Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
b5332aff
Commit
b5332aff
authored
Mar 24, 2015
by
Elsa Gonsiorowski (Uranus)
Browse files
Options
Browse Files
Download
Plain Diff
merge
parents
5509f22e
e6c7f2e0
Changes
55
Expand all
Hide whitespace changes
Inline
Side-by-side
Showing
55 changed files
with
2368 additions
and
1515 deletions
+2368
-1515
codes/codes-workload.h
+9
-8
codes/codeslogging.h
+0
-183
codes/configuration.h
+3
-1
codes/local-storage-model.h
+19
-1
codes/timeline.h
codes/timeline.h
+0
-76
codes/tools.h
codes/tools.h
+0
-56
configure.ac
configure.ac
+1
-1
doc/BUILD_STEPS
doc/BUILD_STEPS
+9
-0
doc/GETTING_STARTED
doc/GETTING_STARTED
+2
-4
reformat.sh
reformat.sh
+109
-0
src/Makefile.subdir
src/Makefile.subdir
+15
-34
src/iokernellang/CodesIOKernelContext.h
+0
-0
src/iokernellang/CodesIOKernelParser.h
+2
-2
src/iokernellang/CodesIOKernelTypes.h
+1
-1
src/iokernellang/CodesKernelHelpers.c
+15
-21
src/iokernellang/CodesKernelHelpers.h
+4
-4
src/iokernellang/codesImpl.c
+2
-2
src/iokernellang/codeslexer.c
+53
-48
src/iokernellang/codeslexer.h
+4
-4
src/iokernellang/codeslexer.l
+2
-2
src/iokernellang/codesparser.c
+59
-59
src/iokernellang/codesparser.h
+2
-2
src/iokernellang/codesparser.y.in
+3
-3
src/logging/codeslogging.c
+0
-492
src/logging/timeline.c
+0
-97
src/modelconfig/configfile.c
+5
-5
src/modelconfig/configfile.h
+13
-15
src/modelconfig/configglue.c
+6
-6
src/modelconfig/configglue.h
+5
-5
src/modelconfig/configlex.l
+0
-1
src/modelconfig/configparser.y
+4
-5
src/modelconfig/configstoreadapter.c
+15
-6
src/modelconfig/configstoreadapter.h
+3
-3
src/modelconfig/configuration.c
+2
-0
src/modelconfig/txt_configfile.c
+18
-19
src/modelconfig/txt_configfile.h
+8
-8
src/util/codes-callbacks.c
+0
-75
src/util/codes-callbacks.h
+0
-39
src/util/local-storage-model.c
+82
-50
src/util/resource-lp.c
+49
-4
src/util/tools.c
src/util/tools.c
+0
-38
src/workload/codes-workload-dump.c
+205
-51
src/workload/codes-workload.c
+23
-5
src/workload/methods/codes-iolang-wrkld.c
+35
-33
tests/Makefile.subdir
+2
-1
tests/conf/buffer_test.conf
+1
-1
tests/local-storage-model-test.c
+0
-10
tests/resource-test.sh
+8
-0
tests/workload/README.txt
+6
-9
tests/workload/codes-workload-mpi-replay.c
+8
-11
tests/workload/codes-workload-test-cn-lp.c
+2
-2
tests/workload/codes-workload-test-cn-lp.h
+1
-1
tests/workload/codes-workload-test.c
+4
-9
tests/workload/codes-workload-test.conf
+1
-2
uc-codes.cfg
uc-codes.cfg
+1548
-0
No files found.
View file @
b5332aff
@@ -15,7 +15,7 @@
@@ -15,7 +15,7 @@
#include "ross.h"
#include "ross.h"
#define MAX_NAME_LENGTH_WKLD 512
typedef
struct
bgp_params
bgp
_params
typedef
struct
iolang_params
iolang
_params
typedef
struct
darshan_params
darshan_params
typedef
struct
darshan_params
darshan_params
typedef
struct
recorder_params
recorder_params
typedef
struct
recorder_params
recorder_params
typedef
struct
codes_workload_info
codes_workload_info
typedef
struct
codes_workload_info
codes_workload_info
@@ -25,18 +25,15 @@ typedef struct scala_trace_params scala_trace_params;
typedef
struct
dumpi_trace_params
dumpi_trace_params
typedef
struct
dumpi_trace_params
dumpi_trace_params
struct
bgp
_params
struct
iolang
_params
/* We have the number of ranks passed in from the bg/p model because
/* the rank count is defined in the workload config file */
* the I/O lang workloads have no information about the number of ranks.
