Commit b3773183 authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Dragonfly Plus Model: Add Gamma Scoring Metric - Unverified
parent 902c7938
...@@ -170,6 +170,8 @@ struct dragonfly_plus_param ...@@ -170,6 +170,8 @@ struct dragonfly_plus_param
int num_router_spine; // number of spine routers (top level) int num_router_spine; // number of spine routers (top level)
int num_router_leaf; // number of leaf routers (bottom level) int num_router_leaf; // number of leaf routers (bottom level)
int queue_threshold; // predefined queue length threshold T before a packet is routed through a lower priority queue int queue_threshold; // predefined queue length threshold T before a packet is routed through a lower priority queue
long max_port_score; // maximum score that can be given to any port during route scoring
// dfp params end // dfp params end
int num_groups; int num_groups;
...@@ -310,6 +312,14 @@ enum last_hop ...@@ -310,6 +312,14 @@ enum last_hop
TERMINAL, TERMINAL,
// Used to denote whether a connection is one that would allow a packet to continue along a minimal path or not
// Specifically used to clearly pass whether a connection is a minimal one through to the connection scoring function
typedef enum conn_minimality_t
C_MIN = 1,
C_NONMIN
} conn_minimality_t;
typedef enum routing_alg_t typedef enum routing_alg_t
MINIMAL = 1, //will always follow the minimal route from host to host MINIMAL = 1, //will always follow the minimal route from host to host
...@@ -323,9 +333,16 @@ typedef enum routing_alg_t ...@@ -323,9 +333,16 @@ typedef enum routing_alg_t
typedef enum route_scoring_metric_t typedef enum route_scoring_metric_t
ALPHA = 1, //Count queue lengths and pending messages for a port ALPHA = 1, //Count queue lengths and pending messages for a port
BETA //Expected Hops to Destination * (Count queue lengths and pending messages) for a port BETA, //Expected Hops to Destination * (Count queue lengths and pending messages) for a port
GAMMA
} route_scoring_metric_t; } route_scoring_metric_t;
typedef enum route_scoring_preference_t
LOWER = 1,
HIGHER
} route_scoring_preference_t;
bool isRoutingAdaptive(int alg) bool isRoutingAdaptive(int alg)
if (alg == PROG_ADAPTIVE || alg == FULLY_PROG_ADAPTIVE) if (alg == PROG_ADAPTIVE || alg == FULLY_PROG_ADAPTIVE)
...@@ -409,6 +426,7 @@ int dragonfly_plus_get_assigned_router_id(int terminal_id, const dragonfly_plus_ ...@@ -409,6 +426,7 @@ int dragonfly_plus_get_assigned_router_id(int terminal_id, const dragonfly_plus_
static short routing = MINIMAL; static short routing = MINIMAL;
static short scoring = ALPHA; static short scoring = ALPHA;
static short scoring_preference = LOWER;
static tw_stime dragonfly_total_time = 0; static tw_stime dragonfly_total_time = 0;
static tw_stime dragonfly_max_latency = 0; static tw_stime dragonfly_max_latency = 0;
...@@ -625,17 +643,6 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -625,17 +643,6 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
routing = MINIMAL; routing = MINIMAL;
char scoring_str[MAX_NAME_LENGTH];
configuration_get_value(&config, "PARAMS", "route_scoring_metric", anno, scoring_str, MAX_NAME_LENGTH);
if (strcmp(scoring_str, "alpha") == 0)
scoring = ALPHA;
else if (strcmp(scoring_str, "beta") == 0)
scoring = BETA;
else {
fprintf(stderr, "No route scoring protocol specified, setting to alpha scoring\n");
scoring = ALPHA;
/* MM: This should be 2 for dragonfly plus*/ /* MM: This should be 2 for dragonfly plus*/
p->num_vcs = 2; p->num_vcs = 2;
...@@ -658,11 +665,9 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -658,11 +665,9 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
p->num_level_chans = 1; p->num_level_chans = 1;
