Commit 96306239 authored by Misbah Mubarak's avatar Misbah Mubarak
Browse files
Merge branch 'model-net-sched-selection-fix' into 'master'
Model net scheduler selection fix
See merge request codes/codes!48
parents b186dfb4 00215a99
......@@ -252,6 +252,24 @@ static void base_read_config(const char * anno, model_net_base_params *p){
&packet_size_l);
packet_size = packet_size_l;
if (ret > 0){
int i;
for (i = 0; i < MAX_SCHEDS; i++){
if (strcmp(sched_names[i], sched) == 0){
p->sched_params.type = i;
break;
if (i == MAX_SCHEDS){
tw_error(TW_LOC,"Unknown value for PARAMS:modelnet-scheduler : "
"%s", sched);
else{
// default: FCFS
p->sched_params.type = MN_SCHED_FCFS;
p->num_queues = 1;
ret = configuration_get_value_int(&config, "PARAMS", "num_injection_queues", anno,
&p->num_queues);
......@@ -276,24 +294,6 @@ static void base_read_config(const char * anno, model_net_base_params *p){
"setting to %d\n", p->node_copy_queues);
if (ret > 0){
int i;
break;
"%s", sched);
else{
// default: FCFS
// get scheduler-specific parameters
if (p->sched_params.type == MN_SCHED_PRIO){
// prio scheduler uses default parameters
......@@ -307,7 +307,7 @@ static void base_read_config(const char * anno, model_net_base_params *p){
ret = configuration_get_value(&config, "PARAMS",
"prio-sched-sub-sched", anno, sched, MAX_NAME_LENGTH);
if (ret == 0)
if (ret <= 0)
*sub_stype = MN_SCHED_FCFS;
else{
int i;
Markdown is supported
0% or .
Please register or to comment
