Commit a4d43ae4 authored by Caitlin Ross's avatar Caitlin Ross
added event tracing support to model net base lp
parent 63751b09
...@@ -63,6 +63,8 @@ struct model_net_method ...@@ -63,6 +63,8 @@ struct model_net_method
revent_f mn_sample_rc_fn; revent_f mn_sample_rc_fn;
init_f mn_sample_init_fn; init_f mn_sample_init_fn;
final_f mn_sample_fini_fn; final_f mn_sample_fini_fn;
void (*mn_ev_register)(st_event_collect *base_type);
const st_event_collect* (*mn_get_event_type)();
extern struct model_net_method * method_array[]; extern struct model_net_method * method_array[];
...@@ -405,8 +405,8 @@ int main( ...@@ -405,8 +405,8 @@ int main(
if (g_st_ev_rb_collect || g_st_ev_collect) if (g_st_ev_rb_collect || g_st_ev_collect)
dragonfly_register_evcol(); //dragonfly_register_evcol();
router_register_evcol(); //router_register_evcol();
svr_register_evcol(); svr_register_evcol();
...@@ -3289,14 +3289,14 @@ static const st_event_collect *dragonfly_get_event_type(void) ...@@ -3289,14 +3289,14 @@ static const st_event_collect *dragonfly_get_event_type(void)
return(&event_types[0]); return(&event_types[0]);
void dragonfly_register_evcol() void dragonfly_register_evcol(st_event_collect *base_type)
ev_type_register(LP_CONFIG_NM_TERM, dragonfly_get_event_type()); ev_type_register(LP_CONFIG_NM_TERM, base_type);
void router_register_evcol() void router_register_evcol(st_event_collect *base_type)
ev_type_register(LP_CONFIG_NM_ROUT, dragonfly_get_event_type()); ev_type_register(LP_CONFIG_NM_ROUT, base_type);
/* returns the dragonfly lp type for lp registration */ /* returns the dragonfly lp type for lp registration */
...@@ -3335,6 +3335,8 @@ struct model_net_method dragonfly_method = ...@@ -3335,6 +3335,8 @@ struct model_net_method dragonfly_method =
.mn_sample_rc_fn = (void*)dragonfly_sample_rc_fn, .mn_sample_rc_fn = (void*)dragonfly_sample_rc_fn,
.mn_sample_init_fn = (void*)dragonfly_sample_init, .mn_sample_init_fn = (void*)dragonfly_sample_init,
.mn_sample_fini_fn = (void*)dragonfly_sample_fin .mn_sample_fini_fn = (void*)dragonfly_sample_fin
.mn_ev_register = dragonfly_register_evcol,
.mn_get_event_type = dragonfly_get_event_type,
struct model_net_method dragonfly_router_method = struct model_net_method dragonfly_router_method =
...@@ -3354,4 +3356,6 @@ struct model_net_method dragonfly_router_method = ...@@ -3354,4 +3356,6 @@ struct model_net_method dragonfly_router_method =
.mn_sample_rc_fn = (void*)dragonfly_rsample_rc_fn, .mn_sample_rc_fn = (void*)dragonfly_rsample_rc_fn,
.mn_sample_init_fn = (void*)dragonfly_rsample_init, .mn_sample_init_fn = (void*)dragonfly_rsample_init,
.mn_sample_fini_fn = (void*)dragonfly_rsample_fin .mn_sample_fini_fn = (void*)dragonfly_rsample_fin
.mn_ev_register = router_register_evcol,
...@@ -113,6 +113,19 @@ tw_lptype model_net_base_lp = { ...@@ -113,6 +113,19 @@ tw_lptype model_net_base_lp = {
sizeof(model_net_base_state), sizeof(model_net_base_state),
void mn_event_collect(model_net_wrap_msg *m, tw_lp *lp, char *buffer)
int type = (int) m->h.event_type;
memcpy(buffer, &type, sizeof(type));
st_event_collect mn_event_types = {
(rbev_col_f) mn_event_collect,
sizeof(int),
(ev_col_f) mn_event_collect,
sizeof(int),
/**** END LP, EVENT PROCESSING FUNCTION DECLS ****/ /**** END LP, EVENT PROCESSING FUNCTION DECLS ****/
/**** BEGIN IMPLEMENTATIONS ****/ /**** BEGIN IMPLEMENTATIONS ****/
...@@ -151,6 +164,13 @@ void model_net_base_register(int *do_config_nets){ ...@@ -151,6 +164,13 @@ void model_net_base_register(int *do_config_nets){
&model_net_base_lp); &model_net_base_lp);
else else
method_array[i]->mn_register(&model_net_base_lp); method_array[i]->mn_register(&model_net_base_lp);
if (method_array[i]->mn_ev_register == NULL)
ev_type_register(model_net_lp_config_names[i], &mn_event_types);
else
method_array[i]->mn_ev_register(&mn_event_types);
Markdown is supported
0%
or
Please register or to comment
