Commit 9257a4ab authored by Noah Wolfe's avatar Noah Wolfe
Browse files
Merge branch 'master' into fattree-merge
parents 623880bc 95e4e97c
...@@ -55,6 +55,8 @@ struct terminal_message ...@@ -55,6 +55,8 @@ struct terminal_message
unsigned int intm_lp_id; unsigned int intm_lp_id;
short new_vc; short new_vc;
short saved_vc; short saved_vc;
int saved_src_dest;
/* last hop of the message, can be a terminal, local router or global router */ /* last hop of the message, can be a terminal, local router or global router */
int last_hop; int last_hop;
/* For routing */ /* For routing */
...@@ -53,6 +53,12 @@ working from the CODES master branches, use the ROSS master branch. ...@@ -53,6 +53,12 @@ working from the CODES master branches, use the ROSS master branch.
breaks libdumpi's function wrappers through const'ifying the MPI breaks libdumpi's function wrappers through const'ifying the MPI
interface). interface).
For building DUMPI with mpich3 versions and higher, use the following build
options:
CFLAGS="-DMPICH_SUPPRESS_PROTOTYPES=1 -DHAVE_PRAGMA_HP_SEC_DEF=1"
./configure --enable-libdumpi --prefix=$INSTALL_PATH
Use the --with-darshan argument to configure to enable the optional Use the --with-darshan argument to configure to enable the optional
Darshan I/O workload generator Darshan I/O workload generator
(http://www.mcs.anl.gov/research/projects/darshan/). In order to use (http://www.mcs.anl.gov/research/projects/darshan/). In order to use
...@@ -92,7 +92,7 @@ struct terminal_message_list { ...@@ -92,7 +92,7 @@ struct terminal_message_list {
terminal_message_list *prev; terminal_message_list *prev;
void init_terminal_message_list(terminal_message_list *this, static void init_terminal_message_list(terminal_message_list *this,
terminal_message *inmsg) { terminal_message *inmsg) {
this->msg = *inmsg; this->msg = *inmsg;
this->event_data = NULL; this->event_data = NULL;
...@@ -100,7 +100,7 @@ void init_terminal_message_list(terminal_message_list *this, ...@@ -100,7 +100,7 @@ void init_terminal_message_list(terminal_message_list *this,
this->prev = NULL; this->prev = NULL;
void delete_terminal_message_list(terminal_message_list *this) { static void delete_terminal_message_list(terminal_message_list *this) {
if(this->event_data != NULL) free(this->event_data); if(this->event_data != NULL) free(this->event_data);
free(this); free(this);
...@@ -640,7 +640,7 @@ static void dragonfly_report_stats() ...@@ -640,7 +640,7 @@ static void dragonfly_report_stats()
return; return;
void dragonfly_collective_init(terminal_state * s, static void dragonfly_collective_init(terminal_state * s,
tw_lp * lp) tw_lp * lp)
// TODO: be annotation-aware // TODO: be annotation-aware
...@@ -699,7 +699,7 @@ void dragonfly_collective_init(terminal_state * s, ...@@ -699,7 +699,7 @@ void dragonfly_collective_init(terminal_state * s,
/* initialize a dragonfly compute node terminal */ /* initialize a dragonfly compute node terminal */
void static void
terminal_init( terminal_state * s, terminal_init( terminal_state * s,
tw_lp * lp ) tw_lp * lp )
...@@ -778,7 +778,7 @@ terminal_init( terminal_state * s, ...@@ -778,7 +778,7 @@ terminal_init( terminal_state * s,
/* sets up the router virtual channels, global channels, /* sets up the router virtual channels, global channels,
* local channels, compute node channels */ * local channels, compute node channels */
void router_setup(router_state * r, tw_lp * lp) static void router_setup(router_state * r, tw_lp * lp)
uint32_t h1 = 0, h2 = 0; uint32_t h1 = 0, h2 = 0;
bj_hashlittle2(LP_METHOD_NM_ROUT, strlen(LP_METHOD_NM_ROUT), &h1, &h2); bj_hashlittle2(LP_METHOD_NM_ROUT, strlen(LP_METHOD_NM_ROUT), &h1, &h2);
...@@ -1034,7 +1034,7 @@ tw_lpid getRouterFromGroupID(int dest_gid, ...@@ -1034,7 +1034,7 @@ tw_lpid getRouterFromGroupID(int dest_gid,
/*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/ /*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/
void router_credit_send(router_state * s, terminal_message * msg, static void router_credit_send(router_state * s, terminal_message * msg,
tw_lp * lp, int sq) { tw_lp * lp, int sq) {