* Only the bg/p config file knows the number of ranks. */
int
num_cns
int
num_cns
/* flag - use path to find kernel files relative to the metafile */
int
use_relpath
int
use_relpath
char
io_kernel_meta_path
char
io_kernel_meta_path
char
bgp_config_file
/* set by config in the metadata path */
char
io_kernel_path
char
io_kernel_path
char
io_kernel_def_path
struct
darshan_params
struct
darshan_params
@@ -67,8 +64,8 @@ struct scala_trace_params {
struct
dumpi_trace_params
struct
dumpi_trace_params
int
num_net_traces
char
file_name
char
file_name
int
num_net_traces
@@ -127,6 +124,10 @@ enum codes_workload_op_type
CODES_WK_WAITANY
CODES_WK_WAITANY
/* Testall operation */
CODES_WK_TESTALL
CODES_WK_TESTALL
/* for workloads that have events not yet handled
* (eg the workload language) */
CODES_WK_IGNORE
/* I/O operation paramaters */
deleted
100644 → 0
View file @
5509f22e
* Copyright (C) 2013 University of Chicago.
* See COPYRIGHT notice in top-level directory.
* (C) 2001 Clemson University and The University of Chicago
* See COPYING in top-level directory.
/** \defgroup codeslogging codeslogging logging interface
* This is a basic application logging facility. It uses printf style
* formatting and provides several mechanisms for output.
/* This code was derived from the PVFS2 codeslogging circa vs. 2.8.1 */
/** \file
* Declarations for the codeslogging logging interface.
#ifndef SRC_COMMON_LOGGING_CODESLOGGING_H
#define SRC_COMMON_LOGGING_CODESLOGGING_H
#include <stdint.h>
#include <stdarg.h>
* Visible interface
#define CODESLOGGING_BUF_SIZE 1024
/* what type of timestamp to place in msgs */
enum
codeslogging_logstamp
CODESLOGGING_LOGSTAMP_NONE
0
CODESLOGGING_LOGSTAMP_USEC
1
CODESLOGGING_LOGSTAMP_DATETIME
2
CODESLOGGING_LOGSTAMP_THREAD
3
#define CODESLOGGING_LOGSTAMP_DEFAULT CODESLOGGING_LOGSTAMP_USEC
/* stdio is needed by codeslogging_debug_fp declaration for FILE* */
#include <stdio.h>
int
codeslogging_enable_stderr
void
int
codeslogging_enable_file
const
char
filename
const
char
mode
int
codeslogging_disable
void
int
codeslogging_set_debug_mask
int
debug_on
uint64_t
mask
int
codeslogging_get_debug_mask
int
debug_on
uint64_t
mask
int
codeslogging_set_logstamp
enum
ts
void
codeslogging_backtrace
void
#ifdef __GNUC__
/* do printf style type checking if built with gcc */
int
__codeslogging_debug
uint64_t
mask
char
prefix
const
char
format
__attribute__
format
printf
3
4
int
codeslogging_err
const
char
format
__attribute__
format
printf
1
2
int
__codeslogging_debug_va
uint64_t
mask
char
prefix
const
char
format
va_list
ap
int
FILE
fp
char
prefix
enum
ts
const
char
format
__attribute__
format
printf
4
5
#ifdef CODESLOGGING_DISABLE_DEBUG
#define codeslogging_debug(mask, format, f...) do {} while(0)
#define codeslogging_perf_log(format, f...) do {} while(0)
#define codeslogging_debug_enabled(__m) 0
#else
extern
int
codeslogging_debug_on
extern
int
codeslogging_facility
extern
uint64_t
codeslogging_debug_mask
#define codeslogging_debug_enabled(__m) \
(codeslogging_debug_on && (codeslogging_debug_mask & __m))
/* try to avoid function call overhead by checking masks in macro */
#define codeslogging_debug(mask, format, f...) \
do { \
if ((codeslogging_debug_on) && (codeslogging_debug_mask & mask) &&\
(codeslogging_facility)) \
__codeslogging_debug(mask, '?', format, ##f); \
} while(0)
#define codeslogging_perf_log(format, f...) \
do { \
if ((codeslogging_debug_on) && \
(codeslogging_debug_mask & CODESLOGGING_PERFCOUNTER_DEBUG) && \
__codeslogging_debug(CODESLOGGING_PERFCOUNTER_DEBUG, 'P', \
format, ##f); \
} while(0)
#endif