p->num_routers = p->num_router_spine + p->num_router_leaf; // num routers per group p->num_routers = p->num_router_spine + p->num_router_leaf; // num routers per group
p->intra_grp_radix = (p->num_routers / 2) * p->num_level_chans; p->intra_grp_radix = (p->num_routers / 2) * p->num_level_chans;
rc = configuration_get_value_int(&config, "PARAMS", "num_cns_per_router", anno, &p->num_cn); rc = configuration_get_value_int(&config, "PARAMS", "num_cns_per_router", anno, &p->num_cn);
if (rc) { if (rc) {
printf("\n Number of cns per router not specified, setting to %d ", 4); printf("\n Number of cns per router not specified, setting to %d ", 4);
...@@ -679,6 +684,50 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params ...@@ -679,6 +684,50 @@ static void dragonfly_read_config(const char *anno, dragonfly_plus_param *params
p->total_routers = p->num_groups * p->num_routers; p->total_routers = p->num_groups * p->num_routers;
p->total_terminals = (p->num_groups * p->num_router_leaf) * p->num_cn; p->total_terminals = (p->num_groups * p->num_router_leaf) * p->num_cn;
// char score_pref_str[MAX_NAME_LENGTH];
// configuration_get_value(&config, "PARAMS", "route_scoring_preference", anno, score_pref_str, MAX_NAME_LENGTH);
// if (strcmp(score_pref_str, "lower") == 0)
// scoring_preference = LOWER;
// else if (strcmp(score_pref_str, "higher") == 0)
// scoring_preference = HIGHER;
// else {
// fprintf(stderr, "No route score preference specified, setting to 'lower is better'\n");
if (strcmp(scoring_str, "alpha") == 0) {
scoring = ALPHA;
else if (strcmp(scoring_str, "beta") == 0) {
scoring = BETA;
else if (strcmp(scoring_str, "gamma") == 0) {
scoring = GAMMA;
else {
scoring = ALPHA;
int largest_vc_size = 0;
if (p->local_vc_size > largest_vc_size)
largest_vc_size = p->local_vc_size;
if (p->global_vc_size > largest_vc_size)
largest_vc_size = p->global_vc_size;
if (p->cn_vc_size > largest_vc_size)
largest_vc_size = p->cn_vc_size;
p->max_port_score = (p->num_vcs * largest_vc_size) + largest_vc_size; //The maximum score that a port can get during the scoring metrics.
// read intra group connections, store from a router's perspective // read intra group connections, store from a router's perspective
// all links to the same router form a vector // all links to the same router form a vector
char intraFile[MAX_NAME_LENGTH]; char intraFile[MAX_NAME_LENGTH];
...@@ -2297,16 +2346,16 @@ static int get_min_hops_to_dest_from_conn(router_state *s, tw_bf *bf, terminal_p ...@@ -2297,16 +2346,16 @@ static int get_min_hops_to_dest_from_conn(router_state *s, tw_bf *bf, terminal_p
* Scores a connection based on the metric provided in the function, lower score is better * Scores a connection based on the metric provided in the function
* @param isMinimalPort a boolean variable used in the Gamma metric to pass whether a given port would lead to the destination in a minimal way
static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, Connection conn) static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, Connection conn, conn_minimality_t c_minimality)
//Currently just looking at VC Occupancy and message queue length like dragonfly custom int score;
int score = 0;
int port = conn.port; int port = conn.port;
switch(scoring) { switch(scoring) {
case ALPHA: case ALPHA: //considers vc occupancy and queued count only LOWER SCORE IS BETTER
for(int k=0; k < s->params->num_vcs; k++) for(int k=0; k < s->params->num_vcs; k++)
...@@ -2315,7 +2364,7 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag ...@@ -2315,7 +2364,7 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag
score += s->queued_count[port]; score += s->queued_count[port];
break; break;