tw_event * buf_e; tw_event * buf_e;
tw_stime ts; tw_stime ts;
...@@ -1083,7 +1083,7 @@ void router_credit_send(router_state * s, terminal_message * msg, ...@@ -1083,7 +1083,7 @@ void router_credit_send(router_state * s, terminal_message * msg,
return; return;
void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) static void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
s->packet_gen--; s->packet_gen--;
packet_gen--; packet_gen--;
...@@ -1119,7 +1119,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1119,7 +1119,7 @@ void packet_generate_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
/* generates packet at the current dragonfly compute node */ /* generates packet at the current dragonfly compute node */
void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg, static void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
tw_lp * lp) { tw_lp * lp) {
packet_gen++; packet_gen++;
s->packet_gen++; s->packet_gen++;
...@@ -1215,7 +1215,7 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1215,7 +1215,7 @@ void packet_generate(terminal_state * s, tw_bf * bf, terminal_message * msg,
return; return;
void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, static void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(bf->c1) { if(bf->c1) {
...@@ -1246,7 +1246,7 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1246,7 +1246,7 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(bf->c5) if(bf->c5)
codes_local_latency_reverse(lp); tw_rand_reverse_unif(lp->rng);
s->issueIdle = 1; s->issueIdle = 1;
if(bf->c6) if(bf->c6)
...@@ -1258,7 +1258,7 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1258,7 +1258,7 @@ void packet_send_rc(terminal_state * s, tw_bf * bf, terminal_message * msg,
return; return;
/* sends the packet from the current dragonfly compute node to the attached router */ /* sends the packet from the current dragonfly compute node to the attached router */
void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, static void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
...@@ -1294,6 +1294,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1294,6 +1294,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
s->terminal_available_time = maxd(s->terminal_available_time, tw_now(lp)); s->terminal_available_time = maxd(s->terminal_available_time, tw_now(lp));
s->terminal_available_time += ts; s->terminal_available_time += ts;
ts = s->terminal_available_time - tw_now(lp);
//TODO: be annotation-aware //TODO: be annotation-aware
codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL, codes_mapping_get_lp_info(lp->gid, lp_group_name, &mapping_grp_id, NULL,
&mapping_type_id, NULL, &mapping_rep_id, &mapping_offset); &mapping_type_id, NULL, &mapping_rep_id, &mapping_offset);
...@@ -1301,7 +1302,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1301,7 +1302,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
s->router_id, 0, &router_id); s->router_id, 0, &router_id);
// we are sending an event to the router, so no method_event here // we are sending an event to the router, so no method_event here
void * remote_event; void * remote_event;
e = model_net_method_event_new(router_id, s->terminal_available_time - tw_now(lp), lp, e = model_net_method_event_new(router_id, ts, lp,
DRAGONFLY_ROUTER, (void**)&m, &remote_event); DRAGONFLY_ROUTER, (void**)&m, &remote_event);
memcpy(m, &cur_entry->msg, sizeof(terminal_message)); memcpy(m, &cur_entry->msg, sizeof(terminal_message));
if (m->remote_event_size_bytes){ if (m->remote_event_size_bytes){
...@@ -1322,8 +1323,8 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1322,8 +1323,8 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(cur_entry->msg.chunk_id == num_chunks - 1 && if(cur_entry->msg.chunk_id == num_chunks - 1 &&
(cur_entry->msg.local_event_size_bytes > 0)) { (cur_entry->msg.local_event_size_bytes > 0)) {
bf->c2 = 1; bf->c2 = 1;
ts = codes_local_latency(lp); tw_stime local_ts = codes_local_latency(lp);
tw_event *e_new = tw_event_new(cur_entry->msg.sender_lp, ts, lp); tw_event *e_new = tw_event_new(cur_entry->msg.sender_lp, local_ts, lp);
