Commit aa2d7a8c authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
enabling optimistic mode for dragonfly-custom
parent dc65eb59
...@@ -81,11 +81,10 @@ struct terminal_custom_message ...@@ -81,11 +81,10 @@ struct terminal_custom_message
short num_rngs; short num_rngs;
short num_cll; short num_cll;
int qos_index;
short last_saved_qos; short last_saved_qos;
short qos_reset1; short qos_reset1;
short qos_reset2; short qos_reset2;
int saved_qos_data;
short saved_qos_status;
tw_stime saved_available_time; tw_stime saved_available_time;
tw_stime saved_avg_time; tw_stime saved_avg_time;
...@@ -21,7 +21,6 @@ ...@@ -21,7 +21,6 @@
#define MN_LP_NM "modelnet_dragonfly_custom" #define MN_LP_NM "modelnet_dragonfly_custom"
#define CONTROL_MSG_SZ 64 #define CONTROL_MSG_SZ 64
#define TRACE -1 #define TRACE -1
#define MAX_SYN_SENDS 10
#define MAX_WAIT_REQS 1024 #define MAX_WAIT_REQS 1024
#define CS_LP_DBG 1 #define CS_LP_DBG 1
#define RANK_HASH_TABLE_SZ 2000 #define RANK_HASH_TABLE_SZ 2000
...@@ -43,6 +42,7 @@ static int synthetic_pattern = 1; ...@@ -43,6 +42,7 @@ static int synthetic_pattern = 1;
static int preserve_wait_ordering = 0; static int preserve_wait_ordering = 0;
static int enable_msg_tracking = 0; static int enable_msg_tracking = 0;
static int is_synthetic = 0; static int is_synthetic = 0;
static int max_gen_data = 1310720;
tw_lpid TRACK_LP = -1; tw_lpid TRACK_LP = -1;
int nprocs = 0; int nprocs = 0;
static double total_syn_data = 0; static double total_syn_data = 0;
...@@ -796,7 +796,7 @@ static void gen_synthetic_tr(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * l ...@@ -796,7 +796,7 @@ static void gen_synthetic_tr(nw_state * s, tw_bf * bf, nw_message * m, tw_lp * l
m_new->msg_type = CLI_BCKGND_GEN; m_new->msg_type = CLI_BCKGND_GEN;
tw_event_send(e); tw_event_send(e);
if(s->num_sends == MAX_SYN_SENDS) if(s->gen_data == max_gen_data)
bf->c5 = 1; bf->c5 = 1;
s->is_finished = 1; s->is_finished = 1;
...@@ -2670,6 +2670,7 @@ const tw_optdef app_opt [] = ...@@ -2670,6 +2670,7 @@ const tw_optdef app_opt [] =
TWOPT_CHAR("workload_conf_file", workloads_conf_file, "workload config file name"), TWOPT_CHAR("workload_conf_file", workloads_conf_file, "workload config file name"),
TWOPT_UINT("num_net_traces", num_net_traces, "number of network traces"), TWOPT_UINT("num_net_traces", num_net_traces, "number of network traces"),
TWOPT_UINT("payload_sz", payload_sz, "size of payload for synthetic traffic "), TWOPT_UINT("payload_sz", payload_sz, "size of payload for synthetic traffic "),
TWOPT_UINT("max_gen_data", max_gen_data, "maximum data to be generated for synthetic traffic "),
TWOPT_UINT("eager_threshold", EAGER_THRESHOLD, "the transition point for eager/rendezvous protocols (Default 8192)"), TWOPT_UINT("eager_threshold", EAGER_THRESHOLD, "the transition point for eager/rendezvous protocols (Default 8192)"),
TWOPT_UINT("disable_compute", disable_delay, "disable compute simulation"), TWOPT_UINT("disable_compute", disable_delay, "disable compute simulation"),
TWOPT_UINT("payload_sz", payload_sz, "size of the payload for synthetic traffic"), TWOPT_UINT("payload_sz", payload_sz, "size of the payload for synthetic traffic"),
...@@ -46,7 +46,6 @@ ...@@ -46,7 +46,6 @@
#define LP_METHOD_NM_ROUT (model_net_method_names[DRAGONFLY_CUSTOM_ROUTER]) #define LP_METHOD_NM_ROUT (model_net_method_names[DRAGONFLY_CUSTOM_ROUTER])
static int debug_cnt = 0; static int debug_cnt = 0;
static int num_rc_windows = 100;
static int max_lvc_src_g = 1; static int max_lvc_src_g = 1;
static int max_lvc_intm_g = 3; static int max_lvc_intm_g = 3;
static int min_gvc_src_g = 0; static int min_gvc_src_g = 0;
...@@ -64,6 +63,12 @@ static long num_remote_packets = 0; ...@@ -64,6 +63,12 @@ static long num_remote_packets = 0;