/* CODESLOGGING_DISABLE_DEBUG */
/* do file and line number printouts w/ the GNU preprocessor */
#define codeslogging_ldebug(mask, format, f...) \
do { \
codeslogging_debug(mask, "%s: " format, __func__ , ##f); \
} while(0)
#define codeslogging_lerr(format, f...) \
do { \
codeslogging_err("%s line %d: " format, __FILE__ , __LINE__ , ##f); \
codeslogging_backtrace(); \
} while(0)
#else
/* ! __GNUC__ */
int
uint64_t
mask
char
prefix
const
char
format
int
__codeslogging_debug_stub
uint64_t
mask
char
prefix
const
char
format
int
codeslogging_err
const
char
format
#define codeslogging_debug(__m, __f, f...) __codeslogging_debug_stub(__m, '?', __f, ##f);
#define codeslogging_ldebug(__m, __f, f...) __codeslogging_debug_stub(__m, '?', __f, ##f);
#else
#define codeslogging_debug(__m, __f, f...) __codeslogging_debug(__m, '?', __f, ##f);
#define codeslogging_ldebug(__m, __f, f...) __codeslogging_debug(__m, '?', __f, ##f);
((codeslogging_debug_on != 0) && (__m & codeslogging_debug_mask))
#endif
#define codeslogging_lerr codeslogging_err
#endif
/* __GNUC__ */
#endif
/* __CODESLOGGING_H */
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ts=8 sts=4 sw=4 expandtab
View file @
b5332aff
@@ -7,9 +7,9 @@
@@ -7,9 +7,9 @@
#ifndef __CONFIGURATION_H__
#define __CONFIGURATION_H__
#include <stddef.h>
#include <inttypes.h>
#include <mpi.h>
#include <mpi.h>
#include "codes/txt_configfile.h"
#define CONFIGURATION_MAX_NAME 256
#define CONFIGURATION_MAX_GROUPS 10
@@ -53,6 +53,8 @@ typedef struct config_lpgroups_s
config_anno_map_t
lpannos
CONFIGURATION_MAX_TYPES
config_anno_map_t
lpannos
config_lpgroups_t
config_lpgroups_t
typedef
struct
ConfigVTable
ConfigHandle
* Load a configuration on the system (collectively)
View file @
b5332aff
@@ -43,7 +43,10 @@ typedef enum lsm_event_e
/* given LP sender, find the LSM device LP in the same group */
tw_lpid
lsm_find_local_device
tw_lp
sender
tw_lpid
const
char
annotation
int
ignore_annotations
tw_lpid
sender_gid
* lsm_event_new
* lsm_event_new
@@ -69,6 +72,21 @@ tw_event* lsm_event_new(const char* category,
size_t
message_bytes
size_t
message_bytes
tw_lp
sender
tw_lp
sender
tw_stime
delay
tw_stime
delay
/* equivalent to lsm_event_new, except it allows to specify an annotation to
* filter by. If ignore_annotations is nonzero, A null annotation parameter
* indicates that the lsm LP to issue to has no annotation */
tw_event
lsm_event_new_annotated
const
char
category
tw_lpid
dest_gid
uint64_t
io_object
int64_t
io_offset
uint64_t
io_size_bytes
int
io_type
size_t
message_bytes
tw_lp
sender
tw_stime
delay
const
char
annotation
int
ignore_annotations
void
lsm_event_new_reverse
tw_lp
sender
void
tw_lp
sender
codes/timeline.h
deleted
100644 → 0
View file @
5509f22e
* timeline.h
* Created on: Jun 24, 2013
* Author: wozniak
#ifndef TIMELINE_H
#define TIMELINE_H
#define TIMELINE_ENABLED 0
#if TIMELINE_ENABLED == 1
#include <ross.h>
Open filename for writing for timeline data
@return 1 on success, 0 on error
int
timeline_init
const
char
filename
Write a timeline record
int
timeline_printf
const
char
format
int
timeline_printf_va
const
char
format
va_list
ap
Write a timeline record with typical ROSS metadata
#define timeline_event(lp, format, args...) \
timeline_event_impl(lp, __func__, format, ##args)
int
timeline_event_impl
const
tw_lp
lp
const
char
func
const
char
format
Finalize the timeline module
void
timeline_finalize
void
#else
// Set all functions to noops (return success value 1)
#define timeline_init(x) 1
#define timeline_printf(f, a...) 1
#define timeline_printf_va(f, a) 1
#define timeline_event(lp, f, a...) 1
