id(int terminal_id, const dragonfly_plus_
// currently supports symmetrical bipartite spine/leaf router configurations
// first half of routers in a given group are leafs which have terminals
// second half of routers in a given group are spines which have no terminals
int
num_groups
p
num_groups
// number of groups of routers in the network
int
num_routers
p
num_routers
// num routers per group
int
num_router_leaf
p
num_router_leaf
// num leaf routers per group
int
num_cn
p
num_cn
// num compute nodes per leaf router
int
num_cn_per_group
num_router_leaf
num_cn
int
group_id
terminal_id
num_router_leaf
num_cn
int
local_router_id
terminal_id
num_router_leaf
num_cn
num_router_leaf
int
group_id
terminal_id
num_cn_per_group
int
local_router_id
terminal_id
num_cn
num_router_leaf
int
router_id
group_id
num_routers
local_router_id
// printf("Terminal %d: assigned to group %d, local router id %d, global router id %d\n",terminal_id,
// group_id, local_router_id, router_id);
return
router_id
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