/* time in nanosecs */ /* time in nanosecs */
static int bw_reset_window = 5000000; static int bw_reset_window = 5000000;
#define indexer3d(_ptr, _x, _y, _z, _maxx, _maxy, _maxz) \
((_ptr) + _z * (_maxx * _maxz) + _y * (_maxx) + _x)
#define indexer2d(_ptr, _x, _y, _maxx, _maxy) \
((_ptr) + _y * (_maxx) + _x)
using namespace std; using namespace std;
struct Link { struct Link {
int offset, type; int offset, type;
...@@ -267,8 +272,8 @@ struct terminal_state ...@@ -267,8 +272,8 @@ struct terminal_state
int * qos_data; int * qos_data;
int rc_index; int rc_index;
int** last_qos_status; int* last_qos_status;
int** last_qos_data; int* last_qos_data;
int last_qos_lvl; int last_qos_lvl;
int is_monitoring_bw; int is_monitoring_bw;
...@@ -307,6 +312,7 @@ struct terminal_state ...@@ -307,6 +312,7 @@ struct terminal_state
double fin_hops_sample; double fin_hops_sample;
tw_stime fin_chunks_time; tw_stime fin_chunks_time;
tw_stime busy_time_sample; tw_stime busy_time_sample;
int num_term_rc_windows;
char sample_buf[4096]; char sample_buf[4096];
struct dfly_cn_sample * sample_stat; struct dfly_cn_sample * sample_stat;
...@@ -386,6 +392,7 @@ struct router_state ...@@ -386,6 +392,7 @@ struct router_state
int op_arr_size; int op_arr_size;
int max_arr_size; int max_arr_size;
int num_rtr_rc_windows;
int* global_channel; int* global_channel;
...@@ -414,8 +421,8 @@ struct router_state ...@@ -414,8 +421,8 @@ struct router_state
int** qos_status; int** qos_status;
int** qos_data; int** qos_data;
/* for reverse handler */ /* for reverse handler */
int*** last_qos_status; int* last_qos_status;
int*** last_qos_data; int* last_qos_data;
const char * anno; const char * anno;
const dragonfly_param *params; const dragonfly_param *params;
...@@ -1115,19 +1122,16 @@ void issue_bw_monitor_event_rc(terminal_state * s, tw_bf * bf, terminal_custom_m ...@@ -1115,19 +1122,16 @@ void issue_bw_monitor_event_rc(terminal_state * s, tw_bf * bf, terminal_custom_m
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
int num_qos_levels = s->params->num_qos_levels; int num_qos_levels = s->params->num_qos_levels;
int rc_index = 0; int num_term_rc_wins = s->num_term_rc_windows;
if(s->rc_index > 0) int rc_index = msg->qos_index;
rc_index = s->rc_index - 1;
for(int k = 0; k < num_qos_levels; k++) for(int k = 0; k < num_qos_levels; k++)
s->qos_status[k] = s->last_qos_status[rc_index][k]; s->qos_status[k] = *(indexer2d(s->last_qos_status, rc_index, k, num_term_rc_wins, num_qos_levels));
s->qos_data[k] = s->last_qos_data[rc_index][k]; s->qos_data[k] = *(indexer2d(s->last_qos_data, rc_index, k, num_term_rc_wins, num_qos_levels));
s->last_qos_status[rc_index][k] = 0; *(indexer2d(s->last_qos_status, rc_index, k, num_term_rc_wins, num_qos_levels)) = 0;
s->last_qos_data[rc_index][k] = 0; *(indexer2d(s->last_qos_data, rc_index, k, num_term_rc_wins, num_qos_levels)) = 0;
s->rc_index--;
/* resets the bandwidth numbers recorded so far */ /* resets the bandwidth numbers recorded so far */
void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_message * msg, tw_lp * lp) void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_message * msg, tw_lp * lp)
...@@ -1137,18 +1141,42 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess ...@@ -1137,18 +1141,42 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess
msg->num_rngs = 0; msg->num_rngs = 0;
int rc_index = s->rc_index; int rc_index = s->rc_index;
/* dynamically reallocate array if index has reached max-size */
if(s->rc_index == s->num_term_rc_windows)
s->num_term_rc_windows *= 2;
int * tmp1 = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int));
int * tmp2 = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int));
