Commit 9950b0f8 authored by Caitlin Ross's avatar Caitlin Ross
Browse files
updating ROSS inst support for fattree
parent 796e8dfa
...@@ -296,6 +296,42 @@ struct switch_state ...@@ -296,6 +296,42 @@ struct switch_state
int *lft; int *lft;
/* ROSS Instrumentation Support */
struct fattree_sample
tw_lpid lpid;
void fattree_event_collect(fattree_message *m, tw_lp *lp, char *buffer, int *collect_flag);
void fattree_model_stat_collect(ft_terminal_state *s, tw_lp *lp, char *buffer);
static void ross_fattree_sample_fn(ft_terminal_state * s, tw_bf * bf, tw_lp * lp, struct fattree_sample *sample);
static void ross_fattree_sample_rc_fn(ft_terminal_state * s, tw_bf * bf, tw_lp * lp, struct fattree_sample *sample);
static void ross_fattree_ssample_fn(switch_state * s, tw_bf * bf, tw_lp * lp, struct fattree_sample *sample);
static void ross_fattree_ssample_rc_fn(switch_state * s, tw_bf * bf, tw_lp * lp, struct fattree_sample *sample);
st_model_types fattree_model_types[] = {
{(rbev_trace_f) fattree_event_collect,
sizeof(int),
(ev_trace_f) fattree_event_collect,
sizeof(int),
(model_stat_f) fattree_model_stat_collect,
0, // update when changing fattree_model_stat_collect
(sample_event_f) ross_fattree_sample_fn,
(sample_revent_f) ross_fattree_sample_rc_fn,
sizeof(struct fattree_sample) } ,
sizeof(int),
sizeof(int),
(sample_event_f) ross_fattree_ssample_fn,
(sample_revent_f) ross_fattree_ssample_rc_fn,
{NULL, 0, NULL, 0, NULL, 0, NULL, NULL, 0}
/* End of ROSS model stats collection */
static tw_stime fattree_total_time = 0; static tw_stime fattree_total_time = 0;
static tw_stime fattree_max_latency = 0; static tw_stime fattree_max_latency = 0;
//static tw_stime max_collective = 0; //static tw_stime max_collective = 0;
...@@ -2967,7 +3003,23 @@ tw_lptype fattree_lps[] = ...@@ -2967,7 +3003,23 @@ tw_lptype fattree_lps[] =
{NULL, NULL, NULL, NULL, NULL, NULL, NULL, 0}, {NULL, NULL, NULL, NULL, NULL, NULL, NULL, 0},
/* For ROSS event tracing */
/* returns the fattree lp type for lp registration */
static const tw_lptype* fattree_get_cn_lp_type(void)
return(&fattree_lps[0]);
/*static const tw_lptype* fattree_get_switch_lp_type(void)
return(&fattree_lps[1]);
static void fattree_register(tw_lptype *base_type) {
lp_type_register(LP_CONFIG_NM, base_type);
lp_type_register("fattree_switch", &fattree_lps[1]);
/* For ROSS Instrumentation */
void fattree_event_collect(fattree_message *m, tw_lp *lp, char *buffer, int *collect_flag) void fattree_event_collect(fattree_message *m, tw_lp *lp, char *buffer, int *collect_flag)
(void)lp; (void)lp;
...@@ -2977,46 +3029,67 @@ void fattree_event_collect(fattree_message *m, tw_lp *lp, char *buffer, int *col ...@@ -2977,46 +3029,67 @@ void fattree_event_collect(fattree_message *m, tw_lp *lp, char *buffer, int *col
memcpy(buffer, &type, sizeof(type)); memcpy(buffer, &type, sizeof(type));
// TODO will need to separate fattree_method into one for terminal and one for switch void fattree_model_stat_collect(ft_terminal_state *s, tw_lp *lp, char *buffer)
// in order to use the ROSS model stats collection {
st_model_types fattree_model_types[] = { (void)lp;
{(rbev_trace_f) fattree_event_collect, (void)s;
sizeof(int), (void)buffer;
sizeof(int),
NULL,
0},
{NULL, 0, NULL, 0, NULL, 0}
static const st_model_types *fattree_get_model_stat_types(void) return;
return(&fattree_model_types[0]); (void)lp;
(void)bf;
(void)s;
(void)sample;
return;
static void fattree_register_model_stats(st_model_types *base_type) static void ross_fattree_sample_rc_fn(ft_terminal_state * s, tw_bf * bf, tw_lp * lp, struct fattree_sample *sample)
st_model_type_register(LP_CONFIG_NM, base_type); (void)lp;
st_model_type_register("fattree_switch", &fattree_model_types[0]); (void)bf;
//trace_type_register("fattree_switch", base_type); (void)s;
(void)sample;
return;
/*** END of ROSS event tracing additions */
/* returns the fattree lp type for lp registration */ static void ross_fattree_ssample_fn(switch_state * s, tw_bf * bf, tw_lp * lp, struct fattree_sample *sample)
return(&fattree_lps[0]); (void)lp;
(void)bf;
(void)s;
(void)sample;
return;
return(&fattree_lps[1]); (void)lp;
} */ (void)bf;
(void)s;
(void)sample;
static void fattree_register(tw_lptype *base_type) { return;
st_model_type_register("fattree_switch", &fattree_model_types[1]);
struct model_net_method fattree_method = struct model_net_method fattree_method =
.mn_configure = fattree_configure, .mn_configure = fattree_configure,
Markdown is supported
0% or .
Please register or to comment
