Commit 8de615cf authored by Misbah Mubarak's avatar Misbah Mubarak
changes to dragonfly global routing and reverse handler
parent 74feda70
...@@ -2323,6 +2323,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des ...@@ -2323,6 +2323,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des
/* If no direct connection exists then find an intermediate connection */ /* If no direct connection exists then find an intermediate connection */
if(curMap.find(dest_rel_id) == curMap.end()) if(curMap.find(dest_rel_id) == curMap.end())
assert(0);
int src_col = src_rel_id % s->params->num_router_cols; int src_col = src_rel_id % s->params->num_router_cols;
int src_row = src_rel_id / s->params->num_router_cols; int src_row = src_rel_id / s->params->num_router_cols;
...@@ -2406,6 +2407,7 @@ get_next_stop(router_state * s, ...@@ -2406,6 +2407,7 @@ get_next_stop(router_state * s,
bf->c19 = 1; bf->c19 = 1;
vector<int> next_stop = get_intra_router(s, local_router_id, dest_router_id, s->params->num_routers); vector<int> next_stop = get_intra_router(s, local_router_id, dest_router_id, s->params->num_routers);
assert(!next_stop.empty()); assert(!next_stop.empty());
assert(next_stop.size() == 1);
select_chan = tw_rand_integer(lp->rng, 0, next_stop.size() - 1); select_chan = tw_rand_integer(lp->rng, 0, next_stop.size() - 1);
codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM_ROUT, s->anno, 0, next_stop[select_chan] / num_routers_per_mgrp, codes_mapping_get_lp_id(lp_group_name, LP_CONFIG_NM_ROUT, s->anno, 0, next_stop[select_chan] / num_routers_per_mgrp,
...@@ -2429,21 +2431,22 @@ get_next_stop(router_state * s, ...@@ -2429,21 +2431,22 @@ get_next_stop(router_state * s,
select_chan = adap_chan; select_chan = adap_chan;
else else
/* Only for non-minimal routes, direct connections are preferred
* (global ports) */
if(interGroupLinks[s->router_id][dest_group_id].size() > 1 && get_direct_con) if(interGroupLinks[s->router_id][dest_group_id].size() > 1 && get_direct_con)
select_chan = find_chan(s->router_id, dest_group_id, s->params->num_routers); select_chan = find_chan(s->router_id, dest_group_id, s->params->num_routers);
assert(select_chan >= 0); assert(select_chan >= 0);
else else
bf->c19 = 1; bf->c16 = 1;
select_chan = tw_rand_integer(lp->rng, 0, connectionList[my_grp_id][dest_group_id].size() - 1); select_chan = tw_rand_integer(lp->rng, 0, connectionList[my_grp_id][dest_group_id].size() - 1);
dest_lp = connectionList[my_grp_id][dest_group_id][select_chan]; dest_lp = connectionList[my_grp_id][dest_group_id][select_chan];
//printf("\n my grp %d dest router %d dest_lp %d rid %d chunk id %d", my_grp_id, dest_router_id, dest_lp, s->router_id, msg->chunk_id); //printf("\n my grp %d dest router %d dest_lp %d rid %d chunk id %d", my_grp_id, dest_router_id, dest_lp, s->router_id, msg->chunk_id);
msg->saved_src_dest = dest_lp; msg->saved_src_dest = dest_lp;
msg->saved_src_chan = select_chan;
/* Get the number of global channels connecting the origin and destination /* Get the number of global channels connecting the origin and destination
* groups */ * groups */
...@@ -2451,7 +2454,10 @@ get_next_stop(router_state * s, ...@@ -2451,7 +2454,10 @@ get_next_stop(router_state * s,
if(s->router_id == msg->saved_src_dest) if(s->router_id == msg->saved_src_dest)
dest_lp = connectionList[dest_group_id][my_grp_id][msg->saved_src_chan]; bf->c17 = 1;
select_chan = tw_rand_integer(lp->rng, 0, interGroupLinks[s->router_id][dest_group_id].size() - 1);
bLink bl = interGroupLinks[s->router_id][dest_group_id][select_chan];
dest_lp = bl.dest;
else else
...@@ -2511,7 +2517,7 @@ get_output_port( router_state * s, ...@@ -2511,7 +2517,7 @@ get_output_port( router_state * s,
rand_offset = tw_rand_integer(lp->rng, 0, interGroupLinks[src_router][intm_grp_id].size()-1); rand_offset = tw_rand_integer(lp->rng, 0, interGroupLinks[src_router][intm_grp_id].size()-1);
assert(rand_offset >= 0); assert(rand_offset >= 0 && rand_offset < s->params->num_global_channels);
bLink bl = interGroupLinks[src_router][intm_grp_id][rand_offset]; bLink bl = interGroupLinks[src_router][intm_grp_id][rand_offset];
int channel_id = bl.offset; int channel_id = bl.offset;
...@@ -2529,20 +2535,20 @@ get_output_port( router_state * s, ...@@ -2529,20 +2535,20 @@ get_output_port( router_state * s,
int dest_col = intra_rtr_id % p->num_router_cols; int dest_col = intra_rtr_id % p->num_router_cols;
