Skip to content
Projects
Groups
Snippets
Help
Loading...
Help
Support
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
C
codes
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
38
Issues
38
List
Boards
Labels
Milestones
Merge Requests
8
Merge Requests
8
Analytics
Analytics
Repository
Value Stream
Wiki
Wiki
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Commits
Issue Boards
Open sidebar
codes
codes
Commits
8de615cf
Commit
8de615cf
authored
Jun 07, 2018
by
Misbah Mubarak
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
changes to dragonfly global routing and reverse handler
parent
74feda70
Changes
1
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
31 additions
and
18 deletions
+31
-18
src/networks/model-net/dragonfly-custom.C
+31
-18
No files found.
View file @
8de615cf
@@ -2323,6 +2323,7 @@ static vector<int> get_intra_router(router_state * s, int src_router_id, int des
/* If no direct connection exists then find an intermediate connection */
if
curMap
find
dest_rel_id
curMap
end
assert
0
int
src_col
src_rel_id
s
params
num_router_cols
int
src_row
src_rel_id
s
params
num_router_cols
@@ -2406,6 +2407,7 @@ get_next_stop(router_state * s,
bf
c19
1
vector
int
next_stop
get_intra_router
s
local_router_id
dest_router_id
s
params
num_routers
assert
next_stop
empty
assert
next_stop
size
1
select_chan
tw_rand_integer
lp
rng
0
next_stop
size
1
codes_mapping_get_lp_id
lp_group_name
LP_CONFIG_NM_ROUT
s
anno
0
next_stop
select_chan
num_routers_per_mgrp
@@ -2429,21 +2431,22 @@ get_next_stop(router_state * s,
select_chan
adap_chan
else
/* Only for non-minimal routes, direct connections are preferred
* (global ports) */
if
interGroupLinks
s
router_id
dest_group_id
size
1
get_direct_con
select_chan
find_chan
s
router_id
dest_group_id
s
params
num_routers
select_chan
find_chan
s
router_id
dest_group_id
s
params
num_routers
assert
select_chan
0
else
bf
c1
9
1
bf
c1
6
1
select_chan
tw_rand_integer
lp
rng
0
connectionList
my_grp_id
dest_group_id
size
1
dest_lp
connectionList
my_grp_id
dest_group_id
select_chan
//printf("\n my grp %d dest router %d dest_lp %d rid %d chunk id %d", my_grp_id, dest_router_id, dest_lp, s->router_id, msg->chunk_id);
msg
saved_src_dest
dest_lp
msg
saved_src_chan
select_chan
/* Get the number of global channels connecting the origin and destination
* groups */
@@ -2451,7 +2454,10 @@ get_next_stop(router_state * s,
if
s
router_id
msg
saved_src_dest
dest_lp
connectionList
dest_group_id
my_grp_id
msg
saved_src_chan
bf
c17
1
select_chan
tw_rand_integer
lp
rng
0
interGroupLinks
s
router_id
dest_group_id
size
1
bLink
bl
interGroupLinks
s
router_id
dest_group_id
select_chan
dest_lp
bl
dest
else
@@ -2511,7 +2517,7 @@ get_output_port( router_state * s,
rand_offset
tw_rand_integer
lp
rng
0
interGroupLinks
src_router
intm_grp_id
size
1
assert
rand_offset
0
assert
rand_offset
0
rand_offset
s
params
num_global_channels
bLink
bl
interGroupLinks
src_router
intm_grp_id
rand_offset
int
channel_id
bl
offset
@@ -2529,20 +2535,20 @@ get_output_port( router_state * s,
int
dest_col
intra_rtr_id
p
num_router_cols
int
dest_row
intra_rtr_id
p
num_router_cols
if
src_col
dest_col
int
offset
tw_rand_integer
lp
rng
0
p
num_col_chans
1
output_port
p
num_router_cols
p
num_row_chans
dest_row
p
num_col_chans
offset
assert
output_port
p
intra_grp_radix
else
if
src_row
dest_row
if
src_row
dest_row
int
offset
tw_rand_integer
lp
rng
0
p
num_row_chans
1
output_port
dest_col
p
num_row_chans
offset
assert
output_port
s
params
num_router_cols
p
num_row_chans
else
else
if
src_col
dest_col
assert
0
int
offset
tw_rand_integer
lp
rng
0
p
num_col_chans
1
output_port
p
num_router_cols
p
num_row_chans
dest_row
p
num_col_chans
offset
assert
output_port
p
intra_grp_radix
else
tw_error
TW_LOC
\n
Invalid dragonfly connectivity src row %d dest row %d src col %d dest col %d src %d dest %d"
src_row
dest_row
src_col
dest_col
intragrp_rtr_id
intra_rtr_id
@@ -2738,7 +2744,7 @@ static int do_global_adaptive_routing( router_state * s,
min_port_b
get_output_port
s
msg
lp
bf
min_rtr_b_id
/* if a direct global channel exists for non-minimal route then give a priority to that. */
in the source group
if
msg
my_l_hop
1
nonmin_chan_a
find_chan
s
router_id
intm_grp_id_a
s
params
num_routers
@@ -2752,13 +2758,15 @@ static int do_global_adaptive_routing( router_state * s,
if
nonmin_chan_a
1
bf
c25
1
noIntraA
true
nonmin_rtr_a
interGroupLinks
s
router_id
intm_grp_id_a
0
dest
nonmin_rtr_a
interGroupLinks
s
router_id
intm_grp_id_a
nonmin_chan_a
dest
else
assert
rand_a
0
nonmin_chan_a
rand_a
nonmin_rtr_a
connectionList
my_grp_id
intm_grp_id_a
rand_a
if
nonmin_rtr_a
s
router_id
noIntraA
true
assert
nonmin_chan_a
0
@@ -2767,13 +2775,15 @@ static int do_global_adaptive_routing( router_state * s,
if
nonmin_chan_b
1
bf
c26
1
noIntraB
true
nonmin_rtr_b
interGroupLinks
s
router_id
intm_grp_id_b
0
dest
nonmin_rtr_b
interGroupLinks
s
router_id
intm_grp_id_b
nonmin_chan_b
dest
else
assert
rand_b
0
nonmin_chan_b
rand_b
nonmin_rtr_b
connectionList
my_grp_id
intm_grp_id_b
rand_b
if
nonmin_rtr_b
s
router_id
noIntraB
true
assert
nonmin_chan_b
0
@@ -3014,6 +3024,10 @@ static void router_packet_receive_rc(router_state * s,
if
bf
c19
tw_rand_reverse_unif
lp
rng
if
bf
c16
lp
rng
if
bf
c17
lp
rng
if
bf
c21
lp
rng
@@ -3169,7 +3183,6 @@ router_packet_receive( router_state * s,
* If not, set the non-minimal destination.*/
if
s
router_id
cur_chunk
msg
intm_rtr_id
//assert(cur_chunk->msg.my_l_hop <= 6);
cur_chunk
msg
nonmin_done
1
else
if
cur_chunk
msg
nonmin_done
0
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