case BETA: case BETA: //consideres vc occupancy and queued count multiplied by the number of minimum hops to the destination LOWER SCORE IS BETTER
int base_score = 0; int base_score = 0;
...@@ -2326,6 +2375,24 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag ...@@ -2326,6 +2375,24 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag
score = base_score * get_min_hops_to_dest_from_conn(s, bf, msg, lp, conn); score = base_score * get_min_hops_to_dest_from_conn(s, bf, msg, lp, conn);
break; break;
case GAMMA: //consideres vc occupancy and queue count but ports that follow a minimal path to fdest are biased 2:1 HIGHER SCORE IS BETTER
score = s->params->max_port_score;
int to_subtract = 0;
to_subtract += s->vc_occupancy[port][k];
to_subtract += s->queued_count[port];
score -= to_subtract;
if (c_minimality = C_MIN) //the connection maintains the paths minimality - gets a bonus of 2x
score = score * 2;
break;
default:
tw_error(TW_LOC, "Unsupported Scoring Protocol Error\n");
return score; return score;
...@@ -2430,35 +2497,62 @@ static Connection do_dfp_routing(router_state *s, ...@@ -2430,35 +2497,62 @@ static Connection do_dfp_routing(router_state *s,
for(int i = 0; i < num_conns; i++) for(int i = 0; i < num_conns; i++)
if(i < (selected_minimal_conns.size()) ) if(i < (selected_minimal_conns.size()) )
scores[i] = dfp_score_connection(s, bf, msg, lp, selected_minimal_conns[i]); scores[i] = dfp_score_connection(s, bf, msg, lp, selected_minimal_conns[i], C_MIN);
else else
scores[i] = dfp_score_connection(s, bf, msg, lp, selected_nonminimal_conns[i-selected_minimal_conns.size()]); scores[i] = dfp_score_connection(s, bf, msg, lp, selected_nonminimal_conns[i-selected_minimal_conns.size()], C_NONMIN);
int best_min_score = INT_MAX; // compare scores based on the scoring preference ----------------------------------------------------------------------------------------------------
int best_min_score_index = 0; int best_min_score_index = 0;
for(int i = 0; i < selected_minimal_conns.size(); i++) int best_non_min_score_index = 0;
if (scores[i] < best_min_score) { if (scoring_preference == LOWER) { //Lower scores are better
best_min_score = scores[i]; int best_min_score = INT_MAX;
best_min_score_index = i; for(int i = 0; i < selected_minimal_conns.size(); i++)
int best_non_min_score = INT_MAX; int best_non_min_score = INT_MAX;
int best_non_min_score_index = 0; for(int i = selected_minimal_conns.size(); i < num_conns; i++)
for(int i = selected_minimal_conns.size(); i < num_conns; i++) {
{ if (scores[i] < best_non_min_score) {
if (scores[i] < best_non_min_score) { best_non_min_score = scores[i];
best_non_min_score = scores[i]; best_non_min_score_index = i-selected_minimal_conns.size();
best_non_min_score_index = i-selected_minimal_conns.size(); }
if (best_min_score <= best_non_min_score) { //ties go to minimal
choose_minimal = true;
//end score calculation else if (scoring_preference == HIGHER) { //higher scores are better
int best_min_score = 0;
if (scores[i] > best_min_score) {
if (best_min_score <= best_non_min_score) { //ties go to minimal int best_non_min_score = 0;
choose_minimal = true; for(int i = selected_minimal_conns.size(); i < num_conns; i++)
if (scores[i] > best_non_min_score) {
if (best_min_score >= best_non_min_score) { //ties go to minimal
// end scoring stuff ----------------------------------------------------------------------------------------------------------------------------------
//intermediate groups have restrictions on how they have to route to avoid livelock //intermediate groups have restrictions on how they have to route to avoid livelock
if (in_intermediate_group) { if (in_intermediate_group) {
Markdown is supported
0% or .
Please register or to comment
