Commit b1c85a7c authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
minor data structure changes from codes-base
parent b15005f4
...@@ -330,7 +330,7 @@ static void dragonfly_configure(){ ...@@ -330,7 +330,7 @@ static void dragonfly_configure(){
all_params = calloc(num_params, sizeof(*all_params)); all_params = calloc(num_params, sizeof(*all_params));
for (uint64_t i = 0; i < anno_map->num_annos; i++){ for (uint64_t i = 0; i < anno_map->num_annos; i++){
const char * anno = anno_map->annotations[i]; const char * anno = anno_map->annotations[i].ptr;
dragonfly_read_config(anno, &all_params[i]); dragonfly_read_config(anno, &all_params[i]);
if (anno_map->has_unanno_lp > 0){ if (anno_map->has_unanno_lp > 0){
...@@ -732,7 +732,7 @@ static void loggp_configure(){ ...@@ -732,7 +732,7 @@ static void loggp_configure(){
all_params = malloc(num_params * sizeof(*all_params)); all_params = malloc(num_params * sizeof(*all_params));
int rc = configuration_get_value_relpath(&config, "PARAMS", int rc = configuration_get_value_relpath(&config, "PARAMS",
"net_config_file", anno, config_file, MAX_NAME_LENGTH); "net_config_file", anno, config_file, MAX_NAME_LENGTH);
if (rc <= 0){ if (rc <= 0){
...@@ -237,18 +237,18 @@ void model_net_base_configure(){ ...@@ -237,18 +237,18 @@ void model_net_base_configure(){
// first grab all of the annotations and store locally // first grab all of the annotations and store locally
for (int c = 0; c < lpconf.lpannos_count; c++){ for (int c = 0; c < lpconf.lpannos_count; c++){
const config_anno_map_t *amap = &lpconf.lpannos[c]; const config_anno_map_t *amap = &lpconf.lpannos[c];
if (strncmp("modelnet_", amap->lp_name, 9) == 0){ if (strncmp("modelnet_", amap->lp_name.ptr, 9) == 0){
for (int n = 0; n < amap->num_annos; n++){ for (int n = 0; n < amap->num_annos; n++){
int a; int a;
for (a = 0; a < num_params; a++){ for (a = 0; a < num_params; a++){
if (annos[a] != NULL && if (annos[a] != NULL && amap->annotations[n].ptr != NULL &&
strcmp(amap->annotations[n], annos[a]) == 0){ strcmp(amap->annotations[n].ptr, annos[a]) == 0){
break; break;
if (a == num_params){ if (a == num_params){
// found a new annotation // found a new annotation
annos[num_params++] = amap->annotations[n]; annos[num_params++] = amap->annotations[n].ptr;
if (amap->has_unanno_lp){ if (amap->has_unanno_lp){
...@@ -61,7 +61,7 @@ void model_net_register(){ ...@@ -61,7 +61,7 @@ void model_net_register(){
for (int grp = 0; grp < lpconf.lpgroups_count; grp++){ for (int grp = 0; grp < lpconf.lpgroups_count; grp++){
config_lpgroup_t *lpgroup = &lpconf.lpgroups[grp]; config_lpgroup_t *lpgroup = &lpconf.lpgroups[grp];
for (int lpt = 0; lpt < lpgroup->lptypes_count; lpt++){ for (int lpt = 0; lpt < lpgroup->lptypes_count; lpt++){
char *nm = lpgroup->lptypes[lpt].name; char const *nm = lpgroup->lptypes[lpt].name.ptr;
for (int n = 0; n < MAX_NETS; n++){ for (int n = 0; n < MAX_NETS; n++){
if (!do_config_nets[n] && if (!do_config_nets[n] &&
strcmp(model_net_lp_config_names[n], nm) == 0){ strcmp(model_net_lp_config_names[n], nm) == 0){
...@@ -585,7 +585,7 @@ static void sn_configure() ...@@ -585,7 +585,7 @@ static void sn_configure()
num_params = anno_map->num_annos + (anno_map->has_unanno_lp > 0); num_params = anno_map->num_annos + (anno_map->has_unanno_lp > 0);
int rc; int rc;
rc = configuration_get_value_double(&config, "PARAMS", rc = configuration_get_value_double(&config, "PARAMS",
"net_startup_ns", anno, &all_params[i].net_startup_ns); "net_startup_ns", anno, &all_params[i].net_startup_ns);
...@@ -910,7 +910,7 @@ static void sp_configure(){ ...@@ -910,7 +910,7 @@ static void sp_configure(){
sp_read_config(anno_map->annotations[i], &all_params[i]); sp_read_config(anno_map->annotations[i].ptr, &all_params[i]);
sp_read_config(NULL, &all_params[anno_map->num_annos]); sp_read_config(NULL, &all_params[anno_map->num_annos]);
...@@ -242,7 +242,7 @@ static void torus_configure(){ ...@@ -242,7 +242,7 @@ static void torus_configure(){
torus_read_config(anno, &all_params[i]); torus_read_config(anno, &all_params[i]);
...@@ -1374,7 +1374,7 @@ void model_net_torus_get_dims( ...@@ -1374,7 +1374,7 @@ void model_net_torus_get_dims(
p = &all_params[anno_map->num_annos]; p = &all_params[anno_map->num_annos];
else { else {
for (i = 0; i < num_params; i++) { for (i = 0; i < num_params; i++) {
if (strcmp(anno, anno_map->annotations[i]) == 0) { if (strcmp(anno, anno_map->annotations[i].ptr) == 0) {
p = &all_params[i]; p = &all_params[i];
break; break;
Markdown is supported
0% or .
Please register or to comment