int dest_row = intra_rtr_id / p->num_router_cols; int dest_row = intra_rtr_id / p->num_router_cols;
if(src_col == dest_col) if(src_row == dest_row)
int offset = tw_rand_integer(lp->rng, 0, p->num_col_chans -1);
output_port = p->num_router_cols * p->num_row_chans + dest_row * p->num_col_chans + offset;
assert(output_port < p->intra_grp_radix);
else
int offset = tw_rand_integer(lp->rng, 0, p->num_row_chans -1); int offset = tw_rand_integer(lp->rng, 0, p->num_row_chans -1);
output_port = dest_col * p->num_row_chans + offset; output_port = dest_col * p->num_row_chans + offset;
assert(output_port < (s->params->num_router_cols * p->num_row_chans)); assert(output_port < (s->params->num_router_cols * p->num_row_chans));
else else if(src_col == dest_col)
assert(0);
output_port = (p->num_router_cols * p->num_row_chans) + dest_row * p->num_col_chans + offset;
else
tw_error(TW_LOC, "\n Invalid dragonfly connectivity src row %d dest row %d src col %d dest col %d src %d dest %d", tw_error(TW_LOC, "\n Invalid dragonfly connectivity src row %d dest row %d src col %d dest col %d src %d dest %d",
src_row, dest_row, src_col, dest_col, intragrp_rtr_id, intra_rtr_id); src_row, dest_row, src_col, dest_col, intragrp_rtr_id, intra_rtr_id);
...@@ -2738,7 +2744,7 @@ static int do_global_adaptive_routing( router_state * s, ...@@ -2738,7 +2744,7 @@ static int do_global_adaptive_routing( router_state * s,
min_port_b = get_output_port(s, msg, lp, bf, min_rtr_b_id); min_port_b = get_output_port(s, msg, lp, bf, min_rtr_b_id);
/* if a direct global channel exists for non-minimal route then give a priority to that. */ /* if a direct global channel exists for non-minimal route in the source group then give a priority to that. */
if(msg->my_l_hop == 1) if(msg->my_l_hop == 1)
nonmin_chan_a = find_chan(s->router_id, intm_grp_id_a, s->params->num_routers); nonmin_chan_a = find_chan(s->router_id, intm_grp_id_a, s->params->num_routers);
...@@ -2752,13 +2758,15 @@ static int do_global_adaptive_routing( router_state * s, ...@@ -2752,13 +2758,15 @@ static int do_global_adaptive_routing( router_state * s,
if(nonmin_chan_a != -1) { if(nonmin_chan_a != -1) {
bf->c25=1; bf->c25=1;
noIntraA = true; noIntraA = true;
nonmin_rtr_a = interGroupLinks[s->router_id][intm_grp_id_a][0].dest; nonmin_rtr_a = interGroupLinks[s->router_id][intm_grp_id_a][nonmin_chan_a].dest;
else else
assert(rand_a >= 0); assert(rand_a >= 0);
nonmin_chan_a = rand_a; nonmin_chan_a = rand_a;
nonmin_rtr_a = connectionList[my_grp_id][intm_grp_id_a][rand_a]; nonmin_rtr_a = connectionList[my_grp_id][intm_grp_id_a][rand_a];
if(nonmin_rtr_a == s->router_id)
noIntraA = true;
assert(nonmin_chan_a >= 0); assert(nonmin_chan_a >= 0);
...@@ -2767,13 +2775,15 @@ static int do_global_adaptive_routing( router_state * s, ...@@ -2767,13 +2775,15 @@ static int do_global_adaptive_routing( router_state * s,
if(nonmin_chan_b != -1) { if(nonmin_chan_b != -1) {
bf->c26=1; bf->c26=1;
noIntraB = true; noIntraB = true;
nonmin_rtr_b = interGroupLinks[s->router_id][intm_grp_id_b][0].dest; nonmin_rtr_b = interGroupLinks[s->router_id][intm_grp_id_b][nonmin_chan_b].dest;
else else
assert(rand_b >= 0); assert(rand_b >= 0);
nonmin_chan_b = rand_b; nonmin_chan_b = rand_b;
nonmin_rtr_b = connectionList[my_grp_id][intm_grp_id_b][rand_b]; nonmin_rtr_b = connectionList[my_grp_id][intm_grp_id_b][rand_b];
if(nonmin_rtr_b == s->router_id)
noIntraB = true;
assert(nonmin_chan_b >= 0); assert(nonmin_chan_b >= 0);
...@@ -3014,6 +3024,10 @@ static void router_packet_receive_rc(router_state * s, ...@@ -3014,6 +3024,10 @@ static void router_packet_receive_rc(router_state * s,
if(bf->c19) if(bf->c19)
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
if(bf->c16)
if(bf->c17)
if(bf->c21) if(bf->c21)
...@@ -3169,7 +3183,6 @@ router_packet_receive( router_state * s, ...@@ -3169,7 +3183,6 @@ router_packet_receive( router_state * s,
* If not, set the non-minimal destination.*/ * If not, set the non-minimal destination.*/
if(s->router_id == cur_chunk->msg.intm_rtr_id) if(s->router_id == cur_chunk->msg.intm_rtr_id)
//assert(cur_chunk->msg.my_l_hop <= 6);
cur_chunk->msg.nonmin_done = 1; cur_chunk->msg.nonmin_done = 1;
else if(cur_chunk->msg.nonmin_done == 0) else if(cur_chunk->msg.nonmin_done == 0)
Markdown is supported
0%
or
Please register or to comment
