Commit ae4ab9e3 authored by Neil McGlohon's avatar Neil McGlohon Committed by Misbah Mubarak
Browse files
SWM_Compute now considers CPU Frequency
parent 7eea28f4
...@@ -27,6 +27,7 @@ ...@@ -27,6 +27,7 @@
#define ALLREDUCE_SHORT_MSG_SIZE 2048 #define ALLREDUCE_SHORT_MSG_SIZE 2048
//#define DBG_COMM 0 //#define DBG_COMM 0
using namespace std; using namespace std;
...@@ -36,7 +37,7 @@ static int rank_tbl_pop = 0; ...@@ -36,7 +37,7 @@ static int rank_tbl_pop = 0;
static int total_rank_cnt = 0; static int total_rank_cnt = 0;
ABT_thread global_prod_thread = NULL; ABT_thread global_prod_thread = NULL;
ABT_xstream self_es; ABT_xstream self_es;
long cpu_freq = 1.0; double cpu_freq = 1.0;
long num_allreduce = 0; long num_allreduce = 0;
long num_isends = 0; long num_isends = 0;
long num_irecvs = 0; long num_irecvs = 0;
...@@ -324,17 +325,22 @@ void SWM_Irecv(SWM_PEER peer, ...@@ -324,17 +325,22 @@ void SWM_Irecv(SWM_PEER peer,
void SWM_Compute(long cycle_count) void SWM_Compute(long cycle_count)
//NM: noting that cpu_frequency has been loaded in comm_online_workload_load() as GHz, e.g. cpu_freq = 2.0 means 2.0GHz
if(!cpu_freq) if(!cpu_freq)
cpu_freq = 2.0; cpu_freq = 2.0;
/* Add an event in the shared queue and then yield */ /* Add an event in the shared queue and then yield */
struct codes_workload_op wrkld_per_rank; struct codes_workload_op wrkld_per_rank;
double cpu_freq_hz = cpu_freq * 1000.0 * 1000.0 * 1000.0;
double delay_in_seconds = cycle_count / cpu_freq_hz;
double delay_in_ns = delay_in_seconds * 1000.0 * 1000.0 * 1000.0;
wrkld_per_rank.op_type = CODES_WK_DELAY; wrkld_per_rank.op_type = CODES_WK_DELAY;
/* TODO: Check how to convert cycle count into delay? */ /* TODO: Check how to convert cycle count into delay? */
wrkld_per_rank.u.delay.nsecs = cycle_count; wrkld_per_rank.u.delay.nsecs = delay_in_ns;
wrkld_per_rank.u.delay.seconds = (cycle_count) / (1000.0 * 1000.0 * 1000.0); wrkld_per_rank.u.delay.seconds = delay_in_seconds;
#ifdef DBG_COMM #ifdef DBG_COMM
printf("\n compute op delay: %ld ", cycle_count); printf("\n compute op delay: %ld ", delay_in_ns);
#endif #endif
/* Retreive the shared context state */ /* Retreive the shared context state */
ABT_thread prod; ABT_thread prod;
Markdown is supported
0% or .
Please register or to comment
