Commit a28856ca authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
adding dumpi workload support in codes-workload-dump utility
parent 0b4fb673
...@@ -64,8 +64,8 @@ struct scala_trace_params { ...@@ -64,8 +64,8 @@ struct scala_trace_params {
struct dumpi_trace_params { struct dumpi_trace_params {
int num_net_traces;
char file_name[MAX_NAME_LENGTH_WKLD]; char file_name[MAX_NAME_LENGTH_WKLD];
int num_net_traces;
...@@ -14,6 +14,7 @@ static char type[128] = {'\0'}; ...@@ -14,6 +14,7 @@ static char type[128] = {'\0'};
static darshan_params d_params = {"", 0}; static darshan_params d_params = {"", 0};
static iolang_params i_params = {0, 0, "", ""}; static iolang_params i_params = {0, 0, "", ""};
static recorder_params r_params = {"", 0}; static recorder_params r_params = {"", 0};
static dumpi_trace_params du_params = {"", 0};
static int n = -1; static int n = -1;
static struct option long_opts[] = static struct option long_opts[] =
...@@ -26,13 +27,14 @@ static struct option long_opts[] = ...@@ -26,13 +27,14 @@ static struct option long_opts[] =
{"i-use-relpath", no_argument, NULL, 'p'}, {"i-use-relpath", no_argument, NULL, 'p'},
{"r-trace-dir", required_argument, NULL, 'd'}, {"r-trace-dir", required_argument, NULL, 'd'},
{"r-nprocs", required_argument, NULL, 'x'}, {"r-nprocs", required_argument, NULL, 'x'},
{"dumpi-log", required_argument, NULL, 'w'},
{NULL, 0, NULL, 0} {NULL, 0, NULL, 0}
void usage(){ void usage(){
fprintf(stderr, fprintf(stderr,
"Usage: codes-workload-dump --type TYPE --num-ranks N [OPTION...]" "Usage: codes-workload-dump --type TYPE --num-ranks N [OPTION...]"
"--type: type of workload (\"darshan_io_workload\", \"iolang_workload\", etc.)\n" "--type: type of workload (\"darshan_io_workload\", \"iolang_workload\", dumpi-trace-workload\" etc.)\n"
"--num-ranks: number of ranks to process (if not set, it is set by the workload)\n" "--num-ranks: number of ranks to process (if not set, it is set by the workload)\n"
"DARSHAN OPTIONS (darshan_io_workload)\n" "DARSHAN OPTIONS (darshan_io_workload)\n"
"--d-log: darshan log file\n" "--d-log: darshan log file\n"
...@@ -43,7 +45,9 @@ void usage(){ ...@@ -43,7 +45,9 @@ void usage(){
"RECORDER OPTIONS (recorder_io_workload)\n" "RECORDER OPTIONS (recorder_io_workload)\n"
"--r-trace-dir: directory containing recorder trace files\n" "--r-trace-dir: directory containing recorder trace files\n"
"--r-nprocs: number of ranks in original recorder workload\n" "--r-nprocs: number of ranks in original recorder workload\n"
"-s: print final workload stats\n"); "-s: print final workload stats\n"
"DUMPI TRACE OPTIONS (dumpi-trace-workload) \n"
"--dumpi-log: dumpi log file \n");
int main(int argc, char *argv[]) int main(int argc, char *argv[])
...@@ -88,7 +92,7 @@ int main(int argc, char *argv[]) ...@@ -88,7 +92,7 @@ int main(int argc, char *argv[])
int64_t num_testalls = 0; int64_t num_testalls = 0;
char ch; char ch;
while ((ch = getopt_long(argc, argv, "t:n:l:a:m:sp", long_opts, NULL)) != -1){ while ((ch = getopt_long(argc, argv, "t:n:l:a:m:sp:w", long_opts, NULL)) != -1){
switch (ch){ switch (ch){
case 't': case 't':
strcpy(type, optarg); strcpy(type, optarg);
...@@ -115,6 +119,9 @@ int main(int argc, char *argv[]) ...@@ -115,6 +119,9 @@ int main(int argc, char *argv[])
case 'x': case 'x':
r_params.nprocs = atol(optarg); r_params.nprocs = atol(optarg);
break; break;
case 'w':
strcpy(du_params.file_name, optarg);
break;
case 's': case 's':
print_stats = 1; print_stats = 1;
break; break;
...@@ -178,6 +185,28 @@ int main(int argc, char *argv[]) ...@@ -178,6 +185,28 @@ int main(int argc, char *argv[])
wparams = (char *)&r_params; wparams = (char *)&r_params;
else if(strcmp(type, "dumpi-trace-workload") == 0)
if(n == -1){
fprintf(stderr,
"Expected \"--num-ranks\" argument for iolang workload\n");
usage();
return 1;
else{
du_params.num_net_traces = n;
if(du_params.file_name[0] == '\0' ){
fprintf(stderr, "Expected \"--r-trace-dir\" argument for dumpi workload\n");
usage();
return 1;
else
wparams = (char*)&du_params;
else { else {
fprintf(stderr, "Invalid type argument\n"); fprintf(stderr, "Invalid type argument\n");
usage(); usage();
...@@ -247,7 +276,8 @@ int main(int argc, char *argv[]) ...@@ -247,7 +276,8 @@ int main(int argc, char *argv[])
case CODES_WK_BCAST: case CODES_WK_BCAST:
num_bcasts++; num_bcasts++;
bcast_size += op.u.collective.num_bytes; bcast_size += op.u.collective.num_bytes;
case CODES_WK_ALLGATHER: break;
num_allgathers++; num_allgathers++;
allgather_size += op.u.collective.num_bytes; allgather_size += op.u.collective.num_bytes;
break; break;
...@@ -285,6 +285,22 @@ void codes_workload_print_op(FILE *f, struct codes_workload_op *op, int rank){ ...@@ -285,6 +285,22 @@ void codes_workload_print_op(FILE *f, struct codes_workload_op *op, int rank){
fprintf(f, "op: rank:? type:collective " fprintf(f, "op: rank:? type:collective "
"bytes:%d\n", op->u.collective.num_bytes); "bytes:%d\n", op->u.collective.num_bytes);
break; break;
case CODES_WK_WAITALL:
fprintf(f, "op: rank:? type:waitall "
"num reqs: :%d\n", op->u.waits.count);
break;
case CODES_WK_WAIT:
fprintf(f, "op: rank:? type:wait "
"num reqs: :%d\n", op->u.wait.req_id);
break;
case CODES_WK_WAITSOME:
fprintf(f, "op: rank:? type:waitsome "
break;
case CODES_WK_WAITANY:
fprintf(f, "op: rank:? type:waitany "
break;
case CODES_WK_IGNORE: case CODES_WK_IGNORE:
break; break;
default: default:
Markdown is supported
0% or .
Please register or to comment
