Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
9497a9c7
Commit
9497a9c7
authored
Sep 26, 2013
by
Philip Carns
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
add queueing and fix time calculation
parent
35cc7c1f
Changes
2
Hide whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
21 additions
and
5 deletions
+21
-5
tests/workload/codes-workload-test-cn-lp.c
+3
-1
tests/workload/codes-workload-test-svr-lp.c
+18
-4
No files found.
View file @
9497a9c7
@@ -34,6 +34,7 @@ struct client_state
int
wkld_id
/* identifier returned by workload load fn */
int
wkld_id
int
target_barrier_count
/* state information for handling barriers */
int
int
current_barrier_count
int
tw_stime
completion_time
struct
client_msg
struct
client_msg
@@ -178,7 +179,7 @@ static void client_finalize(
/* write out some statistics (the current time of each cn as it
* shuts down)
* shuts down)
sprintf
buffer
"cn_lp:%ld
\t
finalize_time:%f
\n
long
lp
gid
tw_now
lp
sprintf
buffer
"cn_lp:%ld
\t
completion_time:%f
\n
long
lp
gid
ns
completion_time
ret
lp_io_write
lp
gid
"compute_nodes"
strlen
buffer
1
buffer
ret
lp_io_write
lp
gid
"compute_nodes"
strlen
buffer
1
buffer
assert
ret
0
assert
ret
0
@@ -302,6 +303,7 @@ static void handle_client_op_loop_event(
switch
m
op_rc
op_type
switch
m
op_rc
op_type
case
CODES_WK_END
case
CODES_WK_END
ns
completion_time
tw_now
lp
printf
"Client rank %d completed workload.
\n
ns
my_rank
printf
\n
ns
my_rank
/* stop issuing events; we are done */
return
return
View file @
9497a9c7
@@ -26,6 +26,7 @@ enum svr_event_type
struct
svr_state
struct
svr_state
tw_stime
next_idle
struct
svr_msg
struct
svr_msg
@@ -33,6 +34,7 @@ struct svr_msg
enum
svr_event_type
event_type
enum
svr_event_type
event_type
struct
codes_workload_op
op
struct
codes_workload_op
op
tw_lpid
src
/* source of this request or ack */
tw_lpid
src
tw_stime
next_idle_rc
static
void
svr_init
static
void
svr_init
@@ -81,6 +83,8 @@ static void svr_init(
memset
ns
0
sizeof
ns
memset
ns
0
sizeof
ns
ns
next_idle
tw_now
lp
return
return
@@ -131,7 +135,7 @@ static void svr_finalize(
/* write out some statistics (the current time of each server as it
* shuts down)
* shuts down)
sprintf
buffer
"svr_lp:%ld
\t
finalize_time:%f
\n
long
lp
gid
tw_now
lp
sprintf
buffer
"svr_lp:%ld
\t
completion_time:%f
\n
long
lp
gid
ns
next_idle
ret
lp_io_write
lp
gid
"servers"
strlen
buffer
1
buffer
ret
lp_io_write
lp
gid
"servers"
strlen
buffer
1
buffer
assert
ret
0
assert
ret
0
@@ -169,13 +173,22 @@ static void handle_svr_op_event(
svr_msg
m
svr_msg
m
tw_lp
lp
tw_lp
lp
printf
"handle_svr_op_event at lp %ld, type %d
\n
lp
gid
m
op
op_type
m
next_idle_rc
ns
next_idle
/* NOTE: this isn't a real server simulator, but we do want time to
* elapse so that we can do correctness/regression testing. We pick the
* elapse so that we can do correctness/regression testing. For testing
* service time by using the op type as the elapsed time.
* purposes we use the value of the op_type field as the amount of
* elapsed time for the operation to consume.
if
ns
next_idle
tw_now
lp
ns
next_idle
m
op
op_type
else
ns
next_idle
tw_now
lp
m
op
op_type
/* send event back to cn to let it know the operation is done */
cn_op_complete
lp
m
op
op_type
m
src
cn_op_complete
lp
ns
next_idle
tw_now
lp
m
src
return
return
@@ -186,6 +199,7 @@ static void handle_svr_op_event_rc(
svr_msg
m
svr_msg
m
tw_lp
lp
tw_lp
lp
ns
next_idle
m
next_idle_rc
cn_op_complete_rc
lp
cn_op_complete_rc
lp
return
return
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