void * m_new = tw_event_data(e_new); void * m_new = tw_event_data(e_new);
void *local_event = (char*)cur_entry->event_data + void *local_event = (char*)cur_entry->event_data +
cur_entry->msg.remote_event_size_bytes; cur_entry->msg.remote_event_size_bytes;
...@@ -1343,7 +1344,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1343,7 +1344,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
s->vc_occupancy[0] + s->params->chunk_size <= s->params->cn_vc_size) { s->vc_occupancy[0] + s->params->chunk_size <= s->params->cn_vc_size) {
bf->c3 = 1; bf->c3 = 1;
terminal_message *m_new; terminal_message *m_new;
ts = g_tw_lookahead + s->params->cn_delay + tw_rand_unif(lp->rng); ts += tw_rand_unif(lp->rng);
e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY, e = model_net_method_event_new(lp->gid, ts, lp, DRAGONFLY,
(void**)&m_new, NULL); (void**)&m_new, NULL);
m_new->type = T_SEND; m_new->type = T_SEND;
...@@ -1357,7 +1358,8 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1357,7 +1358,8 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
if(s->issueIdle) { if(s->issueIdle) {
bf->c5 = 1; bf->c5 = 1;
s->issueIdle = 0; s->issueIdle = 0;
model_net_method_idle_event(codes_local_latency(lp), 0, lp); ts += tw_rand_unif(lp->rng);
model_net_method_idle_event(ts, 0, lp);
if(s->last_buf_full > 0.0) if(s->last_buf_full > 0.0)
...@@ -1374,7 +1376,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1374,7 +1376,7 @@ void packet_send(terminal_state * s, tw_bf * bf, terminal_message * msg,
return; return;
void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp) static void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw_lp * lp)
if(bf->c31) if(bf->c31)
...@@ -1412,7 +1414,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1412,7 +1414,6 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
stat = model_net_find_stats(msg->category, s->dragonfly_stats_array); stat = model_net_find_stats(msg->category, s->dragonfly_stats_array);
stat->recv_time = msg->saved_rcv_time; stat->recv_time = msg->saved_rcv_time;
s->data_size_sample -= msg->total_size;
if(bf->c1) if(bf->c1)
stat->recv_count--; stat->recv_count--;
...@@ -1426,11 +1427,13 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1426,11 +1427,13 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
if(bf->c7) if(bf->c7)
//assert(!hash_link); //assert(!hash_link);
if(bf->c8)
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
N_finished_msgs--; N_finished_msgs--;
s->finished_msgs--; s->finished_msgs--;
total_msg_sz -= msg->total_size; total_msg_sz -= msg->total_size;
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
struct dfly_qhash_entry * d_entry_pop = rc_stack_pop(s->st); struct dfly_qhash_entry * d_entry_pop = rc_stack_pop(s->st);
qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link));
...@@ -1454,7 +1457,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw ...@@ -1454,7 +1457,7 @@ void packet_arrive_rc(terminal_state * s, tw_bf * bf, terminal_message * msg, tw
return; return;
void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, tw_bf * bf, char * event_data, int remote_event_size) static void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, tw_bf * bf, char * event_data, int remote_event_size)
void * tmp_ptr = model_net_method_get_edata(DRAGONFLY, msg); void * tmp_ptr = model_net_method_get_edata(DRAGONFLY, msg);
//tw_stime ts = g_tw_lookahead + bytes_to_ns(msg->remote_event_size_bytes, (1/s->params->cn_bandwidth)); //tw_stime ts = g_tw_lookahead + bytes_to_ns(msg->remote_event_size_bytes, (1/s->params->cn_bandwidth));
...@@ -1482,7 +1485,7 @@ void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, t ...@@ -1482,7 +1485,7 @@ void send_remote_event(terminal_state * s, terminal_message * msg, tw_lp * lp, t
return; return;
/* packet arrives at the destination terminal */ /* packet arrives at the destination terminal */
void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, static void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
// NIC aggregation - should this be a separate function? // NIC aggregation - should this be a separate function?