/* now copy elements one by one. can't use memcpy with 2d array. */
for(int i = 0; i < s->num_term_rc_windows; i++)
for(int j = 0; j < num_qos_levels; j++)
*(indexer2d(tmp1, i, j, s->num_term_rc_windows, num_qos_levels)) = *(indexer2d(s->last_qos_status, i, j, num_term_rc_wins, num_qos_levels));
*(indexer2d(tmp2, i, j, s->num_term_rc_windows, num_qos_levels)) = *(indexer2d(s->last_qos_data, i, j, num_term_rc_wins, num_qos_levels));
free(s->last_qos_status);
free(s->last_qos_data);
s->last_qos_status = tmp1;
s->last_qos_data = tmp2;
/* Reset the qos status and bandwidth consumption. */ /* Reset the qos status and bandwidth consumption. */
s->last_qos_status[rc_index][k] = s->qos_status[k]; *(indexer2d(s->last_qos_status, rc_index, k, num_term_rc_wins, num_qos_levels)) = s->qos_status[k];
s->last_qos_data[rc_index][k] = s->qos_data[k]; *(indexer2d(s->last_qos_data, rc_index, k, num_term_rc_wins, num_qos_levels)) = s->qos_data[k];
s->qos_status[k] = Q_ACTIVE; s->qos_status[k] = Q_ACTIVE;
s->qos_data[k] = 0; s->qos_data[k] = 0;
msg->qos_index = s->rc_index;
s->rc_index++; s->rc_index++;
assert(s->rc_index < num_rc_windows); assert(s->rc_index < s->num_term_rc_windows);
/* if(s->router_id == 0) /* if(s->router_id == 0)
fprintf(dragonfly_term_bw_log, "\n %d %lf %lf ", s->terminal_id, tw_now(lp), s->busy_time_sample); fprintf(dragonfly_term_bw_log, "\n %d %lf %lf ", s->terminal_id, tw_now(lp), s->busy_time_sample);
...@@ -1171,9 +1199,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess ...@@ -1171,9 +1199,7 @@ void issue_bw_monitor_event(terminal_state * s, tw_bf * bf, terminal_custom_mess
void issue_rtr_bw_monitor_event_rc(router_state * s, tw_bf * bf, terminal_custom_message * msg, tw_lp * lp) void issue_rtr_bw_monitor_event_rc(router_state * s, tw_bf * bf, terminal_custom_message * msg, tw_lp * lp)
int rc_index = 0; int rc_index = msg->qos_index;
if(s->rc_index > 0)
for(int i = 0 ; i < msg->num_cll; i++) for(int i = 0 ; i < msg->num_cll; i++)
...@@ -1182,13 +1208,12 @@ void issue_rtr_bw_monitor_event_rc(router_state * s, tw_bf * bf, terminal_custom ...@@ -1182,13 +1208,12 @@ void issue_rtr_bw_monitor_event_rc(router_state * s, tw_bf * bf, terminal_custom
s->qos_status[j][k] = s->last_qos_status[rc_index][j][k]; s->qos_status[j][k] = *(indexer3d(s->last_qos_status, rc_index, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels));
s->qos_data[j][k] = s->last_qos_data[rc_index][j][k]; s->qos_data[j][k] = *(indexer3d(s->last_qos_data, rc_index, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels));
s->last_qos_status[rc_index][j][k] = 0; *(indexer3d(s->last_qos_status, rc_index, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = 0;
s->last_qos_data[rc_index][j][k] = 0; *(indexer3d(s->last_qos_data, rc_index, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = 0;
s->rc_index--;
void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_message * msg, tw_lp * lp) void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_message * msg, tw_lp * lp)
...@@ -1197,18 +1222,46 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me ...@@ -1197,18 +1222,46 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me
int num_rtr_rc_windows = s->num_rtr_rc_windows;
/* dynamically reallocate the array.. */
if(s->rc_index == s->num_rtr_rc_windows)
s->num_rtr_rc_windows *= 2;
int * tmp1 = (int*)calloc(s->num_rtr_rc_windows * s->params->radix * num_qos_levels, sizeof(int));
int * tmp2 = (int*)calloc(s->num_rtr_rc_windows * s->params->radix * num_qos_levels, sizeof(int));
for(int i = 0; i < num_rtr_rc_windows; i++)
for(int j = 0; j < s->params->radix; j++)
*(indexer3d(tmp1, i, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = *(indexer3d(s->last_qos_status, i, j, k, num_rtr_rc_windows, s->params->radix, num_qos_levels));
