Commit acd02f78 authored by Caitlin Ross's avatar Caitlin Ross
Browse files
update to configure.ac for building with Damaris support
parent c2ba8ef7
...@@ -96,6 +96,8 @@ AC_ARG_WITH([damaris],[AS_HELP_STRING([--with-damaris], ...@@ -96,6 +96,8 @@ AC_ARG_WITH([damaris],[AS_HELP_STRING([--with-damaris],
if test "x${use_rdamaris}" = xyes ; then if test "x${use_rdamaris}" = xyes ; then
PKG_CHECK_MODULES_STATIC([ROSS_Damaris], [ross-damaris], [], PKG_CHECK_MODULES_STATIC([ROSS_Damaris], [ross-damaris], [],
[AC_MSG_ERROR([Could not find working ROSS-Damaris installation via pkg-config])]) [AC_MSG_ERROR([Could not find working ROSS-Damaris installation via pkg-config])])
PKG_CHECK_MODULES([rdplugins], [ross-damaris], [],
[AC_MSG_ERROR([Could not find the rdplugins library from ROSS-Damaris via pkg-config])])
fi fi
AM_CONDITIONAL(USE_RDAMARIS, [test "x${use_rdamaris}" = xyes]) AM_CONDITIONAL(USE_RDAMARIS, [test "x${use_rdamaris}" = xyes])
Markdown is supported
0% or .
Please register or to comment