...@@ -1547,7 +1550,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1547,7 +1550,6 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
/* Finished chunks per sample */ /* Finished chunks per sample */
s->fin_chunks_sample++; s->fin_chunks_sample++;
s->data_size_sample += msg->total_size;
/* WE do not allow self messages through dragonfly */ /* WE do not allow self messages through dragonfly */
assert(lp->gid != msg->src_terminal_id); assert(lp->gid != msg->src_terminal_id);
...@@ -1664,9 +1666,12 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1664,9 +1666,12 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
total_msg_sz += msg->total_size; total_msg_sz += msg->total_size;
s->total_msg_size += msg->total_size; s->total_msg_size += msg->total_size;
s->finished_msgs++; s->finished_msgs++;
if(tmp->remote_event_data && tmp->remote_event_size > 0); if(tmp->remote_event_data && tmp->remote_event_size > 0) {
bf->c8 = 1;
send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size); send_remote_event(s, msg, lp, bf, tmp->remote_event_data, tmp->remote_event_size);
/* Remove the hash entry */ /* Remove the hash entry */
qhash_del(hash_link); qhash_del(hash_link);
...@@ -1677,7 +1682,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg, ...@@ -1677,7 +1682,7 @@ void packet_arrive(terminal_state * s, tw_bf * bf, terminal_message * msg,
/* collective operation for the torus network */ /* collective operation for the torus network */
void dragonfly_collective(char const * category, int message_size, int remote_event_size, const void* remote_event, tw_lp* sender) static void dragonfly_collective(char const * category, int message_size, int remote_event_size, const void* remote_event, tw_lp* sender)
tw_event * e_new; tw_event * e_new;
tw_stime xfer_to_nic_time; tw_stime xfer_to_nic_time;
...@@ -1713,7 +1718,7 @@ void dragonfly_collective(char const * category, int message_size, int remote_ev ...@@ -1713,7 +1718,7 @@ void dragonfly_collective(char const * category, int message_size, int remote_ev
/* reverse for collective operation of the dragonfly network */ /* reverse for collective operation of the dragonfly network */
void dragonfly_collective_rc(int message_size, tw_lp* sender) static void dragonfly_collective_rc(int message_size, tw_lp* sender)
(void)message_size; (void)message_size;
codes_local_latency_reverse(sender); codes_local_latency_reverse(sender);
...@@ -1943,7 +1948,7 @@ static void node_collective_fan_out(terminal_state * s, ...@@ -1943,7 +1948,7 @@ static void node_collective_fan_out(terminal_state * s,
void dragonfly_rsample_init(router_state * s, static void dragonfly_rsample_init(router_state * s,
(void)lp; (void)lp;
...@@ -1960,7 +1965,7 @@ void dragonfly_rsample_init(router_state * s, ...@@ -1960,7 +1965,7 @@ void dragonfly_rsample_init(router_state * s,
s->rsamples[i].link_traffic_sample = malloc(sizeof(int64_t) * p->radix); s->rsamples[i].link_traffic_sample = malloc(sizeof(int64_t) * p->radix);
void dragonfly_rsample_rc_fn(router_state * s, static void dragonfly_rsample_rc_fn(router_state * s,
tw_bf * bf, tw_bf * bf,
terminal_message * msg, terminal_message * msg,
...@@ -1991,7 +1996,7 @@ void dragonfly_rsample_rc_fn(router_state * s, ...@@ -1991,7 +1996,7 @@ void dragonfly_rsample_rc_fn(router_state * s,
s->rev_events = stat.rev_events; s->rev_events = stat.rev_events;
void dragonfly_rsample_fn(router_state * s, static void dragonfly_rsample_fn(router_state * s,
...@@ -2038,13 +2043,13 @@ void dragonfly_rsample_fn(router_state * s, ...@@ -2038,13 +2043,13 @@ void dragonfly_rsample_fn(router_state * s,
void dragonfly_rsample_fin(router_state * s, static void dragonfly_rsample_fin(router_state * s,
(void)lp; (void)lp;
const dragonfly_param * p = s->params; const dragonfly_param * p = s->params;
if(!g_tw_mynode) if(s->router_id == 0)
/* write metadata file */ /* write metadata file */
...@@ -2083,7 +2088,7 @@ void dragonfly_rsample_fin(router_state * s, ...@@ -2083,7 +2088,7 @@ void dragonfly_rsample_fin(router_state * s,
