Commit 8815fdde authored by Jonathan Jenkins's avatar Jonathan Jenkins
Browse files
add config reading function for checkpoint wrkld
parent 74ac5414
...@@ -27,6 +27,9 @@ enum checkpoint_status ...@@ -27,6 +27,9 @@ enum checkpoint_status
CHECKPOINT_INACTIVE, CHECKPOINT_INACTIVE,
static void * checkpoint_workload_read_config(
ConfigHandle *handle,
char const * section_name);
static int checkpoint_workload_load(const char* params, int app_id, int rank); static int checkpoint_workload_load(const char* params, int app_id, int rank);
static void checkpoint_workload_get_next(int app_id, int rank, struct codes_workload_op *op); static void checkpoint_workload_get_next(int app_id, int rank, struct codes_workload_op *op);
...@@ -66,10 +69,39 @@ static int chkpoint_tbl_pop = 0; ...@@ -66,10 +69,39 @@ static int chkpoint_tbl_pop = 0;
struct codes_workload_method checkpoint_workload_method = struct codes_workload_method checkpoint_workload_method =
.method_name = "checkpoint_io_workload", .method_name = "checkpoint_io_workload",
.codes_workload_read_config = &checkpoint_workload_read_config,
.codes_workload_load = &checkpoint_workload_load, .codes_workload_load = &checkpoint_workload_load,
.codes_workload_get_next = &checkpoint_workload_get_next, .codes_workload_get_next = &checkpoint_workload_get_next,
checkpoint_wrkld_params *p = malloc(sizeof(*p));
assert(p);
int rc;
rc = configuration_get_value_double(&config, section_name, "checkpoint_sz",
NULL, &p->checkpoint_sz);
assert(!rc);
"checkpoint_wr_bw", NULL, &p->checkpoint_wr_bw);
assert(!rc);
rc = configuration_get_value_double(&config, section_name, "app_run_time",
NULL, &p->app_runtime);
assert(!rc);
rc = configuration_get_value_double(&config, section_name, "mtti", NULL,
&p->mtti);
assert(!rc);
return p;
static int checkpoint_workload_load(const char* params, int app_id, int rank) static int checkpoint_workload_load(const char* params, int app_id, int rank)
checkpoint_wrkld_params *c_params = (checkpoint_wrkld_params *)params; checkpoint_wrkld_params *c_params = (checkpoint_wrkld_params *)params;
Markdown is supported
0% or .
Please register or to comment
