Commit a2f3680b authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Adding slimfly test to make tests
parent a3d030ed
...@@ -26,6 +26,7 @@ TESTS += tests/lp-io-test.sh \ ...@@ -26,6 +26,7 @@ TESTS += tests/lp-io-test.sh \
tests/modelnet-test-torus.sh \ tests/modelnet-test-torus.sh \
tests/modelnet-test-loggp.sh \ tests/modelnet-test-loggp.sh \
tests/modelnet-test-dragonfly.sh \ tests/modelnet-test-dragonfly.sh \
tests/modelnet-test-slimfly.sh \
tests/modelnet-p2p-bw-loggp.sh \ tests/modelnet-p2p-bw-loggp.sh \
tests/modelnet-prio-sched-test.sh tests/modelnet-prio-sched-test.sh
...@@ -48,6 +49,7 @@ EXTRA_DIST += tests/lp-io-test.sh \ ...@@ -48,6 +49,7 @@ EXTRA_DIST += tests/lp-io-test.sh \
tests/modelnet-prio-sched-test.sh \ tests/modelnet-prio-sched-test.sh \
tests/conf/concurrent_msg_recv.conf \ tests/conf/concurrent_msg_recv.conf \
...@@ -57,6 +59,7 @@ EXTRA_DIST += tests/lp-io-test.sh \ ...@@ -57,6 +59,7 @@ EXTRA_DIST += tests/lp-io-test.sh \
tests/conf/modelnet-test-bw-tri.conf \ tests/conf/modelnet-test-bw-tri.conf \
tests/conf/modelnet-test.conf \ tests/conf/modelnet-test.conf \
tests/conf/modelnet-test-dragonfly.conf \ tests/conf/modelnet-test-dragonfly.conf \
tests/conf/modelnet-test-slimfly.conf \
tests/conf/modelnet-test-loggp.conf \ tests/conf/modelnet-test-loggp.conf \
tests/conf/modelnet-test-simplep2p.conf \ tests/conf/modelnet-test-simplep2p.conf \
tests/conf/modelnet-test-latency.conf \ tests/conf/modelnet-test-latency.conf \
#!/bin/bash
tests/modelnet-test --sync=1 -- tests/conf/modelnet-test-slimfly.conf
Markdown is supported
0% or .
Please register or to comment