sample_rtr_bytes_written += (s->op_arr_size * size_sample); sample_rtr_bytes_written += (s->op_arr_size * size_sample);
fclose(fp); fclose(fp);
void dragonfly_sample_init(terminal_state * s, static void dragonfly_sample_init(terminal_state * s,
(void)lp; (void)lp;
...@@ -2106,7 +2111,7 @@ void dragonfly_sample_init(terminal_state * s, ...@@ -2106,7 +2111,7 @@ void dragonfly_sample_init(terminal_state * s,
lp_io_write(lp->gid, "dragonfly-sampling-stats", written, buf); lp_io_write(lp->gid, "dragonfly-sampling-stats", written, buf);
void dragonfly_sample_rc_fn(terminal_state * s, static void dragonfly_sample_rc_fn(terminal_state * s,
...@@ -2137,7 +2142,7 @@ void dragonfly_sample_rc_fn(terminal_state * s, ...@@ -2137,7 +2142,7 @@ void dragonfly_sample_rc_fn(terminal_state * s,
stat.rev_events = 0; stat.rev_events = 0;
void dragonfly_sample_fn(terminal_state * s, static void dragonfly_sample_fn(terminal_state * s,
...@@ -2196,7 +2201,7 @@ void dragonfly_sample_fn(terminal_state * s, ...@@ -2196,7 +2201,7 @@ void dragonfly_sample_fn(terminal_state * s,
s->busy_time_sample = 0; s->busy_time_sample = 0;
void dragonfly_sample_fin(terminal_state * s, static void dragonfly_sample_fin(terminal_state * s,
(void)lp; (void)lp;
...@@ -2235,7 +2240,7 @@ void dragonfly_sample_fin(terminal_state * s, ...@@ -2235,7 +2240,7 @@ void dragonfly_sample_fin(terminal_state * s,
sample_bytes_written += (s->op_arr_size * sizeof(struct dfly_cn_sample)); sample_bytes_written += (s->op_arr_size * sizeof(struct dfly_cn_sample));
void terminal_buf_update_rc(terminal_state * s, static void terminal_buf_update_rc(terminal_state * s,
...@@ -2249,7 +2254,7 @@ void terminal_buf_update_rc(terminal_state * s, ...@@ -2249,7 +2254,7 @@ void terminal_buf_update_rc(terminal_state * s,
return; return;
/* update the compute node-router channel buffer */ /* update the compute node-router channel buffer */
void static void
terminal_buf_update(terminal_state * s, terminal_buf_update(terminal_state * s,
...@@ -2276,7 +2281,7 @@ terminal_buf_update(terminal_state * s, ...@@ -2276,7 +2281,7 @@ terminal_buf_update(terminal_state * s,
return; return;
void static void
terminal_event( terminal_state * s, terminal_event( terminal_state * s,
...@@ -2323,13 +2328,23 @@ terminal_event( terminal_state * s, ...@@ -2323,13 +2328,23 @@ terminal_event( terminal_state * s,
void static void
dragonfly_terminal_final( terminal_state * s, dragonfly_terminal_final( terminal_state * s,
model_net_print_stats(lp->gid, s->dragonfly_stats_array); model_net_print_stats(lp->gid, s->dragonfly_stats_array);
//rc_stack_gc(lp, s->st); if(s->terminal_id == 0)
char meta_fname[64];
sprintf(meta_fname, "dragonfly-msg-stats.meta");
FILE * fp = fopen(meta_fname, "w");
fprintf(fp, "# Format <LP id> <Terminal ID> <Total Data Size> <Avg packet latency> <# Flits/Packets finished> <Avg hops> <Busy Time>");
fclose(fp);
int written = 0; int written = 0;
if(!s->terminal_id) if(!s->terminal_id)
...@@ -2357,7 +2372,7 @@ dragonfly_terminal_final( terminal_state * s, ...@@ -2357,7 +2372,7 @@ dragonfly_terminal_final( terminal_state * s,
free(s->children); free(s->children);
void dragonfly_router_final(router_state * s, static void dragonfly_router_final(router_state * s,
//rc_stack_gc(lp, s->st); //rc_stack_gc(lp, s->st);
...@@ -2379,11 +2394,17 @@ void dragonfly_router_final(router_state * s, ...@@ -2379,11 +2394,17 @@ void dragonfly_router_final(router_state * s,
const dragonfly_param *p = s->params; const dragonfly_param *p = s->params;
if(!s->router_id) if(s->router_id == 0)
written = sprintf(s->output_buf, "# Format <LP ID> <Group ID> <Router ID> <Busy time per router port(s)>"); /* write metadata file */
written += sprintf(s->output_buf + written, "# Router ports in the order: %d local channels, %d global channels", char meta_fname[64];
fprintf(fp, "# Format <LP ID> <Group ID> <Router ID> <Busy time per router port(s)>");
fprintf(fp, "# Router ports in the order: %d local channels, %d global channels",
p->num_routers, p->num_global_channels); p->num_routers, p->num_global_channels);
fclose(fp);
