Commit 8dee7714 authored by Matthieu Dorier's avatar Matthieu Dorier
changed topology function names for Dragonfly-Custom and added comments
parent 27343228
...@@ -3224,60 +3224,90 @@ struct model_net_method dragonfly_custom_router_method = ...@@ -3224,60 +3224,90 @@ struct model_net_method dragonfly_custom_router_method =
#ifdef ENABLE_CORTEX #ifdef ENABLE_CORTEX
static double dragonfly_get_router_link_bandwidth(void* topo, router_id_t r1, router_id_t r2) { static double dragonfly_custom_get_router_link_bandwidth(void* topo, router_id_t r1, router_id_t r2) {
// TODO // TODO
// Given two router ids r1 and r2, this function should return the bandwidth (double)
// of the link between the two routers, or 0 of such a link does not exist in the topology.
// The function should return -1 if one of the router id is invalid.
return -1.0; return -1.0;
static double dragonfly_get_compute_node_bandwidth(void* topo, cn_id_t node) { static double dragonfly_custom_get_compute_node_bandwidth(void* topo, cn_id_t node) {
// TODO // TODO
// Given the id of a compute node, this function should return the bandwidth of the
// link connecting this compute node to its router.
// The function should return -1 if the compute node id is invalid.
static int dragonfly_get_router_neighbor_count(void* topo, router_id_t r) { static int dragonfly_custom_get_router_neighbor_count(void* topo, router_id_t r) {
// TODO // TODO
return 0; // Given the id of a router, this function should return the number of routers
// (not compute nodes) connected to it. It should return -1 if the router id
// is not valid.
return -1;
static void dragonfly_get_router_neighbor_list(void* topo, router_id_t r, router_id_t* neighbors) { static void dragonfly_custom_get_router_neighbor_list(void* topo, router_id_t r, router_id_t* neighbors) {
// TODO // TODO
// Given a router id r, this function fills the "neighbors" array with the ids of routers
// directly connected to r. It is assumed that enough memory has been allocated to "neighbors"
// (using get_router_neighbor_count to know the required size).
static int dragonfly_get_router_location(void* topo, router_id_t r, int32_t* location, int size) { static int dragonfly_custom_get_router_location(void* topo, router_id_t r, int32_t* location, int size) {
// TODO // TODO
return 0; // Given a router id r, this function should fill the "location" array (of maximum size "size")
// with information providing the location of the router in the topology. In a Dragonfly network,
// for instance, this can be the array [ group_id, router_id ] where group_id is the id of the
// group in which the router is, and router_id is the id of the router inside this group (as opposed
// to "r" which is its global id). For a torus network, this would be the dimensions.
// If the "size" is sufficient to hold the information, the function should return the size
// effectively used (e.g. 2 in the above example). If however the function did not manage to use
// the provided buffer, it should return -1.
return -1;
static int dragonfly_get_compute_node_location(void* topo, cn_id_t node, int32_t* location, int size) { static int dragonfly_custom_get_compute_node_location(void* topo, cn_id_t node, int32_t* location, int size) {
// TODO // TODO
return 0; // This function does the same as dragonfly_custom_get_router_location but for a compute node instead
// of a router. E.g., for a dragonfly network, the location could be expressed as the array
// [ group_id, router_id, terminal_id ]
return -1;
static router_id_t dragonfly_get_router_from_compute_node(void* topo, cn_id_t node) { static router_id_t dragonfly_custom_get_router_from_compute_node(void* topo, cn_id_t node) {
// TODO // TODO
// Given a node id, this function returns the id of the router connected to the node,
// or -1 if the node id is not valid.
return -1; return -1;
static int dragonfly_get_router_compute_node_count(void* topo, router_id_t r) { static int dragonfly_custom_get_router_compute_node_count(void* topo, router_id_t r) {
// TODO // TODO
// Given the id of a router, returns the number of compute nodes connected to this
// router, or -1 if the router id is not valid.
return 0; return 0;
static void dragonfly_get_router_compute_node_list(void* topo, router_id_t r, cn_id_t* nodes) { static void dragonfly_custom_get_router_compute_node_list(void* topo, router_id_t r, cn_id_t* nodes) {
// TODO // TODO
// Given the id of a router, fills the "nodes" array with the list of ids of compute nodes
// connected to this router. It is assumed that enough memory has been allocated for the
// "nodes" variable to hold all the ids.
cortex_topology dragonfly_cortex_topology = { cortex_topology dragonfly_custom_cortex_topology = {
.internal = NULL, .internal = NULL,
.get_router_link_bandwidth = dragonfly_get_router_link_bandwidth, .get_router_link_bandwidth = dragonfly_custom_get_router_link_bandwidth,
.get_compute_node_bandwidth = dragonfly_get_compute_node_bandwidth, .get_compute_node_bandwidth = dragonfly_custom_get_compute_node_bandwidth,
.get_router_neighbor_count = dragonfly_get_router_neighbor_count, .get_router_neighbor_count = dragonfly_custom_get_router_neighbor_count,
.get_router_neighbor_list = dragonfly_get_router_neighbor_list, .get_router_neighbor_list = dragonfly_custom_get_router_neighbor_list,
.get_router_location = dragonfly_get_router_location, .get_router_location = dragonfly_custom_get_router_location,
.get_compute_node_location = dragonfly_get_compute_node_location, .get_compute_node_location = dragonfly_custom_get_compute_node_location,
.get_router_from_compute_node = dragonfly_get_router_from_compute_node, .get_router_from_compute_node = dragonfly_custom_get_router_from_compute_node,
.get_router_compute_node_count = dragonfly_get_router_compute_node_count, .get_router_compute_node_count = dragonfly_custom_get_router_compute_node_count,
.get_router_compute_node_list = dragonfly_get_router_compute_node_list, .get_router_compute_node_list = dragonfly_custom_get_router_compute_node_list,
#endif #endif
Markdown is supported
0%
or
Please register or to comment