*(indexer3d(tmp2, i, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = *(indexer3d(s->last_qos_data, i, j, k, num_rtr_rc_windows, s->params->radix, num_qos_levels));
assert(rc_index < s->num_rtr_rc_windows && rc_index >= 0);
for(int j = 0; j < s->params->radix; j++) for(int j = 0; j < s->params->radix; j++)
s->last_qos_status[rc_index][j][k] = s->qos_status[j][k]; *(indexer3d(s->last_qos_status, rc_index, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = s->qos_status[j][k];
s->last_qos_data[rc_index][j][k] = s->qos_data[j][k]; *(indexer3d(s->last_qos_data, rc_index, j, k, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = s->qos_data[j][k];
...@@ -1216,7 +1269,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me ...@@ -1216,7 +1269,7 @@ void issue_rtr_bw_monitor_event(router_state * s, tw_bf * bf, terminal_custom_me
int bw_consumed = get_rtr_bandwidth_consumption(s, k, j); int bw_consumed = get_rtr_bandwidth_consumption(s, k, j);
if(s->router_id == 0) if(s->router_id == 0)
fprintf(dragonfly_rtr_bw_log, "\n %d %f %d %d %d %d %d %f", s->router_id, tw_now(lp), j, k, bw_consumed, s->qos_status[j][k], s->qos_data[j][k], s->busy_time_sample[j]); //fprintf(dragonfly_rtr_bw_log, "\n %d %f %d %d %d %d %d %f", s->router_id, tw_now(lp), j, k, bw_consumed, s->qos_status[j][k], s->qos_data[j][k], s->busy_time_sample[j]);
...@@ -1250,20 +1303,21 @@ void reset_rtr_bw_counters(router_state * s, ...@@ -1250,20 +1303,21 @@ void reset_rtr_bw_counters(router_state * s,
terminal_custom_message * msg, terminal_custom_message * msg,
tw_lp * lp) tw_lp * lp)
if(msg->type == R_BANDWIDTH && s->rc_index > 0) int num_qos_levels = s->params->num_qos_levels;
if(msg->type == R_BANDWIDTH)
s->rc_index = 0; for(int k = 0; k < s->num_rtr_rc_windows; k++)
for(int k = 0; k < num_rc_windows; k++)
for(int i = 0; i < s->params->radix; i++) for(int i = 0; i < s->params->radix; i++)
for(int j = 0; j < s->params->num_qos_levels; j++) for(int j = 0; j < num_qos_levels; j++)
s->last_qos_status[k][i][j] = 0; *(indexer3d(s->last_qos_status, k, i, j, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = 0;
s->last_qos_data[k][i][j] = 0; *(indexer3d(s->last_qos_data, k, i, j, s->num_rtr_rc_windows, s->params->radix, num_qos_levels)) = 0;
s->rc_index = 0;
void reset_bw_counters(terminal_state * s, void reset_bw_counters(terminal_state * s,
...@@ -1271,14 +1325,15 @@ void reset_bw_counters(terminal_state * s, ...@@ -1271,14 +1325,15 @@ void reset_bw_counters(terminal_state * s,
if(msg->type == T_BANDWIDTH && s->rc_index > 0) int num_qos_levels = s->params->num_qos_levels;
if(msg->type == T_BANDWIDTH)
for(int i = 0; i < num_rc_windows; i++) for(int i = 0; i < s->num_term_rc_windows; i++)
for(int j = 0; j < s->params->num_qos_levels; j++) for(int j = 0; j < s->params->num_qos_levels; j++)
s->last_qos_status[i][j] = 0; *(indexer2d(s->last_qos_status, i, j, s->num_term_rc_windows, num_qos_levels)) = 0;
s->last_qos_data[i][j] = 0; *(indexer2d(s->last_qos_data, i, j, s->num_term_rc_windows, num_qos_levels)) = 0;
s->rc_index = 0; s->rc_index = 0;
...@@ -1292,7 +1347,8 @@ terminal_custom_init( terminal_state * s, ...@@ -1292,7 +1347,8 @@ terminal_custom_init( terminal_state * s,
s->packet_gen = 0; s->packet_gen = 0;
s->packet_fin = 0; s->packet_fin = 0;
s->is_monitoring_bw = 0; s->is_monitoring_bw = 0;
s->num_term_rc_windows = 100;
s->rc_index = 0;
int i; int i;
char anno[MAX_NAME_LENGTH]; char anno[MAX_NAME_LENGTH];
...@@ -1347,13 +1403,9 @@ terminal_custom_init( terminal_state * s, ...@@ -1347,13 +1403,9 @@ terminal_custom_init( terminal_state * s,
s->qos_data = (int*)calloc(num_qos_levels, sizeof(int)); s->qos_data = (int*)calloc(num_qos_levels, sizeof(int));
