Commit 93971889 authored by Caitlin Ross's avatar Caitlin Ross
Browse files
just adding in some comments
parent e73e7b37
...@@ -2207,6 +2207,10 @@ void nw_lp_event_collect(nw_message *m, tw_lp *lp, char *buffer, int *collect_fl ...@@ -2207,6 +2207,10 @@ void nw_lp_event_collect(nw_message *m, tw_lp *lp, char *buffer, int *collect_fl
memcpy(buffer, &type, sizeof(type)); memcpy(buffer, &type, sizeof(type));
/* can add in any model level data to be collected along with simulation engine data
* in the ROSS instrumentation. Will need to update the last field in
* nw_lp_model_types[0] for the size of the data to save in each function call
void nw_lp_model_stat_collect(nw_state *s, tw_lp *lp, char *buffer) void nw_lp_model_stat_collect(nw_state *s, tw_lp *lp, char *buffer)
return; return;
...@@ -130,6 +130,10 @@ void ft_svr_event_collect(svr_msg *m, tw_lp *lp, char *buffer, int *collect_flag ...@@ -130,6 +130,10 @@ void ft_svr_event_collect(svr_msg *m, tw_lp *lp, char *buffer, int *collect_flag
* ft_svr_model_types[0] for the size of the data to save in each function call
void ft_svr_model_stat_collect(svr_state *s, tw_lp *lp, char *buffer) void ft_svr_model_stat_collect(svr_state *s, tw_lp *lp, char *buffer)
return; return;
...@@ -116,6 +116,10 @@ void svr_event_collect(svr_msg *m, tw_lp *lp, char *buffer, int *collect_flag) ...@@ -116,6 +116,10 @@ void svr_event_collect(svr_msg *m, tw_lp *lp, char *buffer, int *collect_flag)
* svr_model_types[0] for the size of the data to save in each function call
void svr_model_stat_collect(svr_state *s, tw_lp *lp, char *buffer) void svr_model_stat_collect(svr_state *s, tw_lp *lp, char *buffer)
return; return;
Markdown is supported
0% or .
Please register or to comment
