Commit a68fd5ec authored by Neil McGlohon's avatar Neil McGlohon
Browse files
Fix max vc size assignment
parent 1b9a6e37
...@@ -2595,8 +2595,6 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -2595,8 +2595,6 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
cur_chunk->msg.vc_index = output_port; cur_chunk->msg.vc_index = output_port;
cur_chunk->msg.next_stop = next_stop; cur_chunk->msg.next_stop = next_stop;
int max_vc_size = s->params->cn_vc_size;
output_chan = 0; output_chan = 0;
if(cur_chunk->msg.path_type == MINIMAL) if(cur_chunk->msg.path_type == MINIMAL)
...@@ -2608,6 +2606,19 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess ...@@ -2608,6 +2606,19 @@ static void router_packet_receive(router_state *s, tw_bf *bf, terminal_plus_mess
output_chan = 1; output_chan = 1;
ConnectionType port_type = s->connMan.get_port_type(output_port);
int max_vc_size = 0;
if (port_type == CONN_GLOBAL) {
max_vc_size = s->params->global_vc_size;
else if (port_type == CONN_LOCAL) {
max_vc_size = s->params->local_vc_size;
else {
assert(port_type == CONN_TERMINAL)
max_vc_size = s->param->cn_vc_size;
cur_chunk->msg.output_chan = output_chan; cur_chunk->msg.output_chan = output_chan;
cur_chunk->msg.my_N_hop++; cur_chunk->msg.my_N_hop++;
Markdown is supported
0% or .
Please register or to comment