/* for reverse handlers */ /* for reverse handlers */
s->last_qos_status = (int**)calloc(num_rc_windows, sizeof(int*)); s->last_qos_status = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int));
s->last_qos_data = (int**)calloc(num_rc_windows, sizeof(int*)); s->last_qos_data = (int*)calloc(s->num_term_rc_windows * num_qos_levels, sizeof(int));
s->last_qos_status[i] = (int*)calloc(num_qos_levels, sizeof(int));
s->last_qos_data[i] = (int*)calloc(num_qos_levels, sizeof(int));
for(i = 0; i < num_qos_levels; i++) for(i = 0; i < num_qos_levels; i++)
s->qos_data[i] = 0; s->qos_data[i] = 0;
...@@ -1420,16 +1472,17 @@ void router_custom_setup(router_state * r, tw_lp * lp) ...@@ -1420,16 +1472,17 @@ void router_custom_setup(router_state * r, tw_lp * lp)
if(r->router_id == 0) if(r->router_id == 0)
char rtr_bw_log[64]; char rtr_bw_log[128];
sprintf(rtr_bw_log, "router-bw-tracker"); sprintf(rtr_bw_log, "router-bw-tracker");
dragonfly_rtr_bw_log = fopen(rtr_bw_log, "w"); dragonfly_rtr_bw_log = fopen(rtr_bw_log, "w");
if(dragonfly_rtr_bw_log != NULL) //if(dragonfly_rtr_bw_log != NULL)
fprintf(dragonfly_rtr_bw_log, "\n router-id time-stamp port-id qos-level bw-consumed qos-status qos-data busy-time"); // fprintf(dragonfly_rtr_bw_log, "\n router-id time-stamp port-id qos-level bw-consumed qos-status qos-data busy-time");
//printf("\n Local router id %d global id %d ", r->router_id, lp->gid); //printf("\n Local router id %d global id %d ", r->router_id, lp->gid);
r->num_rtr_rc_windows = 100;
r->rc_index = 0; r->rc_index = 0;
r->is_monitoring_bw = 0; r->is_monitoring_bw = 0;
r->fwd_events = 0; r->fwd_events = 0;
...@@ -1441,23 +1494,9 @@ void router_custom_setup(router_state * r, tw_lp * lp) ...@@ -1441,23 +1494,9 @@ void router_custom_setup(router_state * r, tw_lp * lp)
int num_qos_levels = p->num_qos_levels; int num_qos_levels = p->num_qos_levels;
/* history window for bandwidth reverse computation */ /* history window for bandwidth reverse computation */
r->last_qos_status = (int***)calloc(num_rc_windows, sizeof(int**)); r->last_qos_status = (int*)calloc(r->num_rtr_rc_windows * r->params->radix * num_qos_levels, sizeof(int));
r->last_qos_data = (int***)calloc(num_rc_windows, sizeof(int**)); r->last_qos_data = (int*)calloc(r->num_rtr_rc_windows * r->params->radix * num_qos_levels, sizeof(int));
r->last_qos_status[k] = (int**)calloc(p->radix, sizeof(int*));
r->last_qos_data[k] = (int**)calloc(p->radix, sizeof(int*));
for(int j = 0; j < p->radix; j++)
r->last_qos_status[k][j] = (int*)calloc(num_qos_levels, sizeof(int));
r->last_qos_data[k][j] = (int*)calloc(num_qos_levels, sizeof(int));
for(int i = 0; i < num_qos_levels; i++)
r->last_qos_status[k][j][i] = 0;
r->last_qos_data[k][j][i] = 0;
r->global_channel = (int*)calloc(p->num_global_channels, sizeof(int)); r->global_channel = (int*)calloc(p->num_global_channels, sizeof(int));
r->next_output_available_time = (tw_stime*)calloc(p->radix, sizeof(tw_stime)); r->next_output_available_time = (tw_stime*)calloc(p->radix, sizeof(tw_stime));
r->cur_hist_start_time = (tw_stime*)calloc(p->radix, sizeof(tw_stime)); r->cur_hist_start_time = (tw_stime*)calloc(p->radix, sizeof(tw_stime));
...@@ -2122,7 +2161,9 @@ static void packet_send(terminal_state * s, tw_bf * bf, terminal_custom_message ...@@ -2122,7 +2161,9 @@ static void packet_send(terminal_state * s, tw_bf * bf, terminal_custom_message
msg->num_cll = 0; msg->num_cll = 0;
vcg = get_next_vcg(s, bf, msg, lp); if(num_qos_levels > 1)
/* For a terminal to router connection, there would be as many VCGs as number /* For a terminal to router connection, there would be as many VCGs as number
* of VCs*/ * of VCs*/
Markdown is supported
0% or .
Please register or to comment