#define timeline_finalize()
#endif
#endif
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
codes/tools.h
deleted
100644 → 0
View file @
5509f22e
#ifndef SRC_COMMON_UTIL_TOOLS_H
#define SRC_COMMON_UTIL_TOOLS_H
#ifdef UNUSED
#elif defined(__GNUC__)
# define UNUSED(x) UNUSED_ ## x __attribute__((unused))
#elif defined(__LCLINT__)
# define UNUSED(x)
/*@unused@*/
x
#else
# define UNUSED(x) x
#endif
/* UNUSED */
#define codesmin(a,b) ((a)<(b) ? (a):(b))
#define codesmax(a,b) ((a)>(b) ? (a):(b))
void
always_assert_error
const
char
expr
const
char
file
int
lineno
#define ALWAYS_ASSERT(a) if (!(a)) always_assert_error(#a,__FILE__, __LINE__);
#define ARRAY_SIZEOF(a) (sizeof(a)/sizeof(a[0]))
char
safe_strncpy
char
buf
const
char
source
unsigned
int
bufsize
#define CODES_FLAG_ISSET(mode_, flag_) ((mode_ & flag_) != 0)
#define CODES_FLAG_SET(mode_, flag_, branch_) \
do \
mode_ = mode_ | flag_; \
branch_ = 1; \
}while(0)
#define CODES_FLAG_SET_RC(mode_, flag_, branch_) \
do \
if(branch_) \
mode_ = mode_ & (~flag_); \
}while(0)
#endif
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
configure.ac
View file @
b5332aff
@@ -123,7 +123,7 @@ if test "x${with_dumpi}" != "x" ; then
# DUMPI_CFLAGS+=" -I${with_dumpi}/include/dumpi/common"
# DUMPI_CFLAGS+=" -I${with_dumpi}/include/dumpi/libdumpi"
# DUMPI_CFLAGS+=" -I${with_dumpi}/include/dumpi/libundumpi"
DUMPI_LIBS="-L${with_dumpi}/lib/ -l
dumpi -l
undumpi"
DUMPI_LIBS="-L${with_dumpi}/lib/ -lundumpi"
AC_SUBST(DUMPI_LIBS)
AC_SUBST(DUMPI_CFLAGS)
else
else
doc/BUILD_STEPS
View file @
b5332aff
@@ -67,3 +67,12 @@ Notes on using the clang static analyzer
- edit Makefile, and delete the "CC = mpicc" (or similar) line
- run "scan-build --use-cc=mpicc make"
Notes on using uncrustify
- version 0.61 is required
- build/install uncrustify from your favorite distro (0.61), OR download from
https://github.com/bengardner/uncrustify and build from source
(configure --prefix /path/to/install && make && make install)
- either use uncrustify directly (see uncrustify --help) or use the provided
reformat.sh tool which is a shim over some of the options (see reformat.sh
-h)
doc/GETTING_STARTED
View file @
b5332aff
@@ -96,9 +96,7 @@ IO kernel language, and in-development ScalaTrace
The
synthetic
IO
language
is
a
simple
interpreted
set
of
IO
and
basic
The
synthetic
IO
language
is
a
simple
interpreted
set
of
IO
and
basic
arithmetic
commands
meant
to
simplify
the
specification
and
running
of
arithmetic
commands
meant
to
simplify
the
specification
and
running
of
application
workloads
In
the
code
it
's currently called the "bgp" workload
application
workloads
generator but that is just a historical artifact - in the future it will be
refactored/renamed.
The
input
for
the
workload
generator
consists
of
an
IO
kernel
metadata
file
and
The
input
for
the
workload
generator
consists
of
an
IO
kernel
metadata
file
and
a
number
of
IO
kernel
files
The
former
specifies
a
set
of
kernel
files
to
run
a
number
of
IO
kernel
files
The
former
specifies
a
set
of
kernel
files
to
run
@@ -126,7 +124,7 @@ readat/writeat.
More
detailed
documentation
on
the
language
is
ongoing
but
for
now
a
general
More
detailed
documentation
on
the
language
is
ongoing
but
for
now
a
general
example
can
be
seen
at
doc
workload
which
shows
a
simple
out
of
core
data
example
can
be
seen
at
doc
workload
which
shows
a
simple
out
of
core
data
shuffle
Braver
souls
may
wish
to
visit
the
implementation
at
src
iokernellang
shuffle
Braver
souls
may
wish
to
visit
the
implementation
at
src
iokernellang
and src/workload/codes-
bgp-io
-wrkld.c.
