Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
ae514ea2
Commit
ae514ea2
authored
Mar 27, 2017
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Plain Diff
Merge branch 'master' into 'master'
Adding Cortex generation of events See merge request !23
parents
14c34910
aebf1b5d
Changes
4
Hide whitespace changes
Inline
Side-by-side
Showing
4 changed files
with
29 additions
and
8 deletions
+29
-8
codes/codes-workload.h
+1
-0
configure.ac
configure.ac
+1
-1
src/network-workloads/model-net-mpi-replay.c
+5
-2
src/workload/methods/codes-dumpi-trace-nw-wrkld.c
+22
-5
No files found.
View file @
ae514ea2
@@ -72,6 +72,7 @@ struct dumpi_trace_params {
#ifdef ENABLE_CORTEX_PYTHON
char
cortex_script
MAX_NAME_LENGTH_WKLD
char
cortex_class
char
cortex_gen
#endif
configure.ac
View file @
ae514ea2
@@ -140,7 +140,7 @@ AC_ARG_WITH([boost],[AS_HELP_STRING([--with-boost@<:@=DIR@:>@],
[location of Boost Python installation])])
if [ test "x${with_python}" != "x" -a "x${with_boost}" != "x"] ; then
AC_CHECK_FILES([${with_python}/lib/libpython2.7.
a
${with_boost}/lib/libboost_python.a],
so
AM_CONDITIONAL(USE_PYTHON, true),
AC_MSG_ERROR(Could not find Python and/or Boost-Python libraries))
PYTHON_CFLAGS="-I${with_python}/include -I${with_boost}/include"
View file @
ae514ea2
@@ -54,8 +54,9 @@ struct codes_jobmap_params_list jobmap_p;
/* Variables for Cortex Support */
/* Matthieu's additions start */
static
char
cortex_file
512
static
char
cortex_class
512
static
char
cortex_file
512
\0
static
char
cortex_class
512
\0
static
char
cortex_gen
512
\0
#endif
/* Matthieu's additions end */
@@ -1158,6 +1159,7 @@ void nw_test_init(nw_state* s, tw_lp* lp)
strcpy
params_d
cortex_script
cortex_file
strcpy
params_d
cortex_class
cortex_class
strcpy
params_d
cortex_gen
cortex_gen
#endif
@@ -1534,6 +1536,7 @@ const tw_optdef app_opt [] =
TWOPT_CHAR
"cortex-file"
cortex_file
"Python file (without .py) containing the CoRtEx translation class"
TWOPT_CHAR
"cortex-class"
cortex_class
"Python class implementing the CoRtEx translator"
TWOPT_CHAR
"cortex-gen"
cortex_gen
"Python function to pre-generate MPI events"
#endif
TWOPT_END
View file @
ae514ea2
@@ -23,12 +23,12 @@
#include <cortex/cortex-python.h>
#endif
#define PROFILE_TYPE cortex_dumpi_profile*
#define UNDUMPI_OPEN cortex_undumpi_open
#define DUMPI_START_STREAM_READ cortex_dumpi_start_stream_read
#define UNDUMPI_CLOSE cortex_undumpi_close
#else
#define PROFILE_TYPE dumpi_profile*
#define UNDUMPI_OPEN undumpi_open
#define DUMPI_START_STREAM_READ dumpi_start_stream_read
#define UNDUMPI_CLOSE undumpi_close
#endif
@@ -646,7 +646,11 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
else
sprintf
file_name
"%s%d.bin"
dumpi_params
file_name
rank
profile
cortex_undumpi_open
file_name
app_id
dumpi_params
num_net_traces
rank
if
strcmp
dumpi_params
file_name
"none"
0
profile
cortex_undumpi_open
NULL
app_id
dumpi_params
num_net_traces
rank
else
profile
cortex_undumpi_open
file_name
app_id
dumpi_params
num_net_traces
rank
#else
profile
undumpi_open
file_name
#endif
@@ -728,7 +732,11 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
libundumpi_populate_callbacks
CORTEX_PYTHON_TRANSLATION
transarr
if
dumpi_params
cortex_script
0
0
transarr
else
CORTEX_MPICH_TRANSLATION
transarr
#else
transarr
#endif
@@ -738,7 +746,16 @@ int dumpi_trace_nw_workload_load(const char* params, int app_id, int rank)
//dumpi_free_header(trace_header);
cortex_python_set_module
dumpi_params
cortex_script
dumpi_params
cortex_class
if
dumpi_params
cortex_script
0
0
if
dumpi_params
cortex_class
0
0
dumpi_params
cortex_script
dumpi_params
cortex_class
else
dumpi_params
cortex_script
NULL
if
dumpi_params
cortex_gen
0
0
cortex_python_call_generator
profile
dumpi_params
cortex_gen
#endif
int
finalize_reached
0
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
