Commit a6f5d47c authored by Neil McGlohon's avatar Neil McGlohon
Browse files
DFP: Optimize get two random connections
parent 6e4081e6
...@@ -2537,7 +2537,7 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag ...@@ -2537,7 +2537,7 @@ static int dfp_score_connection(router_state *s, tw_bf *bf, terminal_plus_messag
static vector< Connection > dfp_select_two_connections(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, vector< Connection > conns) static vector< Connection > dfp_select_two_connections(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, vector< Connection > conns)
if(conns.size() < 2) { if(conns.size() < 2) {
tw_rand_integer(lp->rng,0,2); tw_rand_integer(lp->rng,0,2); //ensure this function always uses two rngs
if(conns.size() == 1) if(conns.size() == 1)
return conns; return conns;
...@@ -2545,44 +2545,21 @@ static vector< Connection > dfp_select_two_connections(router_state *s, tw_bf *b ...@@ -2545,44 +2545,21 @@ static vector< Connection > dfp_select_two_connections(router_state *s, tw_bf *b
return vector< Connection>(); return vector< Connection>();
int rand_sel_1, rand_sel_2_offset;
int rand_sel_1, rand_sel_2; int num_conns = conns.size();
vector<int> indices;
vector<int>::iterator it;
for(int i = 0; i < conns.size(); i++)
indices.push_back(i);
// printf("Selecting 1st from %d\n",indices.size());
int pi = tw_rand_integer(lp->rng, 0, indices.size()-1);
rand_sel_1 = indices[pi];
for(it = indices.begin(); it != indices.end(); it++) //because std::find wasn't working :/
if (*it == rand_sel_1)
break;
indices.erase(it); //erases the number located at pos pi
// printf("Selecting 2nd from %d\n",indices.size()); rand_sel_1 = tw_rand_integer(lp->rng, 0, num_conns-1);
pi = tw_rand_integer(lp->rng, 0, indices.size()-1); rand_sel_2_offset = tw_rand_integer(lp->rng, 0, num_conns-1); //number of indices to count up from the previous selected one. Avoids selecting same one twice
rand_sel_2 = indices[pi]; int rand_sel_2 = (rand_sel_1 + rand_sel_2_offset) % num_conns;
for(it = indices.begin(); it != indices.end(); it++) //because std::find wasn't working :/ vector< Connection > retVec;
{ retVec.push_back(conns[rand_sel_1]);
if (*it == rand_sel_2) retVec.push_back(conns[rand_sel_2]);
break;
vector< Connection > selected_conns; return retVec;
selected_conns.push_back(conns[rand_sel_1]);
selected_conns.push_back(conns[rand_sel_2]);
return selected_conns;
static Connection get_absolute_best_connection_from_conns(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, vector<Connection> conns) static Connection get_absolute_best_connection_from_conns(router_state *s, tw_bf *bf, terminal_plus_message *msg, tw_lp *lp, vector<Connection> conns)
tw_rand_integer(lp->rng,0,1); tw_rand_integer(lp->rng,0,1);
Markdown is supported
0% or .
Please register or to comment
