Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
a349938c
Commit
a349938c
authored
Sep 14, 2015
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
Adding congestion control in dragonfly (mostly comes from uiuc_tracer)
parent
a78fee52
Changes
5
Hide whitespace changes
Inline
Side-by-side
Showing
5 changed files
with
1342 additions
and
1170 deletions
+1342
-1170
codes/net/dragonfly.h
+4
-0
src/models/networks/model-net/dragonfly.c
+1331
-1162
src/models/networks/model-net/torus.c
+1
-1
tests/conf/modelnet-test-dragonfly.conf
+2
-3
tests/modelnet-test.c
+4
-4
No files found.
View file @
a349938c
@@ -40,6 +40,9 @@ struct terminal_message
/* number of hops traversed by the packet */
short
my_N_hop
short
my_l_hop
my_g_hop
short
saved_channel
/* Intermediate LP ID from which this message is coming */
unsigned
int
intm_lp_id
short
new_vc
@@ -77,6 +80,7 @@ struct terminal_message
/* LP ID of the sending node, has to be a network node in the dragonfly */
tw_lpid
sender_node
tw_lpid
next_stop
/* for reverse computation */
struct
pending_router_msgs
saved_elem
View file @
a349938c
This source diff could not be displayed because it is too large. You can
view the blob
instead.
View file @
a349938c
@@ -915,7 +915,7 @@ static void packet_generate( nodes_state * s,
m_gen_data_src
char
m_gen_data_src
msg
remote_event_size_bytes
if
msg
local_event_size_bytes
memcpy
m_gen_data
m_gen_data_src
msg
memcpy
m_gen_data
m_gen_data_src
msg
tw_event_send
e_gen
View file @
a349938c
@@ -16,14 +16,13 @@ PARAMS
modelnet_scheduler
"fcfs"
chunk_size
"32"
# modelnet_scheduler="round-robin";
num_vcs
"1"
num_routers
"4"
local_vc_size
"2048"
global_vc_size
"8192"
cn_vc_size
512
cn_vc_size
1024
local_bandwidth
"5.25"
global_bandwidth
"4.7"
cn_bandwidth
"5.25"
message_size
"3
12
message_size
"3
20
routing
"minimal"
View file @
a349938c
@@ -24,8 +24,8 @@
#include "codes/configuration.h"
#include "codes/lp-type-lookup.h"
#define NUM_REQS
1
/* number of requests sent by each server */
#define PAYLOAD_SZ
2048
/* size of simulated data payload, bytes */
#define NUM_REQS
5
#define PAYLOAD_SZ
4096
static
int
net_id
0
static
int
num_routers
0
@@ -455,7 +455,7 @@ static void handle_ack_event(
memcpy
m_remote
m_local
sizeof
svr_msg
m_remote
svr_event_type
do_pull
ACK
REQ
printf("handle_ack_event(), lp %llu.\n", (unsigned long long)lp->gid);
printf
\n
unsigned
long
long
lp
gid
/* safety check that this request got to the right server */
// printf("\n m->src %d lp->gid %d ", m->src, lp->gid);
@@ -514,7 +514,7 @@ static void handle_req_event(
memcpy
m_remote
m_local
sizeof
svr_msg
m_remote
svr_event_type
ACK
printf("handle_req_event(), lp %llu src %llu .\n", (unsigned long long)lp->gid, (unsigned long long) m->src);
printf
\n
unsigned
long
long
lp
gid
unsigned
long
long
m
src
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