and
src
workload
codes
iolang
wrkld
c
The
following
restrictions
currently
apply
to
the
IO
language
The
following
restrictions
currently
apply
to
the
IO
language
all
user
defined
variables
must
be
a
single
lower
case
letter
the
symbol
all
user
defined
variables
must
be
a
single
lower
case
letter
the
symbol
reformat.sh
0 → 100755
View file @
b5332aff
#!/bin/bash
script_dir
cd
dirname
BASH_SOURCE
[0]
pwd
function
error
echo
"ERROR:
&2
exit
1
function
usage
cat
EOF
USAGE: reformat.sh [-x] [-i] [-c CFG] [-b FILE] {-a | FILE...}
-i: perform in-place (will ask to confirm if being done recursively)
-c CFG: use CFG as the uncrustify config (default:
$script_dir
/uc-codes.cfg)
-b FILE[,...]: add FILE to the blacklist of directories (in the form *FILE/*)
multiple files can be added by separating with commas
-a: perform recursively on all files ending in .c or .h
if -a not provided, then perform on all files passed in
-x: instead of formatting, check if output format is the same as input
-h: show this help and exit
EOF
function
build_blacklist
for
x
in
do
echo
-n
"-and -not -path
$x
done
function
getfiles
find
-name
.c
-or
-name
.h
build_blacklist
cfg
$script_dir
/uc-codes.cfg
which uncrustify
/dev/null 2>&1
error
"uncrustify not found"
do_inplace
no
do_recursive
no
do_check
no
blacklist
while
getopts
":ib:axh"
opt
do
case
$opt
in
i
do_inplace
yes
b
blacklist
cat
$OPTARG
sed
s/,/ /g
c
cfg
$OPTARG
a
do_recursive
yes
x
do_check
yes
h
usage
exit
1
usage
error
"invalid argument: -
$OPTARG
esac
done
shift
OPTIND-1
-e
$cfg
usage
error
"config file
$cfg
not found"
-gt
0
$do_recursive
yes
usage
error
"no file args expected in recursive mode"
-eq
0
$do_recursive
no
usage
error
"expected file args in non-recursive mode"
if
$do_recursive
yes
then
file_list
getfiles
$blacklist
else
file_list
fi
if
$do_recursive
yes
$do_inplace
yes
then
echo
-n
"Do recursive in-place reformat? (y/n) "
read
answer
$answer
"[^y].*"
echo
"...aborting reformat"
exit
1
fi
$do_inplace
yes
output_arg
"--replace"
output_arg
if
$do_check
yes
then
check_arg
--check
output_arg
echo
"checking format..."
else
check_arg
fi
function
echolines
for
x
in
do
echo
$x
done
echolines
$file_list
| uncrustify
$check_arg
-c
$cfg
$output_arg
-F
src/Makefile.subdir
View file @
b5332aff
@@ -29,33 +29,22 @@ maintainer-clean-local::
src/modelconfig/configparser.h
src/modelconfig/configlex.h
#BUILT_SOURCES +=
codes
/codesparser.h \
#BUILT_SOURCES +=
src/iokernellang
/codesparser.h \
# src/iokernellang/codesparser.c \
# src/iokernellang/codeslexer.h \
codes
/codeslexer.h
src/iokernellang
/codeslexer.h
#src/iokernellang/codesparser.y: src/iokernellang/codesparser.y.in Makefile
#src/iokernellang/codesparser.c
codes
/codesparser.h: src/iokernellang/codesparser.y
src/iokernellang
codes
/codeslexer.h: $(top_srcdir)/src/iokernellang/codeslexer.h
src/iokernellang
#mkdir -p codes
#mkdir -p codes
#cp $(top_srcdir)/src/iokernellang/codeslexer.h
codes
/codeslexer.h
src/iokernellang
/codeslexer.h
nobase_include_HEADERS
codes/CodesKernelHelpers.h
codes/CodesIOKernelContext.h
codes/CodesIOKernelParser.h
codes/CodesIOKernelTypes.h
codes/codeslexer.h
codes/tools.h
codes/timeline.h
codes/codesparser.h
codes/quickhash.h
codes/quickhash.h
codes/configfile.h
codes/quicklist.h
codes/quicklist.h
codes/codes_mapping.h
codes/lp-type-lookup.h
@@ -73,15 +62,15 @@ nobase_include_HEADERS = \
#codes/codes-nw-workload.h
src_libcodes_base_a_SOURCES
codes
/codesparser.h
src/iokernellang
/codesparser.h
codes
/codeslexer.h
src/iokernellang
/codeslexer.h
codes
src/iokernellang
codes
src/iokernellang
codes
src/iokernellang
codes
src/iokernellang
src/modelconfig/configlex.c
@@ -90,33 +79,25 @@ src_libcodes_base_a_SOURCES = \
codes
/configfile.h
src/modelconfig
/configfile.h
src/modelconfig/configstore.h
src/modelconfig/configstore.c
codes
/txt_configfile.h
src/modelconfig
/txt_configfile.h
codes/tools.h
src/util/tools.c
src/util/codes_mapping.c
